2 hours ago I have finished my task then I saved it and closed it. However, to take necessary information from my worksheet, I can not open my file. When I try, it automatically terminate itself.Can you help me about my issue? q2.sm (28kb) downloaded 5 time(s).Thanks.
Joined: 23/07/2013(UTC) Posts: 760  Was thanked: 267 time(s) in 190 post(s)
You can check smath files with a text editor. An empty region between lines 520-530 was causing force crash. Could you please check and inform if this works? Regards q2.sm (28kb) downloaded 6 time(s).
Thank you so much for your effort, you saved my whole day...  These are lines between 520-530.Which line creates the bug? In case, I will encounter this situation again in future, maybe I will be able to fix it myself. "I appreciate the way you help people!" Best Regards..
Joined: 04/07/2015(UTC) Posts: 6,077  Was thanked: 889 time(s) in 717 post(s)
Your work sheet works OK SS 6179 q2.sm (25kb) downloaded 4 time(s).
Originally Posted by: metu_engineer_1  Thank you so much for your effort, you saved my whole day...  These are lines between 520-530.Which line creates the bug? In case, I will encounter this situation again in future, maybe I will be able to fix it myself. "I appreciate the way you help people!" Best Regards.. Culprit is occasionaly lines contain >\[REGION[xxxxxxxx]]\. They usually have some context you did enter. Some title, some text, an image, etc. But as you can see in this, it is empty. I look for them at first, then others. Don't delete every REGION containing regions. Don't forget to backup your file too. Even it is not opening.
