Joined: 15/10/2019(UTC) Posts: 7  Location: Suzhou Was thanked: 1 time(s) in 1 post(s)
Hello, Is there any curve fitting function in Smath? I mean using the defined points to find the function of these points! Thanks a lot!
Originally Posted by: Jean Giraud  ... for best examination: close Smath ... open a virgin session. This way, as you will download, both will be resident in same session. Open include to inspect the content, close back. Open Test UpDated ... F9 to run Test Updated contents 5 stand alone fit examples. If it does not work wrt your Smath version ... bug. Try it ... report ... Jean Genfit Algo Include.sm (37kb) downloaded 15 time(s). Genfit Algo Include Test UpDated.sm (146kb) downloaded 14 time(s). Hi Jean, Thanks for your reply! I tired the .sm file, but it doesn't work well. Meanwhile, the Genfit Algo Include.sm needs rename as GenfitAlgoInclude.sm. I put the two .sm files in the same location, t  hen I opened the Test Updated.sm, and pressed F9 to run....the error is shown in the picture. The information of my Smath is Version 0.99 Looking forward to your feedback, thanks! [attach]42964 Edited by user 14 January 2022 06:02:44(UTC)
| Reason: Not specified
Was thanked: 67 time(s) in 49 post(s)
Joined: 23/07/2013(UTC) Posts: 760  Was thanked: 267 time(s) in 190 post(s)
Originally Posted by: rex he  I mean using the defined points to find the function of these points! Answer is YESI don't know an embedded function for this. But you can write your own function. Lagrange Interpolation Method can be used. maple() command is not necessary but it simplifies the function. Giving more points, curve gets more complex. Here is some examples for your request. Regards lagrange.sm (27kb) downloaded 17 time(s).    Edited by user 15 January 2022 14:20:22(UTC)
 2 users thanked overlord for this useful post.
on 14/01/2022(UTC), on 14/01/2022(UTC)
Originally Posted by: CBG  Hi Carlos, This works really fine, thanks for sharing this!
Originally Posted by: overlord  Answer is YESI don't know an embedded function for this. But you can write your own function. Lagrange Interpolation Method can be used. maple() command is not necessary but it simplifies the function. Giving more points, curve gets more complex. Here is some examples for your request. Regards lagrange.sm (27kb) downloaded 17 time(s).    Hi, thanks for sharing this, I will try to learn your file!
Joined: 15/04/2012(UTC) Posts: 1,723  Was thanked: 950 time(s) in 602 post(s)
Originally Posted by: rex he  Hello, Is there any curve fitting function in Smath? I mean using the defined points to find the function of these points! Thanks a lot! Maxima plugin has the Fit() function, see this postIn the interactive handbook, you find it in the Function Index page.  |
Joined: 28/08/2014(UTC) Posts: 970  Was thanked: 530 time(s) in 345 post(s)
Hi. Some fitting curves functions in the attached. fit.pdf (528kb) downloaded 24 time(s). fit.sm (378kb) downloaded 20 time(s).Best regards. Alvaro.
 3 users thanked Razonar for this useful post.
on 14/01/2022(UTC), on 14/01/2022(UTC), on 14/01/2022(UTC)
Originally Posted by: rex he  Hi, thanks for sharing this, I will try to learn your file! You are welcome. My function is direct method, may not be suitable for large data sets. Razonar's and mkraska's samples are good to investigate too for that purpose. Regards
Hi ovlerlord. Originally Posted by: overlord  Answer is YES
Yes, it is YES. Originally Posted by: overlord  Lagrange Interpolation Method can be used. maple() command is not necessary but it simplifies the function.
This version of your application doesn't need maple for get the simplified lagrange polynom. lagrange.sm (23kb) downloaded 19 time(s).Best regards. Alvaro.
Originally Posted by: Jean Giraud  Originally Posted by: rex he  Hi Jean, Thanks for your reply! Please, attach your raw data set., i.e: not freaked by else. Two more examples attached. Genfit Frechet DIFFICULT.sm (129kb) downloaded 5 time(s). Genfit Kirby_2 [Reduced] Copy.sm (82kb) downloaded 5 time(s).A fitting session is mostly governed by the model and techniques. In short: sky is the limit. Some data set can only be fitted by hand. Plenty are willing in Smath Community. Take care ... Jean Strain.txt (14kb) downloaded 4 time(s). Stress.txt (14kb) downloaded 4 time(s).Hi Jean, see the stress-strain data, I would say I am really happy about this forum. I got a lot of fit function information from here! Thanks all!
Originally Posted by: Razonar  Wow, it's amazing! Thanks Alvaro!
Joined: 04/07/2015(UTC) Posts: 6,077  Was thanked: 889 time(s) in 717 post(s)
Originally Posted by: rex he  Hi Jean, Thanks for your reply! I tried the .sm file, but it doesn't work well. You have detected a bug wrt your SS version, maybe earlier ones ? Silent Smath Community ? If you open the governing Conjugate Gradient ... it could be the symbolic module has not been saved Symbolic, a common bug reported. By same token, I will delete all previous attachments. Please, don't hesitate ... Take care ... Jean. I guess your original raw data is the one from Alvaro ?
