2 Pages12>
#1 Posted : 17 September 2021 17:58:45(UTC)
Was thanked: 855 time(s) in 685 post(s)
Guide line, not exhaustive...
You will have two ... maybe not in your SS version.
1. Fourier symbolic is not saved in SS 6179.
2. The circular algo Φ complains but productive Φ(x):=Φ
Not exhaustive of many more otherwise solving.
Symbolic COMPENDIUM Appendix Copy.sm (245kb) downloaded 60 time(s).
Symbolic COMPENDIUM Copy.sm (259kb) downloaded 68 time(s).
Offline johnspark
#2 Posted : 29 September 2021 02:57:19(UTC)
johnspark
Rank: Member
Australia
Thank you, these are helpful
#3 Posted : 29 September 2021 14:27:15(UTC)
Few more will be added.
Thanks for your appreciation ... Jean.
#4 Posted : 04 October 2021 02:13:03(UTC)
1. COMPENDIUM ... slightly augmented.
2. COMPENDIUM Appendix ... augmented.
3. COMPENDIUM More ... New
4. COMPENDIUM Diophantine ... New
Symbolic COMPENDIUM AppendixMORE Copy.sm (97kb) downloaded 17 time(s).
Symbolic COMPENDIUM Diophantine Copy.sm (174kb) downloaded 16 time(s).
Symbolic COMPENDIUM Copy.sm (262kb) downloaded 17 time(s).
Symbolic COMPENDIUM Appendix Copy.sm (359kb) downloaded 16 time(s).
For last two days, Smath crashes several times a day.
For months no crash. As well, Forum hard to reach.
Offline johnspark
#5 Posted : 05 October 2021 00:47:10(UTC)
johnspark
Rank: Member
Australia
humbling...
Offline johnspark
#6 Posted : 05 October 2021 01:42:06(UTC)
johnspark
Rank: Member
Australia
humbling...
I have tried to find all the packages available, then activate them, then activate the help command then loosely catalogue the function calls for each package.
Hope this is useful.
(By the way the large no. of packages open did not cause Smath to crash)
Maple Packages.docx (48kb) downloaded 22 time(s). with.zip (1kb) downloaded 9 time(s).
#7 Posted : 05 October 2021 17:02:49(UTC)
NOT humbling John,
I have learned about Maple(length(,)) ... and more from your collaboration !
Now, I'm puzzled with big numbers of so much different length than displayed.
I guess modern Pentium displays the best ULP.
That would explain so much longer/shorter length ?
Eventually, Continued Fraction can be so long not evaluate.
May create "critical error"... Smath crash is pending.
Critical error was not detrimental Mathcad 11
The last 5 pages long big number is disabled.
Take care ... Jean
Symbolic COMPENDIUM BigNumber Copy.sm (200kb) downloaded 6 time(s).
#8 Posted : 05 October 2021 21:16:00(UTC)
John, thanks for the long list of maple commands.
Some special functions may be interesting.
Mostly, we can reproduce the Mathcad equivalent, except:
Float, some Substitute, Z, Fourier transform, Modifiers.
Attached/Added Fibonacci, pi
Symbolic COMPENDIUM BigNumber Copy.sm (216kb) downloaded 20 time(s).
Offline johnspark
#9 Posted : 06 October 2021 10:57:49(UTC)
johnspark
Rank: Member
Australia
Excellent Jean!
I will also explore some of the commands with the books i have of Maple V.
Kind regards...
John
Offline johnspark
#10 Posted : 06 October 2021 14:00:32(UTC)
johnspark
Rank: Member
Australia
Just a little bit more work:
MapleBitsandPieces.sm (23kb) downloaded 20 time(s).
#11 Posted : 06 October 2021 18:50:10(UTC)
Excellent Jean!
Thanks for your collaboration.
I'm actually refreshing my collection of special functions,
as approximated in Smath [Dawson, Whittaker, Polylog, ...]
Maybe next days
Take care ... Jean
#12 Posted : 08 October 2021 03:12:00(UTC)
Hello John,
This one Whittaker is under construction, one more day ?
Smath does not save all Maple plot settings, in pink to reset.
As it looks, Whittaker has no alternative than via maple itself.
However, Smath is the perfect/profitable companion.
I'm the guilty Mathsoft Collab for that one [2008].
Be good down under ... Jean.
Maths Special Whittaker APPROXIMATE.sm (160kb) downloaded 11 time(s).
Offline johnspark
#13 Posted : 08 October 2021 10:42:09(UTC)
johnspark
Rank: Member
Australia
Hello John,
Ah good, will look at later.
Here is some work on sets and lists, because there are quite a few functions that work with these things.
lists and sets bits and pieces.sm (46kb) downloaded 12 time(s).
also perhaps some more for the compendium
Linalg_Exponential.sm (45kb) downloaded 12 time(s).
Linalg_Companion.sm (71kb) downloaded 12 time(s).
Offline johnspark
#14 Posted : 08 October 2021 10:46:41(UTC)
johnspark
Rank: Member
Australia
Hello John,
They are beautiful curves Jean on a beautiful day in Adelaide.
#15 Posted : 08 October 2021 17:01:32(UTC)
...as promised a clean version for lecture.
You mean: Adelaide is blooming.
Here in North-East America is Autumn.
Sugar maples turn all sorts of colors ... in the sun !!!
Next, will open your attachments ... Jean.
Maths Special Whittaker APPROXIMATE Copy.sm (123kb) downloaded 13 time(s).
Offline johnspark
#16 Posted : 09 October 2021 02:53:30(UTC)
johnspark
Rank: Member
Australia
I missed some highlighting of comments.
lists and sets bits and pieces.sm (47kb) downloaded 8 time(s).
Offline johnspark
#17 Posted : 09 October 2021 13:37:54(UTC)
johnspark
Rank: Member
Australia
Jean, just discovered how to get some help info. Please see next file.
Using example for help on maple functions.sm (17kb) downloaded 12 time(s).
#18 Posted : 10 October 2021 15:52:13(UTC)
Thanks John ... added few more.
When it comes solving singular square matrix
NO CAS will do unless they have PseudoInverse
coded as a function in their menu.
Have a good day ... Jean
Page36 Maple John.sm (201kb) downloaded 12 time(s).
Offline johnspark
#19 Posted : 11 October 2021 00:22:38(UTC)
johnspark
Rank: Member
Australia
Thanks for that Jean. More sunny weather this week end. (I like maple syrup the real thing).
Something strange happens as i try to load up your file, the first 3/4 of page 1 loads up, then Smath shuts down. I tried your earlier Symbolic COMPENDIUM Big Number, and it was stable.
So not sure what is going on.
#20 Posted : 11 October 2021 01:36:12(UTC)
A fair size sugar maple [50 cm diameter] produces
45 gallons of water after evaporation 1 gallon maple syrup.
Accordingly to Grandmas: miraculous for boys as well for girls.
Here is the part that you are missing.
Page7 Maple John.sm (156kb) downloaded 9 time(s).
2 Pages12>
