Offline uni
#1 Posted : 22 November 2021 01:47:14(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
DSP Library
SMath Studio compatibility Platform SMath Viewer compatibility mono compatibility Extension page Sources Examples
Functions list:
DSPL-2.0 — opensource cross-platform digital signal processing algorithm library, written in C language.
Distributed under LGPL v3 license. This allows to use this library in all applications with dynamic linking.
Source codes are available on GitHub.
DSPL-2.0 includes follow algorithms sets:
  • Digital spectral analysis, discrete and fast Fourier transform algorithms.
  • Analog and digital IIR filters design and analysis.
  • Digital FIR filters design and analysis.
  • Windows function collection includes 15 different parametric and nonparametric window functions.
  • Digital Hilbert transform algorithms.
  • Mathematical sections includes trigonometric, hyperbolic, elliptic functions of real and complex variables.
  • Pseudorandom numbers generation algorithms.
  • Statistic functions.
  • Linar algebra algorithms (BLAS and LAPACK packages are used under the hood of the DSPL-2.0 library).
  • Digital resampling algorithms.
Examples:
dspl_filter_iir.sm dspl_fir_linphase.sm dspl_iir.sm dspl_window.sm
dspl_filter_iir.pdf (156kb) downloaded 123 time(s).
dspl_fir_linphase.pdf (247kb) downloaded 97 time(s).
dspl_iir.pdf (234kb) downloaded 83 time(s).
dspl_window.pdf (857kb) downloaded 101 time(s).
Click to enlarge
Links:
1. DSPL-2.0 — free DSP algorithm library .
Edited by user 12 December 2021 22:38:42(UTC)  | Reason: Not specified
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
on 02/12/2021(UTC)
Offline johnspark
#2 Posted : 27 November 2021 12:48:56(UTC)
johnspark
Australia
Was thanked: 5 time(s) in 3 post(s)
Originally Posted by: uni Go to Quoted Post
DSP Library
thank you uni, very worthwhile Good
Edited by moderator 28 November 2021 06:43:46(UTC)  | Reason: Not specified
#3 Posted : 28 November 2021 23:35:07(UTC)
Spline2 is as named by the Originators.
It is a statistical spline based on Durbin-Watson test
to determine optimal number of knots and their spacing.
For this particular example, linfitCheby smooths/fits as well.
Robert LSQ works as well, knots from trial/error.
HadCRUt4 for Viacheslav.bmp (1,276kb) downloaded 62 time(s).
Offline johnspark
#4 Posted : 30 November 2021 14:08:33(UTC)
johnspark
Australia
Splines have their place Jean, but I also have future need for hamming window filters and DFT filters, etc. I have worked with $20,000+ protection relays that have very high quality DFT filters to find faults in HV networks ASAP, to reduce damage to people first and equipment second. That is where the c code comes into its own. If i get into power quality values, this work by uni will be indispensable. I think Mathcad used to have an expensive add on for this feature. Uni has kindly provided it for free. That is why I love this Smath forum so much.
Warming up in Adelaide ready for summer starting tomorrow
#5 Posted : 01 December 2021 01:46:21(UTC)
Originally Posted by: johnspark Go to Quoted Post
I have worked with $20,000 protection relays that have very high quality DFT filters to find faults in HV networks ASAP
Once you have the push down sized samples from the grid,
filtered for whatever filter means wrt the grid ...
Smath plugins have fft at hyper accuracy [sanity checked Mathematica, MCD]
From there, compare the spectrum-in vs model spectrum.
Fourier fft, ifft Sanity DEMO.sm (16kb) downloaded 73 time(s).
Offline uni
#6 Posted : 01 December 2021 03:29:17(UTC)
uni
Jean, this thread is intended to discuss only functions from DSP Library and no others. All other discussions should be contained in separate threads. If you want to attach a comparison document, then it must contain functions from DSP Library.
This topic should only contain technical (reference) information on how to use the extension. Other extensions have their own sections.
Edited by user 01 December 2021 03:36:29(UTC)  | Reason: Not specified
Offline uni
#7 Posted : 03 December 2021 10:11:34(UTC)
uni
Adding some functions. The server is still not available for building.
Click to enlarge
dspl_window.pdf (1,130kb) downloaded 62 time(s).
Edited by user 10 December 2021 13:50:52(UTC)  | Reason: Not specified
Offline uni
#8 Posted : 06 December 2021 15:26:12(UTC)
uni
Plugin updated.
Changes:
- many function added;
- refactored.
I will add examples of their use a little later.
Offline uni
#9 Posted : 08 December 2021 10:13:33(UTC)
uni
Examples:
Edited by user 12 December 2021 22:36:12(UTC)  | Reason: Not specified
Offline uni
#10 Posted : 16 December 2021 20:25:48(UTC)
uni
Plugin updated.
Changes:
- OpenBLAS library replaced with CLAPACK;
- totally refactored.
Offline uni
#11 Posted : 11 April 2023 11:06:24(UTC)
uni
Plugin updated (resampling algorithms added).
Changes:
- dspl_farrow_lagrange(3|4) and dspl_farrow_spline(3|4) functions added.
Click to enlarge Click to enlarge
dspl_farrow_lagrange.sm (10kb) downloaded 57 time(s).
dspl_farrow_spline.sm (10kb) downloaded 55 time(s).
Edited by user 11 April 2023 11:08:09(UTC)  | Reason: Not specified
on 11/04/2023(UTC),  on 13/04/2023(UTC),  on 13/04/2023(UTC)
