Offline andrbig77
#1 Posted : 25 October 2021 10:44:22(UTC)
andrbig77
Hello dear Smath - developers,
I ahve a suggestion to option of the picture, that implemented as from Copy/Past in SS-documents.#
Is it possible to program the 'Description' option of the image object as well by expression?
It would be practical, because for images each time must move or place the comment or description of picture separately, if one moves the picture in the document in another place.
A description of the image would be good to add to this implemended object as atributre, like a 'Description' option of the expresion.
Best regards,
Andrey
Online PompelmoTell
#2 Posted : 25 October 2021 12:03:20(UTC)
PompelmoTell
Was thanked: 106 time(s) in 90 post(s)
You can do using the "Image" plugin that accepts the description as a parameter
Offline andrbig77
#3 Posted : 25 October 2021 12:40:59(UTC)
andrbig77
Hello Sergio,
thank you for your tip. This fits for me first.
Best regards,
Andrey
#4 Posted : 25 October 2021 15:50:31(UTC)
Was thanked: 915 time(s) in 743 post(s)
1. an image is created/results from a matrix.
It comes associated with description [top/left/right].
As you move it ► description follows.
2. A picture comes from file, similar to paste a captured image.
You can insert a description to either style.
Select the image and the description with the mouse,
move them wherever ... but they are not associated.
If your description is not subject to change re-capture/paste,
at this point you have a single associated object.
Does it answer your question ? ... Jean.
Offline overlord
#5 Posted : 25 October 2021 19:43:40(UTC)
Turkey
Was thanked: 325 time(s) in 224 post(s)
We can use Image Plugin for description as Sergio suggested.
However I find it beneficial if included Picture Inserts' has description.
I think this is a good request.
Offline Andrey Ivashov
#6 Posted : 26 October 2021 16:39:17(UTC)
Was thanked: 1970 time(s) in 661 post(s)
Agree. It may be convenient to have Description for Picture Region. Will review this possibility.
thanks 3 users thanked Andrey Ivashov for this useful post.
on 27/10/2021(UTC),  on 27/10/2021(UTC),  on 01/11/2021(UTC)
