Offline Renzorex
#1 Posted : 25 May 2021 21:56:39(UTC)
Renzorex
Rank: Member
Peru
Was thanked: 4 time(s) in 2 post(s)
Hi, I want to set my label to vertical dimension but when I rotate the text it gets distorted, please how can I fix it?
Offline TopUser2000
#2 Posted : 26 February 2023 19:23:18(UTC)
TopUser2000
Rank: Member
Belarus
Hello.
Tell me, please, if I have two points, then how can I plot a graph between them? According to my assignment, I need to build several graphs, but I do not know how to do it in the program. I have done the calculations, but for the rest I ask for help from local experts. I attach a sheet with the task and a file with calculations (sorry, that's in Russian). Can someone help me figure it out here?
DPT s NV.sm (20kb) downloaded 4 time(s).
Mekhanicheskie kharakteristiki DPT s nezavisimym vozbuzhdeniem.docx (96kb) downloaded 6 time(s).
Offline overlord
#3 Posted : 26 February 2023 20:31:43(UTC)
Turkey
I made a sample with two different plots.
You can use them by changing variables.
DPT_NV plot.sm (12kb) downloaded 8 time(s).
on 26/02/2023(UTC)
#4 Posted : 26 February 2023 23:33:26(UTC)
TwoPointsPlot.sm (12kb) downloaded 4 time(s).
on 27/02/2023(UTC)
#5 Posted : 27 February 2023 03:09:46(UTC)
on 27/02/2023(UTC)
Offline overlord
#6 Posted : 27 February 2023 03:21:08(UTC)
Turkey
You can also use line and polyline commands for plot.
They work only in XYPlot, but sometimes they make everything easy.
There is also a setprop() function.
It can change format of your XYPlot automatically.
Search setprop() in forum for further information.
DPT_NV plot.sm (21kb) downloaded 13 time(s).
on 27/02/2023(UTC)
Offline TopUser2000
#7 Posted : 27 February 2023 10:54:30(UTC)
TopUser2000
Rank: Member
Belarus
Thanks to everyone. The first answer helped me enough)
One more question:
if I have a graph (attached file), then how do I mark the points along which it passes?
I tried: vector M(s) ω(s) "." 15 "blue"
but the application immediately crashes.
AD.sm (21kb) downloaded 5 time(s).
Is it possible to make the graph automatically scale to the new values?
And does someone use android version of Smath (from this site)? I can't edit any of these files there.
Edited by user 27 February 2023 11:02:44(UTC)  | Reason: Not specified
#8 Posted : 27 February 2023 14:47:08(UTC)
Originally Posted by: TopUser2000 Go to Quoted Post
If I have a graph (attached file), then how do I mark the points along which it passes?
As in the attached.
Instead of re-scaling the same graph, plots all new graph on the same plot.
You will scale to accommodate for the larger graph.
AD Plot Points.sm (105kb) downloaded 5 time(s).
on 27/02/2023(UTC)
Offline TopUser2000
#9 Posted : 27 February 2023 17:29:43(UTC)
TopUser2000
Rank: Member
Belarus
I'm afraid it's too difficult for me)
Is there any simple way to add the pass points and autoscale a graph?
#10 Posted : 27 February 2023 19:38:10(UTC)
Some Smath versions decided that opening in other versions will be black.
1. Open this document
2. If black, select by groups, click on background white
3. Make the all document as per 2. directive
4. at this point, you have recovered my original
5. Plot points and more advanced.
AD Plot Points TopUser2000.sm (88kb) downloaded 3 time(s).
on 27/02/2023(UTC)
Offline overlord
#11 Posted : 27 February 2023 19:57:37(UTC)
Turkey
You can use this, XYPlot region is suitable.
One custom function to plot everything.
It also autoscale the graph.
AD.sm (29kb) downloaded 8 time(s).
on 27/02/2023(UTC)
Offline TopUser2000
#12 Posted : 27 February 2023 21:09:51(UTC)
TopUser2000
Rank: Member
Belarus
Oh... What literature can I read about making plots in?
Offline uni
#13 Posted : 27 February 2023 22:42:23(UTC)
uni
Нужно в YouTube в поиске набрать: SMath Studio tutorial и применить фильтр плейлистов. Там найдётся около 4-5 видеокурсов. Можно отфильтровать по продолжительности.
Также каждый дополнительный компонент (расширение) имеет здесь на форуме свою тему, где в начале обычно приложены примеры типового использования.
Edited by user 27 February 2023 22:44:31(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
Offline TopUser2000
#14 Posted : 27 February 2023 22:47:58(UTC)
TopUser2000
Rank: Member
Belarus
Тут вроде самый необходимый минимум мне описали, но, казалось бы, простую задачу, когда на графике надо проставить точки, тут описывают каким-то сложным для меня способом. Причем, среди кучи текста непонятно, что именно отвечает за эти точки.
Да и с автомасштабом графика я так и не понял.
Offline uni
#15 Posted : 27 February 2023 22:51:27(UTC)
uni
По точкам нужно просто посмотреть примеры использования графиков.
setprop() - функция устанавливает свойство компонента. Возвращает 1, если свойство найдено и успешно установлено, иначе 0.
Она ищет компоненты на всех листах с указанным именем и меняет указанное свойство. Набор доступных для изменения свойств ограничен.
Точки также можно включить в свойствах кривой. ПКМ на компоненте и выбрать настройки, далее зайти в свойства кривой и там выбрать тип маркеров вместо пустого.
В компоненте XYPlot нет автомасштаба, поэтому пока так.
Edited by user 27 February 2023 22:55:23(UTC)  | Reason: Not specified
Russia ☭ forever
#16 Posted : 27 February 2023 22:51:55(UTC)
Oh... What literature can I read about making plots in ?
Download first document @ post 10 ... let's see if it works ?
Offline overlord
#17 Posted : 27 February 2023 23:04:02(UTC)
Turkey
This is what uni cleverly mentioned.
Which I totally forgot its existence.
The plot
Traces
Styles
thanks 2 users thanked overlord for this useful post.
on 27/02/2023(UTC),  on 02/03/2023(UTC)
Offline TopUser2000
#18 Posted : 02 March 2023 10:32:18(UTC)
TopUser2000
Rank: Member
Belarus
Now it works but anyway this way is too difficult for me
#19 Posted : 02 March 2023 19:46:49(UTC)
Glad it works from doctoring the black.
Nothing is too difficult for Smath Community to which you now belongs.
Your very first document, populate more for standard reference project.
If you just have some experimental points you can't escape Hermite.
It was used long time ago for Mollier.
Hermite cubic interpolation is more ancient than my Mathcad 8 Pro.
Take care ... Jean
on 05/03/2023(UTC)
