Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
Offset surface creation An initial surface is given, given by the "createmesh" function, which forms a network with nodes. Dyou want to create an offset surface, offset by an amount h from the initial. The direction of displacement surface epends on the sign of h. Sequence of calculation: 1.Restoring the normal from the nodal points of the initial surface and we get the nodal points of the displaced surface. 2.We connect the resulting node points The image is built on three-dimensional graphics and can be rotated with the mouse Edited by user 05 April 2022 17:00:17(UTC)
| Reason: Not specified
4 users thanked Ber7 for this useful post.
on 11/10/2021(UTC), on 19/10/2021(UTC), on 20/10/2021(UTC), on 21/10/2021(UTC)
Joined: 09/11/2020(UTC) Posts: 17 Location: Cusco Was thanked: 4 time(s) in 2 post(s)
Thank you, this is helpful. I have a question, How did you put the icon with the link?
on 20/10/2021(UTC), on 20/10/2021(UTC)
Thanks Alvaro, I continue to learn from you. Fridel.
Converting Surfaces to Solids The solid is formed from the initial surface, the offset surface, and the lateral surface that connects them. The lateral surface is formed by normals reconstructed from the boundary nodal points of the initial surface. Solid.sm (37kb) downloaded 25 time(s). Solid.pdf (310kb) downloaded 13 time(s).Edited by user 18 April 2022 13:26:12(UTC)
1 user thanked Ber7 for this useful post.
Originally Posted by: Ber7 Converting Surfaces to Solids Hi Fridel. Thanks, great job. In the attached an alternate mesh. Its advantage is that it consists of a single coordinate matrix, so it can be manipulated more easily, with translations, rotations and deformations. As disadvantages, it does not look so good and there may sometimes be a wrong line, but I guess only one. pSolid_alternate_mesh.sm (52kb) downloaded 16 time(s). pSolid_alternate_mesh.pdf (392kb) downloaded 10 time(s).Best regards. Alvaro.
By same token, did you manage constructing Delaunay ? We had no chance in Mathcad. Cheers ... Jean.
Hi. The same but with a different version for the triangular mesh. NorSurAlvaro v2.sm (78kb) downloaded 15 time(s).Best regards.
on 26/10/2021(UTC), on 26/10/2021(UTC)
Examples of meshes with vertices Nodes.sm (50kb) downloaded 16 time(s).Edited by user 18 April 2022 13:50:32(UTC)
2 users thanked Ber7 for this useful post.
