32 Pages«<2122232425>»
Offline overlord
#441 Posted : 10 May 2021 15:49:47(UTC)
Turkey
Was thanked: 548 time(s) in 368 post(s)
Originally Posted by: ndtma Go to Quoted Post
In latest SS 99.7799, I experience a label error similar to image as shown.
Some previous files show this error.
I couldn't replicate this bug but if you have it then there it is.
Maybe I don't have old files that particular versions which gives this bug.
But I can tell there is another one.
Offline ndtma
#442 Posted : 11 May 2021 07:15:47(UTC)
ndtma
Sri Lanka
Was thanked: 130 time(s) in 84 post(s)
Originally Posted by: overlord Go to Quoted Post
Originally Posted by: ndtma [url=/forum/yaf_postsm70673_X-Y-Plot-Region.aspx#post70673][/url]In latest SS 99.7799, I experience a label error similar to image as shown.
Hello.
Thanks for the feedback. I also had this problem.
Therefore, I downloaded and checked the file of Alyles and observed the error as shown in my last post.
Consequent to your post, I checked my collection and observed a strange situation
with a one saved in version 99.7769 where no such error occurred when opened with 99.7799.
On the other hand, a similar file in 99.7251 showed the error as shown.
Edited by user 11 May 2021 10:40:07(UTC)  | Reason: Not specified
Offline uni
#443 Posted : 11 May 2021 07:42:13(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
These numbers encode the text. Andrey changed something in new versions and I need to make changes in the plugin. Hopefully this only affects the display of the data.
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
on 11/05/2021(UTC)
Offline Andrey Ivashov
#444 Posted : 11 May 2021 09:14:19(UTC)
Was thanked: 2012 time(s) in 680 post(s)
You're right, Viacheslav.
You need to use this line of code to decode text entries:
Quote:
TermsConverter.DecodeText(txt)
As I already mentioned, we have such kind of issues for a long time already. But in one of the latest beta versions I've made encoding more strict, so issues appears much more often now. Let's say that it is our chance to catch them and fix.
on 11/05/2021(UTC),  on 11/05/2021(UTC)
Offline uni
#445 Posted : 12 May 2021 07:17:24(UTC)
uni
SMath Studio compatibility
Plugin updated. Please try.
Changes:
- plug-in corrected to respect latest SMath Studio API changes.
on 12/05/2021(UTC),  on 12/05/2021(UTC)
Offline ndtma
#446 Posted : 12 May 2021 08:33:13(UTC)
ndtma
Sri Lanka
Thanks. It works now.
Offline Razonar
#447 Posted : 26 May 2021 05:09:50(UTC)
Razonar
Uruguay
Was thanked: 990 time(s) in 618 post(s)
Small piece of code for filled 2-D contour plot in the XY plot plugin.
FillContour.sm (35kb) downloaded 332 time(s).
FillContour.pdf (307kb) downloaded 320 time(s).
on 26/05/2021(UTC),  on 26/05/2021(UTC)
#448 Posted : 26 May 2021 15:49:23(UTC)
Offline Razonar
#449 Posted : 26 May 2021 19:54:01(UTC)
Razonar
Uruguay
Added contour levels over the filled 2-D contour plot.
ContourLevels.sm (88kb) downloaded 55 time(s).
ContourLevels.pdf (1,234kb) downloaded 48 time(s).
thanks 4 users thanked Razonar for this useful post.
on 26/05/2021(UTC),  on 26/05/2021(UTC),  on 26/05/2021(UTC),  on 12/06/2021(UTC)
Offline Razonar
#450 Posted : 11 June 2021 14:01:38(UTC)
Razonar
Uruguay
Slightly modified for accept loops and conditionals in the function procedure for functions like Mandelbrot set.
MandelbrotSet.sm (61kb) downloaded 58 time(s).
