Guide line, not exhaustive... You will have two ■ ... maybe not in your SS version. 1. Fourier symbolic is not saved in SS 6179. 2. The circular algo Φ complains but productive Φ(x):=Φ Not exhaustive of many more otherwise solving. Cheers ... Jean. Symbolic COMPENDIUM Appendix Copy.sm (245kb) downloaded 95 time(s). Symbolic COMPENDIUM Copy.sm (259kb) downloaded 106 time(s).
Joined: 26/09/2021(UTC) Posts: 66 Location: Adelaide Was thanked: 5 time(s) in 3 post(s)
Originally Posted by: Jean Giraud Guide line, not exhaustive... You will have two ■ ... maybe not in your SS version. 1. Fourier symbolic is not saved in SS 6179. 2. The circular algo Φ complains but productive Φ(x):=Φ Not exhaustive of many more otherwise solving. Cheers ... Jean. Symbolic COMPENDIUM Appendix Copy.sm (245kb) downloaded 95 time(s). Symbolic COMPENDIUM Copy.sm (259kb) downloaded 106 time(s). Thank you, these are helpful
Originally Posted by: johnspark Thank you, these are helpful Few more will be added. Thanks for your appreciation ... Jean.
Originally Posted by: johnspark Originally Posted by: Jean Giraud humbling... I have tried to find all the packages available, then activate them, then activate the help command then loosely catalogue the function calls for each package. Hope this is useful. (By the way the large no. of packages open did not cause Smath to crash) Maple Packages.docx (48kb) downloaded 28 time(s). with.zip (1kb) downloaded 11 time(s).
NOT humbling John, I have learned about Maple(length(,)) ... and more from your collaboration ! Now, I'm puzzled with big numbers of so much different length than displayed. I guess modern Pentium displays the best ULP. That would explain so much longer/shorter length ? Eventually, Continued Fraction can be so long not evaluate. May create "critical error"... Smath crash is pending. Critical error was not detrimental Mathcad 11 The last 5 pages long big number is disabled. Take care ... Jean Symbolic COMPENDIUM BigNumber Copy.sm (200kb) downloaded 14 time(s).
John, thanks for the long list of maple commands. Some special functions may be interesting. Mostly, we can reproduce the Mathcad equivalent, except: Float, some Substitute, Z, Fourier transform, Modifiers. Attached/Added Fibonacci, pi Cheers ... Jean. Symbolic COMPENDIUM BigNumber Copy.sm (216kb) downloaded 36 time(s).
Originally Posted by: Jean Giraud John, thanks for the long list of maple commands. Some special functions may be interesting. Mostly, we can reproduce the Mathcad equivalent, except: Float, some Substitute, Z, Fourier transform, Modifiers. Attached/Added Fibonacci, pi Cheers ... Jean. Symbolic COMPENDIUM BigNumber Copy.sm (216kb) downloaded 36 time(s). Excellent Jean! I will also explore some of the commands with the books i have of Maple V. Kind regards... John
Originally Posted by: Jean Giraud Originally Posted by: johnspark Thank you, these are helpful Few more will be added. Thanks for your appreciation ... Jean. Just a little bit more work: MapleBitsandPieces.sm (23kb) downloaded 33 time(s).
Originally Posted by: johnspark Excellent Jean! Thanks for your collaboration. I'm actually refreshing my collection of special functions, as approximated in Smath [Dawson, Whittaker, Polylog, ...] Maybe next days Take care ... Jean
Hello John, This one Whittaker is under construction, one more day ? Smath does not save all Maple plot settings, in pink to reset. As it looks, Whittaker has no alternative than via maple itself. However, Smath is the perfect/profitable companion. I'm the guilty Mathsoft Collab for that one [2008]. Be good down under ... Jean. Maths Special Whittaker APPROXIMATE.sm (160kb) downloaded 17 time(s).
Originally Posted by: Jean Giraud Hello John, This one Whittaker is under construction, one more day ? Smath does not save all Maple plot settings, in pink to reset. As it looks, Whittaker has no alternative than via maple itself. However, Smath is the perfect/profitable companion. I'm the guilty Mathsoft Collab for that one [2008]. Be good down under ... Jean. Maths Special Whittaker APPROXIMATE.sm (160kb) downloaded 17 time(s). Ah good, will look at later. Here is some work on sets and lists, because there are quite a few functions that work with these things. lists and sets bits and pieces.sm (46kb) downloaded 15 time(s).also perhaps some more for the compendium Linalg_Exponential.sm (45kb) downloaded 20 time(s). Linalg_Companion.sm (71kb) downloaded 21 time(s).
