Joined: 25/10/2021(UTC) Posts: 5 Location: California
Trying to plot a variety of functions and nothing shows up in the plots. I have 23 yrs of MathCad experience, but cannot figure out what Smath is looking for to plot three very simple function (See attached file). Additionally, I am not sure why an equation needs vectorized to output the answers in the normal distribution equation. Equation 1 - Normal distribution does not solve as a function until it is vectorized. Why? Equation 2 - f(x):x^3+2*x*sin(0.25) solves without vectorization but will not plot. Why? Equation 3 - f(x):vectorize(1/{σ*sqrt(2*π)}*e^{-1/2*({x-μ}/σ)^2}) solves with vectorization but does not plot (2D or X-Y plot method). Why? Smath - 2D Plots.sm (16kb) downloaded 13 time(s).
Equation 2 also needs vectorized to get the correct results. You don't have to do this in MathCad, why here?
You have defined a vector of values for x. If you use the X-YPLOT plugin you need to change the variable. If instead you use SM native 2D graph then it already works as you expect sergio
First Solution Found This allowed me to plot Normal Distribution Function. augment(x,f(x))
Solved for now. On with the learning experience. Thanks....
Joined: 09/11/2020(UTC) Posts: 17 Location: Cusco Was thanked: 4 time(s) in 2 post(s)
Hi, if you need a quick plot I recommend you use 2D standard plot you can plot functions f(x) directly , if you need a more configurable plot use XY plot but you need to put your data in a special format. Smath - 2D Plots.sm (20kb) downloaded 4 time(s).
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 508 time(s) in 338 post(s)
You don't need to use range() and augment() if you want to plot sections. You can limit it with if-else() or cases(). Regards Edited by user 25 October 2021 21:31:01(UTC)
| Reason: Not specified
Originally Posted by: Paecific Trying to plot a variety of functions and nothing shows up in the plots. I have 23 yrs of MathCad experience, but cannot figure out what Smath is looking for to plot three very simple function (See attached file). Additionally, I am not sure why an equation needs vectorized to output the answers in the normal distribution equation. 1. Show the two other ones on same document for doctoring. 2. Your sigma makes no sense ! 3. BTW, in Samples you should find my Stat Treasury [10 WS] Hard to find such immense Compendium. 4. If you can't download, please let me know Welcome ... Jean. Smath - 2D Plots.sm (18kb) downloaded 12 time(s).
... besides the pure statistical application, you can use to fit data sets [Fréchet US Rainfall ...]
Originally Posted by: Jean Giraud ... besides the pure statistical application, you can use to fit data sets [Fréchet US Rainfall ...] There is about 24 built-in PDF in Smath ... f(x) menu as well as CDF, ICDF
Originally Posted by: Paecific Equation 1 - Normal distribution does not solve as a function until it is vectorized. Why? 1. Discretize the range you want and plot ... No vectorize. 2. Plot scalar directly.
... in most applications inc(Low,High,step,f(#)) is preferred Paecific.sm (15kb) downloaded 7 time(s).
Scalar plots have limited use, mostly confirm the project. Discrete plot can be used for subsequent application/export. 1. Collapsed the algo at top utilities. 2. Use it infinitely in-situ use [range each f(x) at will].
