Offline Andrey Ivashov
#1 Posted : 08 September 2021 00:27:00(UTC)
Was thanked: 1972 time(s) in 661 post(s)
New Beta SMath Studio 0.99.7921 is available!
SMath Studio boxCalculation of Gravitation Acceleration exampleExample of animation on the WorksheetExtensions Manager toolOpened math Reference BookSMath Viewer output to Autocad exampleSMath Studio on iOSSMath Studio on iPad
Changes introduced in current build
Improvements
  • SMath Studio splitted to SMath Solver & SMath Writer;
  • Application icons and splash screens updated;
  • Separate set of icons created for supported file formats;
  • *.smw file type introduced for SMath Writer documents;
  • Autodetection of units input implemented in TextRegion.
Corrections
  • Fixed critical issue happens on snippet adding.
Miscellaneous
  • Cursor in MathRegion is now hidden if selection is shown;
  • Refactoring.
Download
Software icon SMathStudioDesktop.0_99_7921.Setup.msi (Date: 2021.09.08; File size: 2.72 MB) - 20326 downloads
Software icon SMathStudioDesktop.0_99_7921.Mono.tar.gz (Date: 2021.09.08; File size: 1.79 MB) - 7463 downloads
thanks 7 users thanked Andrey Ivashov for this useful post.
on 08/09/2021(UTC),  on 08/09/2021(UTC),  on 09/09/2021(UTC),  on 09/09/2021(UTC),  on 09/09/2021(UTC),  on 23/09/2021(UTC),  on 01/03/2022(UTC)
#2 Posted : 08 September 2021 00:54:50(UTC)
Finally, SMath Studio splitted to two different applications: SMath Solver and SMath Writer.
SMath Solver
This is a new name to what was previously called SMath Studio. This application allows user to be focused on calculations.
SMath Writer
Created for work with rich text which includes math. Has Ribbon menu built-in and interface tuned for best experience in documentation and text formatting.
This is a name which gathers Solver and Writer in a single package.
Both applications supports their own file formats: Solver - *.sm, Writer - *.smw. If you have created Documents in SMath Studio using previous program versions please just change an extension manually.
This beta release of SMath Studio package contains Solver/Writer inside.
Please note: Solver has no any significant changes, so one can continue using it in production, but Writer is an alpha version of what I've started to work on. Writer requires more time from me to be polished to have all the same features as currently available in Solver.
Let me know what you think.
Best regards, Andrey Ivashov.
thanks 8 users thanked Andrey Ivashov for this useful post.
on 08/09/2021(UTC),  on 08/09/2021(UTC),  on 08/09/2021(UTC),  on 08/09/2021(UTC),  on 08/09/2021(UTC),  on 09/09/2021(UTC),  on 09/09/2021(UTC),  on 23/09/2021(UTC)
Offline overlord
#3 Posted : 08 September 2021 18:56:39(UTC)
Turkey
Was thanked: 395 time(s) in 262 post(s)
I guess Document Mode is not working on Linux, yet.
At least I couldn't make it run, it even kills the parent terminal.
I didn't encounter any problem with Solver though.
Edited by user 08 September 2021 20:39:31(UTC)  | Reason: Not specified
on 08/09/2021(UTC)
#4 Posted : 08 September 2021 23:47:32(UTC)
Thank you for this info! I will check Writer on Linux.
Offline Yibbou
#5 Posted : 14 September 2021 15:37:21(UTC)
Yibbou
Rank: Member
Senegal
Thank you Andrei for this work.
SMath Writer is a great idea. It can be used to create high quality scientific documents like LateX and other scientific word processors like TeXmacs, Scientific Workplace, LyX and MathCha.
To achieve this goal, consideration should be given to adding environments or things like that that meet scientific typography standards such as:
- title, author, summary, section, sub-section, sub-sub-section environments
- online equations
- equations with automatic numbering
- theorem, lemma, axiom, proof, corollary, remark environments
- exercise, problem, question, solution, answer environments
and so on...
Offline joaobr
#6 Posted : 15 September 2021 21:32:38(UTC)
joaobr
Brazil
Was thanked: 7 time(s) in 6 post(s)
Andrey, plugins EXCEL I/O and Clipboard Region don't seem to work after this update.
Offline ElSid
#7 Posted : 17 September 2021 18:19:17(UTC)
ElSid
Andrey,
Can you explain the separation of the program or a link if you already did (I could not find it). I have not been as active on the form lately. Why "Writer" as a separate program? I know you were playing with something similar in the plugins. Curiosity more than everything. I seem to have missed a lot of NEW features along the way ...
Offline overlord
#8 Posted : 18 September 2021 00:55:43(UTC)
Turkey
Since there is SMath Writer now, document mode is deprecated.