MandelbrotSet.pdf (773kb) downloaded 29 time(s).
thanks 3 users thanked Razonar for this useful post.
on 11/06/2021(UTC),  on 11/06/2021(UTC),  on 12/06/2021(UTC)
Offline uni
#451 Posted : 25 October 2021 15:09:10(UTC)
uni
Changes:
- fixed an issue with incorrect drawing of grid lines when changing the direction of the axis.
on 25/10/2021(UTC)
Offline Razonar
#452 Posted : 05 November 2021 01:17:27(UTC)
Razonar
Uruguay
A colormaped trimesh in the XY plugin.
pShowTMesh.sm (54kb) downloaded 36 time(s).
on 05/11/2021(UTC),  on 05/11/2021(UTC),  on 06/11/2021(UTC)
Offline uni
#453 Posted : 16 November 2021 21:07:16(UTC)
uni
Plugin updated.
Changes:
- fixed problem when copying a region (some properties of the chart style were not copied).
on 16/11/2021(UTC),  on 16/11/2021(UTC)
Offline uni
#454 Posted : 16 November 2021 22:52:25(UTC)
uni
Linear polar examples.
XYPlot. Linear polar.sm (57kb) downloaded 334 time(s).
XYPlot. Linear polar.pdf (135kb) downloaded 249 time(s).
thanks 5 users thanked uni for this useful post.
on 16/11/2021(UTC),  on 16/11/2021(UTC),  on 16/11/2021(UTC),  on 17/11/2021(UTC),  on 17/11/2021(UTC)
Offline Razonar
#455 Posted : 17 November 2021 01:33:09(UTC)
Razonar
Uruguay
Hi. Very nice and useful plots. In some cases you can get more or less the same result with less effort using the plugin's ability to graph implicit functions.
thanks 5 users thanked Razonar for this useful post.
on 17/11/2021(UTC),  on 17/11/2021(UTC),  on 17/11/2021(UTC),  on 17/11/2021(UTC),  on 17/11/2021(UTC)
Offline uni
#456 Posted : 18 November 2021 16:57:35(UTC)
uni
Plugin updated.
Changes:
- restored the ability to use units in arguments.
on 18/11/2021(UTC),  on 18/11/2021(UTC),  on 18/11/2021(UTC)
Offline uni
#457 Posted : 14 December 2021 16:22:20(UTC)
uni
Plugin updated. It works, but the component is still not stable.
Changes:
- added support for parametric plot type.
'~' is used as a mark for the "range" variable and should only be used inside the X-Y Plot. When used in conjunction with ODE solvers (with a lspline() function), too many calculations are obtained and it is impossible to use this method.
Click to enlarge
XYPlot.%20Parametric.sm
Edited by user 14 December 2021 16:27:53(UTC)  | Reason: Not specified
on 14/12/2021(UTC),  on 14/12/2021(UTC)
Offline uni
#458 Posted : 15 December 2021 00:10:33(UTC)
uni
Plugin updated.
Changes:
- some broken functionality repaired;
- fixed error in determining the field width for vertical axes;
- the decimal symbol is taken from the program settings now;
- the midpoint is replaced by the multiplication sign ×;
- added the ability to change the scales of the axes using the mouse wheel;
- refactored.
Edited by user 15 December 2021 00:55:25(UTC)  | Reason: Not specified
on 15/12/2021(UTC)
Offline uni
#459 Posted : 17 December 2021 12:56:28(UTC)
uni
Plugin updated.
Changes:
- fixed a critical error when copying a region;
- rendering of linetypes (dash, ...) slightly changed (enlarged);
- added support for automatic drawing of the region when the document autocalculation mode is enabled (for now only for zoom mouse event).
Edited by user 17 December 2021 13:16:23(UTC)  | Reason: Not specified
on 17/12/2021(UTC),  on 17/12/2021(UTC)
Offline uni
#460 Posted : 17 December 2021 15:17:09(UTC)
uni
Plugin updated.
Changes:
- returned red border on error;
- more complete support for auto-recalculation mode.
on 17/12/2021(UTC),  on 17/12/2021(UTC),  on 18/12/2021(UTC)
Guest (7)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
