Joined: 23/07/2013(UTC) Posts: 1,125 Was thanked: 506 time(s) in 337 post(s)
Originally Posted by: alexa123 Here is your manually recovered file. Apparently there was an empty text region. It was starting at line 8662. That was causing the error. Removing it made the file tick. Regards Podwojny balkon1.sm (2,867kb) downloaded 16 time(s).Code: <region left="342" top="56124" width="63" height="27" color="#000000" fontSize="12">
<text lang="pol" width="55" fontFamily="Times New Roman" fontSize="12">
<content>
<p> \[REGION[c655dfafd07249abba46f86987917195]]\[m2]</p>
</content>
<regions>
<region id="c655dfafd07249abba46f86987917195" left="10" top="0" width="17" height="26" color="#000000" fontSize="12" />
</regions>
</text>
</region>
Joined: 09/12/2021(UTC) Posts: 27 Location: MG Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: overlord Originally Posted by: alexa123 Here is your manually recovered file. Apparently there was an empty text region. It was starting at line 8662. That was causing the error. Removing it made the file tick. Regards Podwojny balkon1.sm (2,867kb) downloaded 16 time(s).Code: <region left="342" top="56124" width="63" height="27" color="#000000" fontSize="12">
<content>
</content>
<regions>
</regions>
</text>
</region>
good morning I'm having the same problem how do I open this msdos tab to fix?