If there is no practical benefit of this option, it can be removed.
This suggestion is just for cosmetic purpose by the way.
No harm shall be done if it stays.
#9 Posted : 22 September 2021 09:10:01(UTC)
I decided to leave this checkbox as is for now because there is theoretical possibility to use different text-region plug-ins as a base of the text rendering engine. Currently we have updated TextRegion which is designed to work in Document Mode, but we also have Writer plug-in developed by Davide which can be updated to support document mode as well.
This means that if Writer plug-in will be ready to be used as a base text rendering engine this checkbox will give us a possibility to change text engines for SMath Writer.
#10 Posted : 22 September 2021 09:44:43(UTC)
Hello.
An actual reason of this separation can be found here: https://en.smath.com/for...20002_Document-mode.aspx
In short words:
Historically SMath Studio is used to perform calculations and then export results (copy/paste, as images or as pdf) to include them in MS Word document or other similar applications. Because: no built-in text formatting (hard to express), all regions are positioned absolutely (hard to compose & update), interface is too different from the popular text processors (stopper for beginners). Now imagine something like MS Word with full-featured embedded math calculation like in SMath Studio. This is why we need SMath Writer.
But I do not want those who like to work with old-style SMath worksheets to fill pain because of migration to the new Document mode. That is why we have SMath Solver.
Personally I think that SMath Writer has a very interesting future when it will be ready as a full-functional text processor with full-featured calculation capabilities.
Important note: 99% of the code is shared between Solver and Writer which means that changes to the Solver will improve Writer and vice versa. So Solver will never be deprecated - we just have two different interfaces now.
on 22/09/2021(UTC),  on 22/09/2021(UTC),  on 22/09/2021(UTC),  on 23/09/2021(UTC)
Offline loha
#11 Posted : 05 October 2021 12:32:04(UTC)
loha
Was thanked: 8 time(s) in 8 post(s)
Impressive!
That is software with ethics. Clap Clap Clap
Offline RamonTavarez
#12 Posted : 15 October 2021 22:11:06(UTC)
RamonTavarez
Rank: Member
Was thanked: 2 time(s) in 1 post(s)
Hi.
Congratulations for this great job!Clapping
Some questions:
1.- Can I install the beta version, the one with solver + writer, into a different directory?
2.- Will this installation affect the actual version in use?
Offline wb.c
#13 Posted : 20 October 2021 18:03:31(UTC)
wb.c
Was thanked: 16 time(s) in 15 post(s)
The save/load feature in Smath Viewer doesn't seem to work very well. Seems like certain values are not saved correctly and some values are saved, but when a file is loaded, the viewer does not update the values in their corresponding input windows.
Offline gurro
#14 Posted : 23 October 2021 06:40:25(UTC)
gurro
Was thanked: 19 time(s) in 7 post(s)
I'm getting some weird results with trigonometric functions. For example:
sin(110'deg) = 0.5547, it should be 0.9396
cos(110'deg) = 0.8381, it should be -0.3420
tan(110'deg) = 1.5366, it should be -2.7475
Could you check what's wrong with those trigonometric functions?
UPDATE: It seems to be a delay in the autocalculation feature. After I pressed "recalculate" several times, the values of those trigonometric functions were updated correctly. Therefore, please ignore this message. Good
I am writing a book on Analytic Geometry with SMath Studio, when I came across the beta version in which SMath is split into Solve and Write and loaded it. Then, I detected this error. Of course, having been converted to SMath Solve, my Analytic Geometry files wouldn't open in SMath Studio. And, so, I got worried that Solve had a fatal flaw with trigonometric functions. But it seems to be a bug with recalculating.
Thanks again, Andrey, for that fabulous program.
Gilberto Urroz
Edited by user 23 October 2021 20:35:11(UTC)  | Reason: Not specified
Offline overlord
#15 Posted : 23 October 2021 07:06:41(UTC)
Turkey
Could you please check your syntax again?
Nothing is wrong when I wrote those functions.
on 23/10/2021(UTC)
Offline Alex M.
#16 Posted : 28 October 2021 16:35:17(UTC)
Alex M.
Was thanked: 123 time(s) in 94 post(s)
Hello Andrey,
Can i do absolutely everything in SmathWriter what I can do in Smath Solver?
My work flow relies heavily on:
Equations
Image Region
EXCEL IO
Line Programming
In a nutshell its math with a sprinkle of text :-)
Thank you!
Offline CBG
#17 Posted : 29 October 2021 00:01:21(UTC)
CBG
Was thanked: 73 time(s) in 54 post(s)
Why can't Smath Writer import files from Smath Solver,
and can it import files from other formats?
Carlos
thanks 1 user thanked CBG for this useful post.
on 24/05/2022(UTC)
