SMath Studio Forum
Bugs & Problems
Variable not recognized when dividing
Joined: 17/05/2021(UTC) Posts: 19 Was thanked: 5 time(s) in 4 post(s)
If I make a division where a variable is the denominator sometimes the variable is not recognized. See below, in the last row the variable is not recognized. I have discovered that the bug depends on that the variable must have a subscript and also how I enter the equal sign. If I enter the equal sign while the marker is still positioned next to the denominator then everything is alright. But if I press right arrow and then equal sign the variable is not recognized.
1 user thanked gntech for this useful post.
Thanks for taking the time to answer. Are you referring to SMath Studio version 6179? I forgot to mention in my first post but I am using the recently released stable version 0.99.7808
The exact key sequence to reproduce the bug is as follows:
A,L:10(Enter) 1/A,Tab(RightArrow)=
The following also produces the bug:
A,L:10(Enter) 1/A,L(RightArrow)=
Please try those sequences
Originally Posted by: Jean Giraud ... for users of your latest SS version ? No, I meant, to see if you can confirm/reproduce the bug on another system. Since you seem to say that you could not reproduce the bug on your system. Or have I understood something wrong? Originally Posted by: Jean Giraud SS 6179 Does NOT reproduce your bug. Edit: Or do you mean that you have triaged the bug to have appeared after SS 6179 ?
Originally Posted by: gntech The exact key sequence to reproduce the bug is as follows:
Thank you very much! Issue is reproduced. Will fix it asap. Best regards, Andrey Ivashov.
Thank you very much, this is most likely the cause we were looking for here. |
Thanks Andrey and Davide, I am very happy to have been able to help you on this issue I have done some more testing and found that the key elements to reproduce the bug is that the last variable entered has a subscript and that "RightArrow" is pressed before pressing equal sign. So for example: A.L:3 3*A.L(RightArrow)= 2^A.L(RightArrow)=
Issue is fixed. Will be included into the next release.
Thank you!
SMath Studio Forum
Bugs & Problems
