SMath Studio Forum
Questions
Definition of Variables with several "if".
Is it possible to define a variable, that depends on an other variable.
I want to define a variable like: "Mpa".
The "Mpa" is 400N/mm^2, if the variable "Diameter" is 12mm. If the variable "Diameter" is 14mm, "MPA" should be 300N/mm^2. If the variable "Diameter" is 16mm, "MPA" should be 250/mm^2. ...
At the end, the list is about 15 different possibilities.
I came from Mathcad. Mathcad has the option "add Line". With this, you can add as much "if"-Lines as you wand. Is there a possibility to do this in Smath Studio also?
Thank you.
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 508 time(s) in 338 post(s)
If I understood correct, what you need is cases() function.
Joined: 14/09/2013(UTC) Posts: 90 Was thanked: 24 time(s) in 16 post(s)
Please note that cases() function is not directly included in SMath "core" functions; you will find it after installing a plug-in called Custom Functions. You can find it in SMath extension manager.
Originally Posted by: MathUser123 I came from Mathcad. Mathcad has the option "add Line". With this, you can add as much "if"-Lines as you wand. Is there a possibility to do this in Smath Studio also?
Lot more pro in Smath ... coma twice on any place holder.
You can make cases() as a function. This will make mpa value easily calculated. Regards
Inspired from overlord.
Just a reminder, you should watch for order in cases. Once one if condition is provided, below won't be regarded. Regards
Hey, thank you all. You are awesome. It worked. Thanks for your detailed inputs. Regards…
Hello For this type of project, I try to fit the data to a curve and find its equation, and thus calculate any value in the specified range. Although in this case, the values given are very few, as an example I annex the corresponding calculation. Define_a_Variable_Ajust_by_Last_Square.sm (59kb) downloaded 52 time(s).Best Regards Carlos
Hola Carlos, best 2022. Pretty clean Quadratic fit ! Take care ... Jean Quadratic fit.sm (15kb) downloaded 17 time(s).
Hola Jean
Feliz y Prospero 2022
Nice quadratic fit, thanks
Cuidate mucho
Carlos
SMath Studio Forum
Questions
