2 hours ago I have finished my task then I saved it and closed it. However, to take necessary information from my worksheet, I can not open my file. When I try, it automatically terminate itself.Can you help me about my issue? q2.sm (28kb) downloaded 10 time(s).Thanks.
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 508 time(s) in 338 post(s)
You can check smath files with a text editor. An empty region between lines 520-530 was causing force crash. Could you please check and inform if this works? Regards q2.sm (28kb) downloaded 10 time(s).
Thank you so much for your effort, you saved my whole day... These are lines between 520-530.Which line creates the bug? In case, I will encounter this situation again in future, maybe I will be able to fix it myself. "I appreciate the way you help people!" Best Regards..
Your work sheet works OK SS 6179 q2.sm (25kb) downloaded 7 time(s).
Originally Posted by: metu_engineer_1 Thank you so much for your effort, you saved my whole day... These are lines between 520-530.Which line creates the bug? In case, I will encounter this situation again in future, maybe I will be able to fix it myself. "I appreciate the way you help people!" Best Regards.. Culprit is occasionaly lines contain >\[REGION[xxxxxxxx]]\. They usually have some context you did enter. Some title, some text, an image, etc. But as you can see in this, it is empty. I look for them at first, then others. Don't delete every REGION containing regions. Don't forget to backup your file too. Even it is not opening.
