Offline Ber7
#1 Posted : 10 October 2021 18:20:33(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Offset surface creation
An initial surface is given, given by the "createmesh" function, which forms a
network with nodes.
Dyou want to create an offset surface, offset by an amount h from the initial.
The direction of displacement surface epends on the sign of h.
Sequence of calculation:
1.Restoring the normal from the nodal points of the initial surface and we get
the nodal points of the displaced surface.
2.We connect the resulting node points
The image is built on three-dimensional graphics and can be rotated with the mouse
Edited by user 05 April 2022 17:00:17(UTC)  | Reason: Not specified
thanks 4 users thanked Ber7 for this useful post.
on 11/10/2021(UTC),  on 19/10/2021(UTC),  on 20/10/2021(UTC),  on 21/10/2021(UTC)
Offline Renzorex
#2 Posted : 19 October 2021 17:54:16(UTC)
Renzorex
Rank: Member
Peru
Was thanked: 4 time(s) in 2 post(s)
Thank you, this is helpful.
I have a question, How did you put the icon with the link?
Offline Ber7
#3 Posted : 19 October 2021 19:58:45(UTC)
Ber7
Israel
Hi,Rezorex.I put the icon with the link using the "hyperlink" insert.
Here is a link to an article from Mapleprimes
https://www.mapleprimes.com/post...Parametrized-Surface-For
Offline Razonar
#4 Posted : 20 October 2021 11:22:00(UTC)
Razonar
Uruguay
Hi. Thanis Ber. A slightly different version, using only parametric functions.
Offset surface creation.sm (74kb) downloaded 34 time(s).
Offset surface creation.pdf (918kb) downloaded 17 time(s).
on 20/10/2021(UTC),  on 20/10/2021(UTC)
Offline Ber7
#5 Posted : 20 October 2021 15:45:16(UTC)
Ber7
Israel
Thanks Alvaro, I continue to learn from you.
Fridel.
Offline Ber7
#6 Posted : 20 October 2021 19:31:05(UTC)
Ber7
Israel
Converting Surfaces to Solids
The solid is formed from the initial surface, the offset surface, and the
lateral surface that connects them. The lateral surface is formed by normals
reconstructed from the boundary nodal points of the initial surface.
Solid.sm (37kb) downloaded 25 time(s).
Solid.pdf (310kb) downloaded 13 time(s).
Edited by user 18 April 2022 13:26:12(UTC)  | Reason: Not specified
thanks 1 user thanked Ber7 for this useful post.
on 21/10/2021(UTC)
#7 Posted : 21 October 2021 02:43:17(UTC)
Thanks ► Fridel, Alvaro
I don't have the courage to convert SS 6179 ... OK.
Keep up ... Jean.
Rotate 3D TREASURY_2 Parametric Explorer.sm (34kb) downloaded 12 time(s).
Offline Razonar
#8 Posted : 21 October 2021 10:31:50(UTC)
Razonar
Uruguay
Hi Fridel. Thanks, great job. In the attached an alternate mesh. Its advantage is that it consists of a single coordinate matrix, so it can be manipulated more easily, with translations, rotations and deformations. As disadvantages, it does not look so good and there may sometimes be a wrong line, but I guess only one.
pSolid_alternate_mesh.sm (52kb) downloaded 16 time(s).
pSolid_alternate_mesh.pdf (392kb) downloaded 10 time(s).
on 21/10/2021(UTC)
Offline Ber7
#9 Posted : 24 October 2021 17:47:27(UTC)
Ber7
Israel
Normal to the surface on Rezonar's triangular mesh
NorSurAlvaro.sm (50kb) downloaded 24 time(s).
NorSurAlvaro.pdf (624kb) downloaded 7 time(s).
Edited by user 18 April 2022 13:43:25(UTC)  | Reason: Not specified
on 25/10/2021(UTC)
#10 Posted : 24 October 2021 20:59:18(UTC)
By same token, did you manage constructing Delaunay ?
We had no chance in Mathcad. Cheers ... Jean.
Offline Razonar
#11 Posted : 26 October 2021 04:06:52(UTC)
Razonar
Uruguay
Hi. The same but with a different version for the triangular mesh.
NorSurAlvaro v2.sm (78kb) downloaded 15 time(s).
on 26/10/2021(UTC),  on 26/10/2021(UTC)
Offline Ber7
#12 Posted : 26 October 2021 06:44:19(UTC)
Ber7
Israel
Examples of meshes with vertices
Nodes.sm (50kb) downloaded 16 time(s).
Edited by user 18 April 2022 13:50:32(UTC)  | Reason: Not specified
thanks 2 users thanked Ber7 for this useful post.
Offline Ber7
#13 Posted : 26 October 2021 17:35:04(UTC)
Ber7
Israel
Animation with triangular meshes
pTriMeshAnimat.sm (23kb) downloaded 20 time(s).
Edited by user 18 April 2022 14:27:44(UTC)  | Reason: Not specified
Offline Ber7
#14 Posted : 11 November 2021 12:54:12(UTC)
Ber7
Israel
Creating surface thickness with triangular meshes
thickness.sm (57kb) downloaded 21 time(s).
thickness.pdf (733kb) downloaded 8 time(s).
Edited by user 18 April 2022 14:47:47(UTC)  | Reason: Not specified
