10 Pages«<34567>»
Offline uni
#81 Posted : 06 December 2018 11:36:46(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
Updated. Now you can also use simple form for D() function definition.
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
thanks 4 users thanked uni for this useful post.
on 06/12/2018(UTC),  on 06/12/2018(UTC),  on 06/12/2018(UTC),  on 06/12/2018(UTC)
Offline uni
#82 Posted : 06 December 2018 12:01:27(UTC)
uni
But x in D(t,x) is vector.
Offline uni
#83 Posted : 24 December 2018 11:33:39(UTC)
uni
Updated.
Now x in simple D(t,x) definition must be a scalar.
iode.examples.sm (205kb) downloaded 207 time(s).
iode.kinetic1.sm (8kb) downloaded 119 time(s).
iode.kinetic2.sm (15kb) downloaded 94 time(s).
iode.kinetic3.sm (15kb) downloaded 99 time(s).
iode.integrate.sm (11kb) downloaded 108 time(s).
iode.test1.sm (23kb) downloaded 103 time(s).
iode.test2.sm (23kb) downloaded 95 time(s).
iode.Amplitude detector.sm (21kb) downloaded 108 time(s).
iode.examples.pdf (417kb) downloaded 173 time(s).
iode.kinetic1.pdf (75kb) downloaded 94 time(s).
iode.kinetic2.pdf (91kb) downloaded 72 time(s).
iode.kinetic3.pdf (89kb) downloaded 74 time(s).
iode.integrate.pdf (89kb) downloaded 82 time(s).
iode.test1.pdf (117kb) downloaded 78 time(s).
iode.test2.pdf (122kb) downloaded 73 time(s).
iode.Amplitude detector.pdf (148kb) downloaded 79 time(s).
Edited by user 25 December 2018 20:16:14(UTC)  | Reason: Not specified
on 24/12/2018(UTC),  on 24/12/2018(UTC),  on 24/12/2018(UTC),  on 24/12/2018(UTC)
Offline uni
#84 Posted : 16 January 2019 12:05:17(UTC)
uni
Updated. Rkadapt() fixed.
on 16/01/2019(UTC),  on 16/01/2019(UTC),  on 16/01/2019(UTC)
Offline uni
#85 Posted : 31 January 2019 23:43:52(UTC)
uni
Updated ( >= SMath Studio 0.99.6970).
Changes:
- divided into two plugins (the second one is Intel ODE Solver Library);
- version changed (0.2.x.x);
- refactored.
Edited by user 01 February 2019 04:01:14(UTC)  | Reason: Not specified
Offline uni
#86 Posted : 11 February 2019 15:36:21(UTC)
uni
Some news.
It's hard but I want to realize a general solution for some types of tasks. Specially for this I need more powerful symbolic engine inside SMath. Therefore I made symcs project. I hope that we can use this solution in other similar cases.
That's why I split the plugin.
on 11/02/2019(UTC),  on 11/02/2019(UTC)
Offline omorr
#87 Posted : 11 February 2019 17:01:58(UTC)
omorr
Serbia
Was thanked: 319 time(s) in 268 post(s)
I think that most of the Mathcad users know what you intend to do and I really appreciate that Good
#88 Posted : 11 February 2019 21:52:40(UTC)
Viacheslav is an ancient Mathsoft visitor.
I still have a document from Him ... 2D Implicit plot.
Is possible to code 1/1 Mathcad Given/ODEsolve ?
Offline uni
#89 Posted : 11 February 2019 22:35:16(UTC)
uni
No, Jean, 1/1 - not possible. Now they have two different realisations: MC11-MC15 and Prime. But I can do something similar. Plugin can implicity collect information about available ode solvers and you can choose them in the context menu.
on 12/02/2019(UTC)
#90 Posted : 11 February 2019 22:52:19(UTC)
I can see you "busy" ! Gorgeous context menu.
What is that Smath Community doing: Building Cathedrals/Pyramids ?
You mean: Mathcad Prime "cluster fuck" in US appreciation from Collab.
Offline Razonar
#91 Posted : 11 July 2021 06:23:42(UTC)
Razonar
Uruguay
Was thanked: 989 time(s) in 618 post(s)
Some news.
Hi uni. It is possible to enable a clone of that component for return only the expressions inside? For example, the set of the equations
Also, it is possible too to add the option for mark with a round box the area?
Offline uni
#92 Posted : 11 July 2021 07:20:49(UTC)
uni
Yes, it is possible.
on 11/07/2021(UTC)
Offline uni
#93 Posted : 26 November 2021 06:11:56(UTC)
uni
Coming soon, but for now as an experiment.
on 26/11/2021(UTC),  on 29/11/2021(UTC)
Offline uni
#94 Posted : 28 November 2021 21:47:31(UTC)
uni
I have verified that linear interpolation is used, which is described in the manual.
I changed the interpolation method to linear and also changed the notation of the derivative by analogy ( "`" ).
on 29/11/2021(UTC)
Offline uni
#95 Posted : 28 November 2021 22:42:18(UTC)
uni
Prime symbol looks much better (′). I think it's better to use it.
Offline uni
#96 Posted : 29 November 2021 00:49:59(UTC)
uni
I was wrong. Linear interpolation and linear spline interpolation are different things. I will try to find the formulas that are used in these functions.
Offline uni
#97 Posted : 29 November 2021 08:43:07(UTC)
uni
A simple test that shows the interpolation method used by the ODE solver. Obviously, the lspline() function is used.
Odesolve() with rkfixed method (Mathcad 15).
Odesolve interpolation test.mcd.zip (9kb) downloaded 8 time(s).
The same for Mathcad Prime 7.0 (Adams method used).
Edited by user 29 November 2021 09:15:42(UTC)  | Reason: Not specified
on 29/11/2021(UTC)
Offline uni
#98 Posted : 30 November 2021 02:31:00(UTC)
uni
Ok, I found a bug in rkfixed() and finally figured out the difference between interpolation functions. In the picture below, I repeated part of the calculations from Mathcad. As you can see, to interpolate the numerical solution of the ODE, a cubic spline is used, linear at the end points.
Bugs will be fixed when the build server starts working.
Links:
1. Cubic spline
2. Cubic Spline Interpolation
Cubic spline interpolation using Mathcad (2009).pdf (257kb) downloaded 40 time(s).
Edited by user 30 November 2021 04:37:19(UTC)  | Reason: Not specified
#99 Posted : 30 November 2021 03:30:48(UTC)
Thanks Viacheslav ... superb demo.
BTW, I was wrong ODEsolve is lspline MCD 11.
Years ago, Tom G. had exposed the different deficiencies
wrt to each l_p_c cubic spline ... Matlab as well.
So, your next headache is to figure the best solver from
the huge Smath library [17], Mathcad stiff is Radau MCD 2001i, 11.
Offline overlord
#100 Posted : 30 November 2021 07:28:14(UTC)
Turkey
Was thanked: 548 time(s) in 368 post(s)
This day should be accepted as a milestone. We have to celebrate this day annually.
There should be carnivals, fireworks should enlighten the night.
10 Pages«<34567>»
