9 Pages«<45678>»
Offline uni
#101 Posted : 30 November 2021 08:35:46(UTC)
uni
Was thanked: 1286 time(s) in 751 post(s)
Originally Posted by: uni Go to Quoted Post
Linear interpolation and linear spline interpolation are different things. I will try to find the formulas that are used in these functions.
We can restore the interpolation functions: lspline(), pspline() and cspline(). This is how the cspline() function works. Based on the attached document and file from the PTC Mathcad forum.
Click to enlarge Click to enlarge
Cubic spline interpolation using Mathcad (2009).pdf (257kb) downloaded 40 time(s).
cspline1.mcdx.zip (13kb) downloaded 13 time(s).
cspline.sm (39kb) downloaded 22 time(s).
cspline.pdf (89kb) downloaded 16 time(s).
Edited by user 10 December 2021 13:42:42(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
#102 Posted : 30 November 2021 15:58:24(UTC)
With enough points, simply cinterp Smath.
ODE HIRES.sm (68kb) downloaded 16 time(s).
Offline uni
#103 Posted : 04 December 2021 06:46:37(UTC)
uni
rkfixed(3|4) added, but I still don’t know which derivative symbol is better to take. (ʹ) - modifier letter prime (U+02B9) used below. I don't know how to enter it from the keyboard.
Edited by user 10 December 2021 13:43:39(UTC)  | Reason: Not specified
Russia ☭ forever
on 04/12/2021(UTC)
Offline uni
#104 Posted : 04 December 2021 11:19:00(UTC)
uni
Full set: interp(), [l,p,c]spline().
Click to enlarge
Odesolve interpolation test.sm (60kb) downloaded 28 time(s).
Odesolve interpolation test.pdf (103kb) downloaded 23 time(s).
(*) rkfixed() with a bug now, so you will see something differ.
Edited by user 10 December 2021 13:45:44(UTC)  | Reason: Not specified
Russia ☭ forever
Offline uni
#105 Posted : 05 December 2021 12:55:49(UTC)
uni
(ʹ) - modifier letter prime (U 02B9) used below. I don't know how to enter it from the keyboard.
This can be done in 2 steps:
1. Copy \02B9\ to text region. This code will turn into a text simbol (ʹ).
2. Select and copy it as variable name.
PS. It looks like it's time to combine all Mathcad functions into one plugin - Mathcad Toolbox. It will contain all such functions: ODE solvers, spline functions, in/out functions and so on.
Edited by user 05 December 2021 16:29:09(UTC)  | Reason: Not specified
Russia ☭ forever
on 05/12/2021(UTC)
Offline Razonar
#106 Posted : 05 December 2021 19:18:42(UTC)
Razonar
Uruguay
Was thanked: 859 time(s) in 545 post(s)
Hi. Your develop looks brillant.
2. Select and copy it as variable name. ...
Also, you can get any unicode char with this
... PS. It looks like it's time to combine all Mathcad functions into one plugin - Mathcad Toolbox. It will contain all such functions: ODE solvers, spline functions, in/out functions and so on.
And don't forget the possibility that the area simply returns the equations of the differential equation or a non-linear system of equations so that the user can then try to solve the ode or nle systems with the functions he chooses.
on 06/12/2021(UTC)
Offline mkraska
#107 Posted : 06 December 2021 00:30:56(UTC)
mkraska
Was thanked: 1149 time(s) in 737 post(s)
This looks very interesting. Seems that it is not yet in the online gallery?
In principle, the built-in diff(1) operator would be an option but it looks ugly if applied twice.
The ordinary prime would be ok for me (just as it is used as tag in unit names), it is input as Shift # on german keyboards.
diff2.sm (3kb) downloaded 11 time(s).
#108 Posted : 06 December 2021 04:15:07(UTC)
I still don’t know which derivative symbol is better to take. (ʹWink - modifier letter prime (U 02B9) used below. I don't know how to enter it from the keyboard.
My preference goes for book style.
US keyboard D apostrophe (x):=
Offline uni
#109 Posted : 06 December 2021 06:07:58(UTC)
uni
I can't contact Andrey directly. The server does not allow compiling the sources, as there is no free space. Therefore, the latest changes are not yet available.
I've made some changes. I liked the idea with the str2num() function. Also I can override the diff(1) function, but that can be confusing.
Now it is possible to numerically solve the Cauchy problem for one variable: diff(y(x),x,n)=F(x,y(x),...,diff(y(x),x,n-1)) . Later, I will expand the rest of the ODE solvers to support this simplified form. But for this I need to combine plugins and add interpolation functions similar to Mathcad (lspline(), interp(), ...). It will be more convenient for me to test the solvers, comparing the results with Mathcad.
