Offline gntech
#1 Posted : 18 May 2021 12:31:31(UTC)
gntech
Rank: Member
Sweden
Was thanked: 5 time(s) in 4 post(s)
If I make a division where a variable is the denominator sometimes the variable is not recognized. See below, in the last row the variable is not recognized.
I have discovered that the bug depends on that the variable must have a subscript and also how I enter the equal sign.
If I enter the equal sign while the marker is still positioned next to the denominator then everything is alright.
But if I press right arrow and then equal sign the variable is not recognized.
thanks 1 user thanked gntech for this useful post.
on 18/05/2021(UTC)
Offline gntech
#2 Posted : 18 May 2021 17:41:31(UTC)
gntech
Rank: Member
Sweden
Thanks for taking the time to answer. Are you referring to SMath Studio version 6179? I forgot to mention in my first post but I am using the recently released stable version 0.99.7808
The exact key sequence to reproduce the bug is as follows:
A,L:10(Enter)
1/A,Tab(RightArrow)=
The following also produces the bug:
A,L:10(Enter)
1/A,L(RightArrow)=
Please try those sequences
Offline gntech
#3 Posted : 18 May 2021 18:00:06(UTC)
gntech
Rank: Member
Sweden
... for users of your latest SS version ?
No, I meant, to see if you can confirm/reproduce the bug on another system. Since you seem to say that you could not reproduce the bug on your system. Or have I understood something wrong?
SS 6179 Does NOT reproduce your bug.
Edit: Or do you mean that you have triaged the bug to have appeared after SS 6179 ?
Offline Andrey Ivashov
#4 Posted : 18 May 2021 18:12:24(UTC)
A,L:10(Enter)
A,L:10(Enter)
1/A,L(RightArrow)=
Thank you very much!
Issue is reproduced. Will fix it asap.
Best regards, Andrey Ivashov.
#5 Posted : 18 May 2021 20:53:58(UTC)
Thank you very much, this is most likely the cause we were looking for here. Clap
Offline gntech
#6 Posted : 18 May 2021 23:13:59(UTC)
gntech
Rank: Member
Sweden
Thanks Andrey and Davide, I am very happy to have been able to help you on this issue Good
I have done some more testing and found that the key elements to reproduce the bug is that the last variable entered has a subscript and that "RightArrow" is pressed before pressing equal sign.
So for example:
A.L:3
3*A.L(RightArrow)=
2^A.L(RightArrow)=
#7 Posted : 18 May 2021 23:19:02(UTC)
Issue is fixed. Will be included into the next release.
Thank you!
on 19/05/2021(UTC)
