SMath Studio Forum
Feature Requests
Functions as arguments of other functions
in my recent calculations I needed to have a function that takes two funtions as parameters and calculates some values. Something like:
k_f(s;c)=s(1)*c(8)
k_f(sin; cos)=
Trying this in SMath Studio unfortunately failed.
Is is possible to implement such a thing in SMath Studio?
Yours,
Pawel Wierzba
Yes it is possible, see the attached image |
Thank you very much. Indeed, it works, even with functions with more arguments than one.
Sorry for asking a question about something that has already been implemented.
Make it infinite algo style.
Thank you for the advice. Fortunately, standard way of defining functions is well known to me. Unfortunately, I had to pass functions as arguments, rather than define them the "standard way". I had several functions and some coefficients to be calculated, based on them. Something like the example below. If done the standard way, it would involve a LOT of writing. Edited by user 07 July 2021 16:20:06(UTC)
| Reason: could not get the image to display
Originally Posted by: pwi Unfortunately, I had to pass functions as arguments, rather than define them the "standard way". I had several functions and some coefficients to be calculated, based on them. Something like the example below. Attach the document for understanding that mystic doing.
Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: Davide Carpi Yes it is possible, see the attached image Beautiful! I wonder why Jean is not so enthousiastic?
... should have been posted ~ 2 hours ago.
Joined: 10/12/2009(UTC) Posts: 246 Location: Cali, Colombia Was thanked: 85 time(s) in 65 post(s)
Originally Posted by: pwi Thank you for the advice. Fortunately, standard way of defining functions is well known to me. Unfortunately, I had to pass functions as arguments, rather than define them the "standard way". I had several functions and some coefficients to be calculated, based on them. Something like the example below. If done the standard way, it would involve a LOT of writing. Great! SMath has that awesome characteristic, so you can use that "standard way" for defining functions. Good luck with your job!
Originally Posted by: pwi ... I had several functions and some coefficients to be calculated, based on them. Something like the example below. ... If done the standard way, it would involve a LOT of writing. Hi. You can try a for loop with something like this in the body Best regards. Alvaro.
Originally Posted by: pwi If done the standard way, it would involve a LOT of writing. Make it algo style as exemplified. At this point, you are missing a link ... what link ? Before integration, you must plot the integrand. That will avoid the Simpson integrator to result scrap. Visit/search 'Samples' for more integrators [Adaptive, Romberg].
... Smath is a CAS, an advanced CAS i.e: like competitive CAS, Smath is not a click_click_done.
Interesting solution, promising to be very useful. I wonder if it could be done with other functions. It would really shorten a lot of thing if was possible. Especially with external plugins function calls. Regards
Originally Posted by: Jean Giraud At this point, you are missing a link ... what link ? Before integration, you must plot the integrand. That will avoid the Simpson integrator to result scrap. Visit/search 'Samples' for more integrators [Adaptive, Romberg].
Originally Posted by: Jean Giraud ... Smath is a CAS, an advanced CAS i.e: like competitive CAS, Smath is not a click_click_done.
Thank you for help, especially the comment about potential problems with the integrator and illustrative examples. Starting to study other integrators [Adaptive, Romberg], as advised. I wish I could click a few "THANK" buttons for help, but on my two browsers (Opera and Edge) they simply generate an error message.
Originally Posted by: pwi Thank you for help, especially the comment about potential problems with the integrator and illustrative examples. I posted the wrong image ... that's the right one. Don't drop dead by how far simple integration can fly in the blue !
Originally Posted by: pwi Thank you for help, especially the comment about potential problems with the integrator and illustrative examples. The 'thanks' button' never worked. 1. The previous image as *,sm 2. My Integration tool box. Please, don't hesitate for + ... Jean Integral 000000000000 vectorsf(j,k,a,b).sm (14kb) downloaded 13 time(s). Integral 00000000 MASTER ToolBox.sm (478kb) downloaded 12 time(s).
Looks like line() mysteriously solve the issue. I have come across similar to this behavior before. Regards Edited by user 08 July 2021 22:27:22(UTC)
| Reason: Not specified
Originally Posted by: overlord Looks like line() mysteriously solve the issue. ... Hi. For help understanding what's happen: that behavior is similar to the SetDelayed in Wolfram Mathematica language: https://www.wolfram.com/...-and-delayed-values.html Best regards. Alvaro.
SMath Studio Forum
Feature Requests
