SMath Studio Forum
Bugs & Problems
X-Y Plot and ZedGraph do not plot constant values
Joined: 29/09/2016(UTC) Posts: 2 Location: Красноярск Was thanked: 4 time(s) in 2 post(s)
SMath Studio version: 0.99.7808 and previous stable release. OS: Windows XP, Windows 7. The plug-ins X-Y Plot and ZedGraph do not plot constant values. Pop-up error message: "The specified argument is outside the range of valid values. Parameter Name: arrayIndex" Constant value do not plotted in both cases: as a number or as a variable name. The only way to plot it is to define constant function y(x):=const and then plot the y(x). In the earlier releases of SMath Studio both plug-ins worked similar to the standard 2D plot. [img=https://disk.yandex.ru/i/c3WKCU0XwWp3hg]Example of error[/img]
2 users thanked pavel_n for this useful post.
on 24/05/2021(UTC), on 24/05/2021(UTC)
Your version has to be doctored or use as previous versions.
It is not about a version, but about the settings. Issue is reproduced and will be fixed asap.
Fixed. Fix will be a part of the next release.
SMath Studio Forum
Bugs & Problems
