Offline rex he
#1 Posted : 13 January 2022 13:38:26(UTC)
rex he
Rank: Member
China
Is there any curve fitting function in Smath?
I mean using the defined points to find the function of these points!
Thanks a lot!
Offline rex he
#2 Posted : 14 January 2022 06:00:26(UTC)
rex he
Rank: Member
China
... for best examination: close Smath ... open a virgin session.
This way, as you will download, both will be resident in same session.
Open include to inspect the content, close back.
Open Test UpDated ... F9 to run
Test Updated contents 5 stand alone fit examples.
If it does not work wrt your Smath version ... bug.
Try it ... report ... Jean
Genfit Algo Include.sm (37kb) downloaded 28 time(s).
Genfit Algo Include Test UpDated.sm (146kb) downloaded 23 time(s).
Hi Jean,
Thanks for your reply!
I tired the .sm file, but it doesn't work well. Meanwhile, the Genfit Algo Include.sm needs rename as GenfitAlgoInclude.sm.
I put the two .sm files in the same location, tSmath_error.pnghen I opened the Test Updated.sm, and pressed F9 to run....the error is shown in the picture.
The information of my Smath is Version 0.99
Looking forward to your feedback, thanks!
[attach]42964
Edited by user 14 January 2022 06:02:44(UTC)  | Reason: Not specified
Offline CBG
#3 Posted : 14 January 2022 06:53:11(UTC)
CBG
Hello
Maybe you can deal with Least Squares Fit
Define_a_Variable_Ajust_by_Last_Square.sm (59kb) downloaded 51 time(s).
Ajust_by_Last_Square_Selection.sm (55kb) downloaded 25 time(s).
Carlos
Edited by user 14 January 2022 06:55:57(UTC)  | Reason: Not specified
Offline overlord
#4 Posted : 14 January 2022 08:04:40(UTC)
Turkey
Was thanked: 506 time(s) in 337 post(s)
Answer is YES
I don't know an embedded function for this.
But you can write your own function.
Lagrange Interpolation Method can be used.
maple() command is not necessary but it simplifies the function.
Giving more points, curve gets more complex.
Here is some examples for your request.
lagrange.sm (27kb) downloaded 29 time(s).
Click to enlarge
Click to enlarge
Click to enlarge
Click to enlarge
Edited by user 15 January 2022 14:20:22(UTC)  | Reason: Not specified
thanks 2 users thanked overlord for this useful post.
on 14/01/2022(UTC),  on 14/01/2022(UTC)
Offline rex he
#5 Posted : 14 January 2022 08:55:13(UTC)
rex he
Rank: Member
China
Originally Posted by: CBG Go to Quoted Post
Hello
Carlos
Hi Carlos,
This works really fine, thanks for sharing this!
Offline rex he
#6 Posted : 14 January 2022 08:57:10(UTC)
rex he
Rank: Member
China
Originally Posted by: overlord Go to Quoted Post
Answer is YES
Click to enlarge
Click to enlarge
Click to enlarge
Click to enlarge
Hi, thanks for sharing this, I will try to learn your file!
Offline mkraska
#7 Posted : 14 January 2022 11:36:56(UTC)
mkraska
Was thanked: 1120 time(s) in 718 post(s)
Thanks a lot!
Maxima plugin has the Fit() function, see this post
In the interactive handbook, you find it in the Function Index page.
on 14/01/2022(UTC)
Offline Razonar
#8 Posted : 14 January 2022 12:56:58(UTC)
Razonar
Uruguay
Hi. Some fitting curves functions in the attached.
fit.pdf (528kb) downloaded 37 time(s).
fit.sm (378kb) downloaded 36 time(s).
thanks 3 users thanked Razonar for this useful post.
on 14/01/2022(UTC),  on 14/01/2022(UTC),  on 14/01/2022(UTC)
Offline overlord
#9 Posted : 14 January 2022 16:56:33(UTC)
Turkey
You are welcome.
My function is direct method, may not be suitable for large data sets.
Razonar's and mkraska's samples are good to investigate too for that purpose.
Offline Razonar
#10 Posted : 14 January 2022 22:25:17(UTC)
Razonar
Uruguay
Hi ovlerlord.
Answer is YES
Yes, it is YES.
This version of your application doesn't need maple for get the simplified lagrange polynom.
lagrange.sm (23kb) downloaded 29 time(s).
on 14/01/2022(UTC)
Offline rex he
#11 Posted : 17 January 2022 06:15:21(UTC)
rex he
Rank: Member
China
Hi Jean,
Please, attach your raw data set., i.e: not freaked by else.
Two more examples attached.
Genfit Frechet DIFFICULT.sm (129kb) downloaded 6 time(s).
Genfit Kirby_2 [Reduced] Copy.sm (82kb) downloaded 6 time(s).
A fitting session is mostly governed by the model and techniques.
In short: sky is the limit. Some data set can only be fitted by hand.
Plenty are willing in Smath Community.
Take care ... Jean
Strain.txt (14kb) downloaded 5 time(s). Stress.txt (14kb) downloaded 5 time(s).
Hi Jean,
see the stress-strain data, I would say I am really happy about this forum. I got a lot of fit function information from here! Thanks all!
Offline Razonar
#12 Posted : 17 January 2022 10:55:01(UTC)
Razonar
Uruguay
Hi. Three fitting models for your data.
fit_stress_strain.sm (524kb) downloaded 36 time(s).
fit_stress_strain.pdf (636kb) downloaded 33 time(s).
on 17/01/2022(UTC)
Offline rex he
#13 Posted : 17 January 2022 11:58:00(UTC)
rex he
Rank: Member
China
Wow, it's amazing!
Thanks Alvaro!
#14 Posted : 27 January 2022 00:21:34(UTC)
Hi Jean,
I tried the .sm file, but it doesn't work well.
You have detected a bug wrt your SS version, maybe earlier ones ?
Silent Smath Community ?
If you open the governing Conjugate Gradient ... it could be
the symbolic module has not been saved Symbolic, a common bug reported.
By same token, I will delete all previous attachments.
Please, don't hesitate ... Take care ... Jean.
I guess your original raw data is the one from Alvaro ?
