Hi everyone I am trying to create a matrix inside a matrix using a for loop. This is what I did: Matrix inside a matrix.sm (13kb) downloaded 8 time(s).This works but my real data is much larger than the one in this example and it takes like 10 minutes to run. Is there a more efficient way to do this? Thanks. Edited by user 23 November 2021 20:46:22(UTC)
| Reason: Not specified
Originally Posted by: (Pedro) This works but my real data is much larger than the one in this example and it takes like 10 minutes to run. Is there a more efficient way to do this?
Your example runs in 0.5 s [Steam Engine Win 7] Matrix inside a matrix.sm (13kb) downloaded 9 time(s).
Joined: 23/03/2016(UTC) Posts: 275 Was thanked: 91 time(s) in 57 post(s)
Two things. One move the assignment of p[k to under the k for loop. You're reassigning to p too often. Also, for large datasets, it helps to initialize the size of the matrix rather than just increasing the size over each iteration. See attaached. Matrix inside a matrix_lyles.sm (16kb) downloaded 9 time(s). |
1 user thanked alyles for this useful post.
Hola Pedro. Please check this version and tell us how long it takes with your data. Matrix inside a matrix.sm (32kb) downloaded 13 time(s).Best regards. Alvaro.
Originally Posted by: alyles Two things. On my Win 7 ... takes 4 times my original SS 6179 doctored version. Has it dependence with Smath version ? Cheers ... Jean.
Originally Posted by: Razonar Hola Pedro. Please check this version and tell us how long it takes with your data. Timing is about twice my doctored version.
Originally Posted by: alyles Two things. One move the assignment of p[k to under the k for loop. You're reassigning to p too often. Also, for large datasets, it helps to initialize the size of the matrix rather than just increasing the size over each iteration. See attaached. Matrix inside a matrix_lyles.sm (16kb) downloaded 9 time(s). Thanks a lot, this works perfectly
Originally Posted by: Razonar Hola Pedro. Please check this version and tell us how long it takes with your data. Matrix inside a matrix.sm (32kb) downloaded 13 time(s).Best regards. Alvaro. Gracias, aprecio tu ayuda
Originally Posted by: Jean Giraud Your example runs in 0.5 s [Steam Engine Win 7] ... annotated attachment ...Cheers ... Jean Matrix inside a matrix (Proposal).sm (32kb) downloaded 14 time(s).
1. Wait and see your next Monster Big. 2. 10 min on your machine might take 1 hr on mine, but willing. 3. Maybe not not so big and interpolate ? See you sometimes, Cheers ... Jean
