Offline Stefan Weisskircher
#1 Posted : 17 May 2021 10:01:01(UTC)
Stefan Weisskircher
the (very smart) element-wise calculation seems to be buggy if applied to nested functions. The result can be calculated correctly, but cannot be assigned to a new variable. I found this issue in a complex calculation and simplified it to the attached problem:
- A first function uses an if-statement to calculate the result
- A second funtion calls the first function and multiplies the result with "1"
If either the if-statement or the multiplication is removed, everything works fine. This seems to be strange...
Used SMath-version: 0.99.7610, but also with current Beta-version 0.99.7804
For own tests: TestElem.sm (12kb) downloaded 2 time(s).
Offline Ber7
#2 Posted : 17 May 2021 10:20:37(UTC)
Ber7
Israel
Was thanked: 486 time(s) in 266 post(s)
Use the function eval()
eval.sm (12kb) downloaded 13 time(s).
#3 Posted : 17 May 2021 10:43:54(UTC)
Stefan Weisskircher
Seems to work! Thank you for your fast response!
