Joined: 23/07/2013(UTC) Posts: 1,198  Was thanked: 548 time(s) in 368 post(s)
Originally Posted by: ndtma  In latest SS 99.7799, I experience a label error similar to image as shown. Some previous files show this error.
I couldn't replicate this bug but if you have it then there it is. Maybe I don't have old files that particular versions which gives this bug. But I can tell there is another one.
Joined: 05/06/2014(UTC) Posts: 351   Location: Colombo Was thanked: 130 time(s) in 84 post(s)
Originally Posted by: overlord  Originally Posted by: ndtma [url=/forum/yaf_postsm70673_X-Y-Plot-Region.aspx#post70673][/url]In latest SS 99.7799, I experience a label error similar to image as shown. Some previous files show this error.
Hello. Thanks for the feedback. I also had this problem. Therefore, I downloaded and checked the file of Alyles and observed the error as shown in my last post. Consequent to your post, I checked my collection and observed a strange situation with a one saved in version 99.7769 where no such error occurred when opened with 99.7799. On the other hand, a similar file in 99.7251 showed the error as shown.   Edited by user 11 May 2021 10:40:07(UTC)
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,641   Was thanked: 1400 time(s) in 817 post(s)
These numbers encode the text. Andrey changed something in new versions and I need to make changes in the plugin. Hopefully this only affects the display of the data. |
Russia ☭ forever (git.io/vOZo0) Viacheslav N. Mezentsev |
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,640   Was thanked: 2012 time(s) in 680 post(s)
Originally Posted by: uni  These numbers encode the text. Andrey changed something in new versions and I need to make changes in the plugin. Hopefully this only affects the display of the data. You're right, Viacheslav. You need to use this line of code to decode text entries: Quote:TermsConverter.DecodeText(txt) As I already mentioned, we have such kind of issues for a long time already. But in one of the latest beta versions I've made encoding more strict, so issues appears much more often now. Let's say that it is our chance to catch them and fix. Best regards.
on 11/05/2021(UTC), on 11/05/2021(UTC)
 Plugin updated. Please try. Changes: - plug-in corrected to respect latest SMath Studio API changes. |
on 12/05/2021(UTC), on 12/05/2021(UTC)
Joined: 28/08/2014(UTC) Posts: 1,533  Was thanked: 989 time(s) in 618 post(s)
Small piece of code for filled 2-D contour plot in the XY plot plugin. FillContour.sm (35kb) downloaded 330 time(s). FillContour.pdf (307kb) downloaded 319 time(s).Best regards Alvaro.
on 26/05/2021(UTC), on 26/05/2021(UTC)
Joined: 04/07/2015(UTC) Posts: 6,866  Was thanked: 983 time(s) in 811 post(s)
Added contour levels over the filled 2-D contour plot. ContourLevels.sm (88kb) downloaded 55 time(s). ContourLevels.pdf (1,234kb) downloaded 48 time(s).Best regards Alvaro.
 4 users thanked Razonar for this useful post.
on 26/05/2021(UTC), on 26/05/2021(UTC), on 26/05/2021(UTC), on 12/06/2021(UTC)
Slightly modified for accept loops and conditionals in the function procedure for functions like Mandelbrot set.  MandelbrotSet.sm (61kb) downloaded 58 time(s). MandelbrotSet.pdf (773kb) downloaded 29 time(s).Best regards Alvaro.
 3 users thanked Razonar for this useful post.
on 11/06/2021(UTC), on 11/06/2021(UTC), on 12/06/2021(UTC)
 Plugin updated. Please try. Changes: - fixed an issue with incorrect drawing of grid lines when changing the direction of the axis.  |
A colormaped trimesh in the XY plugin. pShowTMesh.sm (54kb) downloaded 36 time(s). Best regards. Alvaro.
on 05/11/2021(UTC), on 05/11/2021(UTC), on 06/11/2021(UTC)
 Plugin updated. Changes: - fixed problem when copying a region (some properties of the chart style were not copied). |
on 16/11/2021(UTC), on 16/11/2021(UTC)
 5 users thanked uni for this useful post.
on 16/11/2021(UTC), on 16/11/2021(UTC), on 16/11/2021(UTC), on 17/11/2021(UTC), on 17/11/2021(UTC)
Originally Posted by: uni  Linear polar examples. Hi. Very nice and useful plots. In some cases you can get more or less the same result with less effort using the plugin's ability to graph implicit functions.  Best regards. Alvaro.
 5 users thanked Razonar for this useful post.
on 17/11/2021(UTC), on 17/11/2021(UTC), on 17/11/2021(UTC), on 17/11/2021(UTC), on 17/11/2021(UTC)
 Plugin updated. Changes: - restored the ability to use units in arguments.   |
on 18/11/2021(UTC), on 18/11/2021(UTC), on 18/11/2021(UTC)
 Plugin updated. It works, but the component is still not stable. Changes: - added support for parametric plot type. '~' is used as a mark for the "range" variable and should only be used inside the X-Y Plot. When used in conjunction with ODE solvers (with a lspline() function), too many calculations are obtained and it is impossible to use this method.   Edited by user 14 December 2021 16:27:53(UTC)
on 14/12/2021(UTC), on 14/12/2021(UTC)
 Plugin updated. Changes: - some broken functionality repaired; - fixed error in determining the field width for vertical axes; - the decimal symbol is taken from the program settings now; - the midpoint is replaced by the multiplication sign ×; - added the ability to change the scales of the axes using the mouse wheel; - refactored.  Edited by user 15 December 2021 00:55:25(UTC)
 Plugin updated. Changes: - fixed a critical error when copying a region; - rendering of linetypes (dash, ...) slightly changed (enlarged); - added support for automatic drawing of the region when the document autocalculation mode is enabled (for now only for zoom mouse event). Edited by user 17 December 2021 13:16:23(UTC)
on 17/12/2021(UTC), on 17/12/2021(UTC)
 Plugin updated. Changes: - returned red border on error; - more complete support for auto-recalculation mode. |
on 17/12/2021(UTC), on 17/12/2021(UTC), on 18/12/2021(UTC)
