Joined: 25/10/2017(UTC) Posts: 158 Was thanked: 7 time(s) in 5 post(s)
Hi!
When I want to plot text/strings, I add mat(1;5) to my graph. Strings usually has top left justification.
Is it possible to set justification as the sixth element of the matrix?
Originally Posted by: Jean Giraud Originally Posted by: hanskl Is it possible to set justification as the sixth element of the matrix ? No need AFAIK. Hello Jean, Take a look at the attached image. I want C to have top right justification, and B bottom right. I could just offset the coordinates for a quick fix, but when I change the zoom level that will not work. Best regards,
Originally Posted by: hanskl Hello Jean, Take a look at the attached image. I want C to have top right justification, and B bottom right. I could just offset the coordinates for a quick fix, but when I change the zoom level that will not work. Best regards, For fixed rotation, you can get inspired from the attached. Smath is not a CAD, but from little it does so much. This W Truss originates from Ioan [SS 5346 ?] End result from multiple collaboration [Alyles, Carlos, Jean]. Next from you: *.sm document. Cheers ... Jean Utilities XY [Draw Truss Labels ZOOMED mode].sm (27kb) downloaded 38 time(s).
Originally Posted by: Jean Giraud For fixed rotation, you can get inspired from the attached. Smath is not a CAD, but from little it does so much. This W Truss originates from Ioan [SS 5346 ?] End result from multiple collaboration [Alyles, Carlos, Jean]. Next from you: *.sm document. Cheers ... Jean
Jean, Your example seems to work well when zooming out. When zooming in the labels starts getting further appart fram the drawing. I was hoping maybe this was something the developers could incorporate in an upcoming release. Best regards,
Originally Posted by: Jean Giraud You are asking a CAD functionality that does not have much interest. This triangle has some curious relationship. Most probably each figure will have more surprises + rotation. What is the interest of zooming a triangle ? That one, you can zoom/rotate at will for [Area/Perimeter/CG] [Area/Perimeter/CG] for any figure of XY vertices. Where are you in your design ? ... Jean.
Jean, I was just puzzling around with trigonometry. I never seem to remember the trigonometric relationships, so rather than googling 'trigonometric functions' all the time, I figured it would be fun to try to make something in SMath. Attached is the "project" I was fooling around with. I tried to plot an angle (L) in all the corners that were 90°, but because of the significant round-off errors I skipped that part. Best regards, Trigonometry.sm (40kb) downloaded 22 time(s).
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 508 time(s) in 338 post(s)
Originally Posted by: hanskl Attached is the "project" I was fooling around with. I tried to plot an angle (L) in all the corners that were 90°, but because of the significant round-off errors I skipped that part.
This is a very good example. Nice job, kudos to your project. Regards
Originally Posted by: overlord This is a very good example. Nice job, kudos to your project.
Thank you, far too kind! Best regards,
Originally Posted by: Jean Giraud Your zoomed triangle is pure success from brute force refactoring. Sorry for the 5 hours power failure from unusual strong wind. Thanks for this nice project ... Jean Trigonometry.sm (50kb) downloaded 12 time(s). I guess zooming in and out on the plot could be avoided by resizing the triangle within the plot.. and that way shifting/aligning the labels manually will work just fine. Best regards,
Last brick in the wall for that one. Medians [med] approximate, not from calculations. More maths added for convenience. Thanks for that superb Classroom ... Jean Utilities XY [Draw ZOOM Triangle].sm (21kb) downloaded 19 time(s).
Originally Posted by: Jean Giraud Last brick in the wall for that one. Medians [med] approximate, not from calculations. More maths added for convenience. Thanks for that superb Classroom ... Jean Jean, Very interesting! Thanks for the insight. Best regards,
