Offline uni
#1 Posted : 31 January 2019 23:48:55(UTC)
uni
Intel ODE Solver Library
SMath Studio compatibility SMath Viewer compatibility mono compatibility Platform Extension page Sources
Functions list: rkm9st(5), mk52lfn(5), mk52lfa(5), rkm9mkn(5), rkm9mka(5).
rkm9st(init, x1, x2, intvls, D) A specialized routine for solving non-stiff and middle-stiff ODE systems using the explicit method, which is based on the 4th order Merson’s method and the 1st order multistage method of up to and including 9 stages with stability control.
mk52lfn(init, x1, x2, intvls, D) A specialized routine for solving stiff ODE systems using the implicit method based on L-stable (5,2)-method with the numerical Jacobi matrix, which is computed by the routine.
mk52lfa(init, x1, x2, intvls, D) A specialized routine for solving stiff ODE systems using the implicit method based on L-stable (5,2)-method with numerical or analytical computation of the Jacobi matrix. The user must provide a routine for this computation.
rkm9mkn(init, x1, x2, intvls, D) A specialized routine for solving ODE systems with a variable or a priori unknown stiffness; automatically chooses the explicit or implicit scheme in every step and computes the numerical Jacobi matrix when necessary.
rkm9mka(init, x1, x2, intvls, D) A specialized routine for solving ODE systems with a variable or a priori unknown stiffness; automatically chooses the explicit or implicit scheme in every step. The user must provide a routine for numerical or analytical computation of the Jacobi matrix.
Arguments:
- init is either a vector of n real initial values, where n is the number of unknowns (or a single scalar initial value, in the case of a single ODE).
- x1 and x2 are real, scalar endpoints of the interval over which the solution to the ODE(s) is evaluated. Initial values in init are the values of the ODE function(s) evaluated at x1.
- intvls is the integer number of discretization intervals used to interpolate the solution function. The number of solution points is the number of intervals + 1.
- D is a vector function of the form D(x,y) specifying the right-hand side of the system
iode.examples.sm (205kb) downloaded 195 time(s).
iode.kinetic1.sm (8kb) downloaded 109 time(s).
iode.kinetic2.sm (15kb) downloaded 89 time(s).
iode.kinetic3.sm (15kb) downloaded 92 time(s).
iode.integrate.sm (11kb) downloaded 102 time(s).
iode.test1.sm (23kb) downloaded 98 time(s).
iode.test2.sm (23kb) downloaded 87 time(s).
iode.Amplitude detector.sm (21kb) downloaded 98 time(s).
Box_models.sm (101kb) downloaded 74 time(s).
iode.examples.pdf (417kb) downloaded 156 time(s).
iode.kinetic1.pdf (75kb) downloaded 87 time(s).
iode.kinetic2.pdf (91kb) downloaded 64 time(s).
iode.kinetic3.pdf (89kb) downloaded 67 time(s).
iode.integrate.pdf (89kb) downloaded 74 time(s).
iode.test1.pdf (117kb) downloaded 71 time(s).
iode.test2.pdf (122kb) downloaded 68 time(s).
iode.Amplitude detector.pdf (148kb) downloaded 71 time(s).
Box_models.pdf (146kb) downloaded 58 time(s).
Documents:
Intel ODE Solver Library Reference Manual (2018).pdf (240kb) downloaded 47 time(s).
See also:
Mathcad Toolbox
DotNumerics
SADEL
Matlab C++ Math Library
OSLO
lsoda
GNU Scientific Library (GSL)
Edited by user 14 July 2022 12:48:44(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
on 01/02/2019(UTC),  on 01/02/2019(UTC),  on 01/02/2019(UTC)
Offline omorr
#2 Posted : 11 July 2021 15:47:22(UTC)
omorr
Serbia
Hmm...even dn_GearsBDF() will go nuts for this example.
Just for the record...
iode.Amplitude detector-1.sm (20kb) downloaded 18 time(s).
EDIT: mk52lfa() and mk52lfn() will also perform well here
Edited by user 11 July 2021 16:00:40(UTC)  | Reason: Not specified
#3 Posted : 11 July 2021 16:15:24(UTC)
From recollection,NONE ODE solve that one.
ODE rkfixed Pulse Pitfall.sm (38kb) downloaded 25 time(s).
Offline uni
#4 Posted : 11 July 2021 18:20:01(UTC)
uni
A little help is needed here
Russia ☭ forever
on 11/07/2021(UTC)
Offline omorr
#5 Posted : 11 July 2021 21:59:35(UTC)
omorr
Serbia
I should have guessed that Good . Thank you.
Offline uni
#6 Posted : 09 December 2021 22:12:56(UTC)
uni
Plugin updated.
Changes:
- added support for ODE systems in mathematical form;
- refactored.
Russia ☭ forever
on 09/12/2021(UTC),  on 10/12/2021(UTC)
Offline uni
#7 Posted : 20 December 2021 22:17:42(UTC)
uni
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
Russia ☭ forever