Originally Posted by: johnspark Originally Posted by: Jean Giraud Hello John, This one Whittaker is under construction, one more day ? Smath does not save all Maple plot settings, in pink to reset. As it looks, Whittaker has no alternative than via maple itself. However, Smath is the perfect/profitable companion. I'm the guilty Mathsoft Collab for that one [2008]. Be good down under ... Jean. Maths Special Whittaker APPROXIMATE.sm (160kb) downloaded 17 time(s). Ah good, will look at later. Here is some work on sets and lists, because there are quite a few functions that work with these things. lists and sets bits and pieces.sm (46kb) downloaded 15 time(s).also perhaps some more for the compendium Linalg_Exponential.sm (45kb) downloaded 20 time(s). Linalg_Companion.sm (71kb) downloaded 21 time(s). They are beautiful curves Jean on a beautiful day in Adelaide.
Originally Posted by: johnspark They are beautiful curves Jean on a beautiful day in Adelaide. ...as promised a clean version for lecture. You mean: Adelaide is blooming. Here in North-East America is Autumn. Sugar maples turn all sorts of colors ... in the sun !!! Next, will open your attachments ... Jean. Maths Special Whittaker APPROXIMATE Copy.sm (123kb) downloaded 21 time(s).
Originally Posted by: Jean Giraud Originally Posted by: johnspark They are beautiful curves Jean on a beautiful day in Adelaide. ...as promised a clean version for lecture. You mean: Adelaide is blooming. Here in North-East America is Autumn. Sugar maples turn all sorts of colors ... in the sun !!! Next, will open your attachments ... Jean. Maths Special Whittaker APPROXIMATE Copy.sm (123kb) downloaded 21 time(s). I missed some highlighting of comments. lists and sets bits and pieces.sm (47kb) downloaded 15 time(s).
Originally Posted by: johnspark Originally Posted by: Jean Giraud Originally Posted by: johnspark They are beautiful curves Jean on a beautiful day in Adelaide. ...as promised a clean version for lecture. You mean: Adelaide is blooming. Here in North-East America is Autumn. Sugar maples turn all sorts of colors ... in the sun !!! Next, will open your attachments ... Jean. Maths Special Whittaker APPROXIMATE Copy.sm (123kb) downloaded 21 time(s). I missed some highlighting of comments. lists and sets bits and pieces.sm (47kb) downloaded 15 time(s). Jean, just discovered how to get some help info. Please see next file. Using example for help on maple functions.sm (17kb) downloaded 20 time(s).
Originally Posted by: johnspark Jean, just discovered how to get some help info. Please see next file. Thanks John ... added few more. When it comes solving singular square matrix NO CAS will do unless they have PseudoInversecoded as a function in their menu. Have a good day ... Jean Page36 Maple John.sm (201kb) downloaded 28 time(s).
Originally Posted by: Jean Giraud Originally Posted by: johnspark Jean, just discovered how to get some help info. Please see next file. Thanks John ... added few more. When it comes solving singular square matrix NO CAS will do unless they have PseudoInversecoded as a function in their menu. Have a good day ... Jean Page36 Maple John.sm (201kb) downloaded 28 time(s). Thanks for that Jean. More sunny weather this week end. (I like maple syrup the real thing). Something strange happens as i try to load up your file, the first 3/4 of page 1 loads up, then Smath shuts down. I tried your earlier Symbolic COMPENDIUM Big Number, and it was stable. So not sure what is going on.
Originally Posted by: johnspark Thanks for that Jean. More sunny weather this week end. (I like maple syrup the real thing). A fair size sugar maple [50 cm diameter] produces 45 gallons of water after evaporation 1 gallon maple syrup. Accordingly to Grandmas: miraculous for boys as well for girls. Here is the part that you are missing. Cheers ... Jean. Page7 Maple John.sm (156kb) downloaded 27 time(s).
