Offline FT_PENG
#1 Posted : 23 December 2021 23:49:19(UTC)
FT_PENG
Hi, I ran into an issue trying to use Solve() function with Maxima plugin.
I installed the last version of plugin (5.45.1)
and even the refence book seems to not work properly:
Click to enlarge
although, when I remove the L:= it does solve again.
Click to enlarge
how could I resolve this issue?
regards,
Edited by moderator 24 December 2021 17:27:37(UTC)  | Reason: Made a preview for the images.
Offline Razonar
#2 Posted : 24 December 2021 04:05:31(UTC)
Razonar
Uruguay
Was thanked: 989 time(s) in 618 post(s)
regards,
Hi. Think of Solve's non-evaluation problem as something similar to what you get with Hold in Mathematica or with 'x' in Maple. I do not know if it is a change in the behavior of the plugin that is here to stay, or an unwanted effect due to an update, but what you can do is not define with := and ask in the same line for the symbolic result, but first define L := Solve (...) and then symbolically evaluate L ->
this means, SMath needs another step to proceed to evaluate the expression in Solve.
#3 Posted : 24 December 2021 15:35:29(UTC)
From native Smath 6179.
Offline overlord
#4 Posted : 24 December 2021 18:37:06(UTC)
Turkey
Was thanked: 548 time(s) in 368 post(s)
Not related with OP's question.
Your reply doesn't have the answer also.
