Offline pdalet
#1 Posted : 26 April 2021 23:22:16(UTC)
pdalet
France, Metropolitan
Was thanked: 17 time(s) in 11 post(s)
I can load a .sm file on Windows 10 (see joined files), but I have a big problem on linux (Ubuntu 20.04 64 bits - mono 6.12.0.122).
When I have loaded the file .sm, all menus disappears and the sheet displayed becomes bigger .
tested with
smathstudio 0.99 build 7786 and build 7778
Thanks a lot.
ex10 corr.pdf (50kb) downloaded 2 time(s). ex10 corr.sm (15kb) downloaded 5 time(s).
Philippe DALET.
Offline Andrey Ivashov
#2 Posted : 26 April 2021 23:58:07(UTC)
Please could you attach a screenshot from Linux?
Offline pdalet
#3 Posted : 27 April 2021 00:59:21(UTC)
pdalet
philippe
thanks 1 user thanked pdalet for this useful post.
on 27/04/2021(UTC)
Offline overlord
#4 Posted : 27 April 2021 01:15:06(UTC)
Turkey
Nothing is wrong with my setup.
on 27/04/2021(UTC)
#5 Posted : 27 April 2021 01:42:52(UTC)
Thank you. Will check this issue.
Offline pdalet
#6 Posted : 27 April 2021 11:20:18(UTC)
pdalet
Hello Andrey ,
I run smathstudio on a terminal and no error messages are displayed in the terminal.
- [AppDir] PictureRegion 1.10.7786.571 (21 ms.)
- [AppDir] SpecialFunctions 1.12.7786.571 (21 ms.)
- [AppDir] StandardToolboxButtons 1.1.7786.571 (0 ms.)
- [AppDir] TextRegion 1.11.7786.571 (10 ms.)
- [AppDir] PlotRegion 1.11.7786.571 (11 ms.)
- [AppDir] HTMLFileType 1.14.7786.571 (1 ms.)
- [AppDir] XMCDFileType 1.12.7786.571 (3 ms.)
- [AppDir] AreaRegion 1.11.7786.571 (2 ms.)
- [AppDir] SMathFileType 1.11.7786.571 (1 ms.)
- [AppDir] ImageFileType 1.11.7786.571 (1 ms.)
- [AppDir] MathRegion 1.11.7786.571 (2 ms.)
- [AppDir] ViewerFileType 1.1.7786.571 (2 ms.)
I have done the same operation with SMathStudioDesktop.0_99_7691.Mono.
All is OK. No errors.
Ph.D
Offline pdalet
#7 Posted : 27 April 2021 20:22:39(UTC)
pdalet
Philippe,
If you don't mind, attach the *.sm document.
Will add to my Instrumentation Compendium.
I have Pt, T, J advanced thermometers but not alcohol column.
Thanks ... Jean.
Thanks
The file is a correction of a physical problem given to my students.
ex10 corr.sm (15kb) downloaded 5 time(s). ex10 corr.pdf (53kb) downloaded 4 time(s).ex10.png
Offline pdalet
#8 Posted : 09 May 2021 11:36:10(UTC)
pdalet
Hello Andrey,
I have found the origin of the bug.
In text region (only on linux)
changing <p style="font-family: Arial;"> with <p> eliminates the bug.
no bug on Win10
ph.D
on 09/05/2021(UTC)
#9 Posted : 09 May 2021 13:44:28(UTC)
Hello.
Please could you try to replace "Arial" with some another Font name installed on your system? Unfortunately I cannot reproduce a bug, but maybe it is because Arial is not available on your system?
If other fonts will work I think I could try to fix this problem.
Offline pdalet
#10 Posted : 10 May 2021 01:32:42(UTC)
pdalet
Hello.
I have install Arial fonts on ~/.fonts folder, and the display is correct.
All is OK
Thanks.
philippe
