Offline Paecific
#1 Posted : 25 October 2021 19:34:04(UTC)
Paecific
Trying to plot a variety of functions and nothing shows up in the plots.
I have 23 yrs of MathCad experience, but cannot figure out what Smath is looking for to plot three very simple function (See attached file).
Additionally, I am not sure why an equation needs vectorized to output the answers in the normal distribution equation.
Equation 1 - Normal distribution does not solve as a function until it is vectorized. Why?
Equation 2 - f(x):x^3+2*x*sin(0.25) solves without vectorization but will not plot. Why?
Equation 3 - f(x):vectorize(1/{σ*sqrt(2*π)}*e^{-1/2*({x-μ}/σ)^2}) solves with vectorization but does not plot (2D or X-Y plot method). Why?
Smath - 2D Plots.sm (16kb) downloaded 13 time(s).
Offline Paecific
#2 Posted : 25 October 2021 19:54:36(UTC)
Paecific
Equation 2 also needs vectorized to get the correct results.
You don't have to do this in MathCad, why here?
Offline PompelmoTell
#3 Posted : 25 October 2021 20:35:07(UTC)
PompelmoTell
You have defined a vector of values ​​for x. If you use the X-YPLOT plugin you need to change the variable. If instead you use SM native 2D graph then it already works as you expect
Offline Paecific
#4 Posted : 25 October 2021 20:42:14(UTC)
Paecific
First Solution Found
This allowed me to plot Normal Distribution Function.
augment(x,f(x))
Offline Paecific
#5 Posted : 25 October 2021 21:13:13(UTC)
Paecific
Solved for now. On with the learning experience.
Thanks....
Offline Renzorex
#6 Posted : 25 October 2021 21:13:44(UTC)
Renzorex
Rank: Member
Peru
Was thanked: 4 time(s) in 2 post(s)
Hi, if you need a quick plot I recommend you use 2D standard plot you can plot functions f(x) directly , if you need a more configurable plot use XY plot but you need to put your data in a special format. PlotXY.png Smath - 2D Plots.sm (20kb) downloaded 4 time(s).
Offline overlord
#7 Posted : 25 October 2021 21:29:09(UTC)
Turkey
You don't need to use range() and augment() if you want to plot sections.
You can limit it with if-else() or cases().
Edited by user 25 October 2021 21:31:01(UTC)  | Reason: Not specified
#8 Posted : 25 October 2021 21:43:24(UTC)
1. Show the two other ones on same document for doctoring.
2. Your sigma makes no sense !
3. BTW, in Samples you should find my Stat Treasury [10 WS]
Hard to find such immense Compendium.
4. If you can't download, please let me know
Welcome ... Jean.
Smath - 2D Plots.sm (18kb) downloaded 12 time(s).
#9 Posted : 25 October 2021 21:50:14(UTC)
... besides the pure statistical application,
you can use to fit data sets [Fréchet US Rainfall ...]
#10 Posted : 25 October 2021 21:52:41(UTC)
There is about 24 built-in PDF in Smath ... f(x) menu
as well as CDF, ICDF
#11 Posted : 26 October 2021 13:05:13(UTC)
1. Discretize the range you want and plot ... No vectorize.
2. Plot scalar directly.
#12 Posted : 26 October 2021 13:29:00(UTC)
Paecific.sm (10kb) downloaded 7 time(s).
#13 Posted : 26 October 2021 14:20:56(UTC)
... in most applications inc(Low,High,step,f(#)) is preferred
Paecific.sm (15kb) downloaded 7 time(s).
#14 Posted : 26 October 2021 15:50:27(UTC)
Scalar plots have limited use, mostly confirm the project.
Discrete plot can be used for subsequent application/export.
1. Collapsed the algo at top utilities.
2. Use it infinitely in-situ use [range each f(x) at will].
Offline overlord
#15 Posted : 26 October 2021 17:29:10(UTC)
Turkey
Try this file.
Smath - 2D Plots_r1.sm (18kb) downloaded 22 time(s).
