2 Pages12>
Offline overlord
#1 Posted : 07 June 2021 23:07:11(UTC)
Turkey
Gamma function,
Lower Incomplete Gamma function,
Upper Incomplete Gamma function,
with almost instant speed and high precision.
gamma.sm (35kb) downloaded 12 time(s). <---- least accurate
gamma_r2.sm (12kb) downloaded 14 time(s).
gamma_r3.sm (12kb) downloaded 10 time(s).
gamma_r4.sm (14kb) downloaded 12 time(s).
gamma_r5.sm (12kb) downloaded 14 time(s).
gamma_r6.sm (18kb) downloaded 6 time(s).
gamma_r7.sm (29kb) downloaded 13 time(s).
gamma_r8.sm (32kb) downloaded 10 time(s).
gamma_r9.sm (37kb) downloaded 18 time(s). <----imaginary numbers added
Edited by user 13 June 2021 07:28:04(UTC)  | Reason: Not specified
Offline overlord
#2 Posted : 08 June 2021 20:57:24(UTC)
Turkey
Thanks, will explore.
Main limitation is smath floating points.
Python gives much more accurate results with same algorithms.
Try the other one for gamma calculation.
Edited by user 08 June 2021 21:10:53(UTC)  | Reason: Not specified
#3 Posted : 09 June 2021 01:21:30(UTC)
round(■ ,■ ,■ ) ... undefined
H.T.Davis [Abramowitz & Stegun] -> very objective.
In the mean time I'm finishing two superb applications examples
... examples based on your first Gamma(a,x) version,
Thanks for that one, gorgeous ... Jean.
gamma_r2 [H.T.Davis].sm (58kb) downloaded 11 time(s).
Offline overlord
#4 Posted : 09 June 2021 01:55:03(UTC)
Turkey
Undefined because you have an old version of smath.
Round(#,#,#) is not parsed through your program.
Use trunc() instead. And with more constants.
Offline overlord
#5 Posted : 09 June 2021 02:34:03(UTC)
Turkey
Technically this should be the most accurate one.
Edited by user 09 June 2021 04:54:04(UTC)  | Reason: Not specified
#6 Posted : 09 June 2021 03:34:29(UTC)
As offered ... two applications.
Now, the old Rooster is going in the bed marmite ... Jean.
gamma(a,x) Applications.sm (24kb) downloaded 14 time(s).
Offline overlord
#7 Posted : 09 June 2021 04:08:00(UTC)
Turkey
I suggest you to change gamma function with gamma_r4.
It is 3 times faster and much more precise.
#8 Posted : 09 June 2021 19:46:58(UTC)
Thanks for gamma_r4
1. NO gain timing both applications
2. gamma_r4 Does NOT solve ... first version solves.
Offline overlord
#9 Posted : 09 June 2021 20:06:13(UTC)
Turkey
Thanks for gamma_r4
Speed may differ between linux and windows.
gamma_r4 is faster 3 times in linux.
What do you mean by 'does not solve'?
How should this page look like?
gamma(a,x) Applications.pdf (126kb) downloaded 10 time(s).
#10 Posted : 09 June 2021 20:19:23(UTC)
Offline overlord
#11 Posted : 09 June 2021 20:36:55(UTC)
Turkey
I think this is the same bug I mentioned earlier. Some functions don't like to be in another function.
Solution was to put a line but that method is not working in this case.
@Andrey or @Davide has to look at this.
Offline overlord
#12 Posted : 09 June 2021 22:03:46(UTC)
Turkey
Latest version is faster about 4 times.
Offline overlord
#13 Posted : 09 June 2021 22:23:05(UTC)
Turkey
It solves, not with conventional methods.
They tend to give errors, not gamma_r4's fault.
alglib is the answer, it usually gives result.
Edited by user 10 June 2021 03:17:02(UTC)  | Reason: Not specified
#14 Posted : 10 June 2021 03:50:11(UTC)
Good rescue ... OK.
As it looks, sr4 resides at the kernel level.
Thus, it plots but not solve(,,,,)
because not scalar wrt 'x' for the solve bloc.
Offline overlord
#15 Posted : 10 June 2021 04:06:36(UTC)
Turkey
Good rescue ... OK.
Nope, not related with kernel, blocks, scalability, etc.
It is probably a bug of solve(), roots(), FindRoot().
Gamma Function has nothing to do with it.
Even very simple ones suffer from this too.
Check below.
Edited by user 10 June 2021 04:26:33(UTC)  | Reason: Not specified
Offline overlord
#16 Posted : 10 June 2021 04:22:56(UTC)
Turkey
It seems solve(), roots(), FindRoot() doesn't like if statements.
I have updated the bugreport in Bugs and Problems > solve() bug.
Using cases() seems to solve the issue. Check the sample below.
Edited by user 10 June 2021 04:41:57(UTC)  | Reason: Not specified
#17 Posted : 10 June 2021 17:16:16(UTC)
Doctored version confirmed.
Offline overlord
#18 Posted : 11 June 2021 04:56:05(UTC)
Turkey
gamma_r5 has a serious flaw. It can't calculate a<0.5.
My bad, should check it carefully. Corrected page is below.
Refactored so it is faster, also get rid of recursive call.
I had to get around some smath bugs with line, if/cases, recursive.
Correlation of them gives weird errors.
Hope this version solves all issues and be the last one.
I know I have flooded this topic too much, sorry for inconvenience.
PS: gamma for negative non-integer values support corrected
Edited by user 11 June 2021 08:43:39(UTC)  | Reason: Not specified
#19 Posted : 11 June 2021 16:16:24(UTC)
You may not like my verdicts:
1. on-line faster has no or little interest, neither up ^307.
2. Your first version runs fine the two applications.
3. The champion is the long time ago published Alvaro Γ(x)
4. for these two applications [2] & [3] are same
but => [3] drops timing [2] from 24 s down 18 s
The drop in timing results from Alvaro Γ(x)
running at the kernel scalar level.
BTW, my original H.T. Davis sanity Mathcad & Alvaro Γ(x)
By same token, thanks Alvaro for your Γ(x).
Maths Special Gamma(a,x) Incomplete APPLICATIONS [Alvaro G(x)].sm (27kb) downloaded 11 time(s).
Offline overlord
#20 Posted : 11 June 2021 18:45:20(UTC)
Turkey
1. 10^308 feature added for fully use IEEE capability.
2. gamma_r6 runs every possible applications.
3. don't want to disrespect, Alvaro's is a single line awesome code.
4. mine has same algorithm with more features, with faster calculation.
4. gamma_r6 is faster from gamma_r2 and gamma_r3 while trying to have all feature.
gamma_r6_app.sm (34kb) downloaded 12 time(s).
Here is a side by side comparison with Alvaro's algorithm with mine.
On linux, gamma_r6 is faster about 20 percent.
Similar Topics
Incomplete Gamma Functions (Bugs & Problems)
by overlord 06/06/2021 14:45:29(UTC)
2 Pages12>