Block region collects equations in the form of a system and substitutes it as the first parameter into the function.
Click to enlarge
Edited by user 10 December 2021 13:45:12(UTC)  | Reason: Not specified
Russia ☭ forever
Offline uni
#110 Posted : 06 December 2021 10:32:09(UTC)
uni
I can add the ability to set this symbol directly in the document. This way you can change the default symbol.
Russia ☭ forever
on 06/12/2021(UTC)
Offline uni
#111 Posted : 06 December 2021 15:11:48(UTC)
uni
SMath Studio compatibility
Plugin updated. Please try.
Examples:
Mathcad Block.sm Mathcad Block. Examples.sm
Changes:
- rkfixed() now works correctly;
- Odesolve block renamed to Mathcad Block;
- the task for the ODE solver in the usual mathematical notation is supported;
- default diff symbol is apostrophe ( ' );
- linterp() is used as an interpolation function;
- refactored.
Edited by user 10 December 2021 13:43:52(UTC)  | Reason: Not specified
Russia ☭ forever
on 06/12/2021(UTC),  on 06/12/2021(UTC)
Offline Razonar
#112 Posted : 06 December 2021 19:41:05(UTC)
Razonar
Uruguay
Hi Viacheslav, thanks, great job. One question: Why to use linterp instead cspline? The problem with cspline is about the border of the interval, where you have only diff by the left and the right, and there you can adapt the cubic splines to be linear or parabolic, but in the interior of the interval I guess that it's better cubic splines interpolation.
ODEQuestion.sm (16kb) downloaded 16 time(s).
Offline uni
#113 Posted : 06 December 2021 21:44:46(UTC)
uni
I will add the interpolation functions ( interp(), lspline(),... ) to the plugin and rename it to Mathcad Toolbox. After that, it will be possible to test its work, comparing it with the Mathcad numerically.
Edited by user 06 December 2021 21:46:41(UTC)  | Reason: Not specified
Russia ☭ forever
on 06/12/2021(UTC)
Offline uni
#114 Posted : 07 December 2021 11:56:03(UTC)
uni
Plugin updated.
Changes:
- plugin renamed to Mathcad Toolbox;
- version changed to 0.3.*;
- interp(), lspline() functions added;
- lspline() function used in any ode solvers.
Russia ☭ forever
on 07/12/2021(UTC),  on 07/12/2021(UTC)
Offline mkraska
#115 Posted : 07 December 2021 14:32:19(UTC)
mkraska
Really nice generic block concept! It is a really good reason for updating the handbook and the portable distribution.
This is how to use it with symbolic solutions using Solve() (Maxima plugin):
Solve block.sm (6kb) downloaded 26 time(s).
Looking forward to a RK integrator for multi-DOF systems. This is how I would imagine the user interface.
Federpendel-block.sm (49kb) downloaded 28 time(s).
on 07/12/2021(UTC)
Offline uni
#116 Posted : 07 December 2021 15:32:51(UTC)
uni
This is the next step, but the existing solution is not stable and has some bugs.
Russia ☭ forever
Offline uni
#117 Posted : 07 December 2021 17:13:30(UTC)
uni
Plugin updated.
Changes:
- plugin merged with Mathcad File Access (all functions are inside Mathcad Toolbox);
- the condition has changed in the definition of the solver function (to support both directions of integration): (x-xmin)*(xmax-x)>=0;
- pspline() function added.
Russia ☭ forever
on 07/12/2021(UTC)
Offline Razonar
#118 Posted : 07 December 2021 20:00:34(UTC)
Razonar
Uruguay
Hi. In the meantime, we can play with things like this:
Solve block.sm (55kb) downloaded 32 time(s).
Edited by user 07 December 2021 20:04:36(UTC)  | Reason: Not specified
on 07/12/2021(UTC)
Offline uni
#119 Posted : 08 December 2021 08:24:11(UTC)
uni
Looks great, but something is missing.
Click to enlarge
Edited by user 10 December 2021 13:44:39(UTC)  | Reason: Not specified
Russia ☭ forever
on 08/12/2021(UTC)
Offline uni
#120 Posted : 10 December 2021 11:59:47(UTC)
uni
Plugin updated.
Changes:
- fixed algorithm for selecting regions (Mathcad Block).
Russia ☭ forever
on 10/12/2021(UTC)
9 Pages«<45678>»
