2 Pages12>
Offline Andrey Ivashov
#1 Posted : 02 May 2021 16:46:08(UTC)
Was thanked: 1977 time(s) in 665 post(s)
SMath Studio - SMath
Created by Andrey Ivashov in the scope of SMath project. Published by smath.
SMath Studio box
Version 1.0.8348 - Stable (released at )
Downloads: 1702362 Download
Open in browser
Changes history
The best software for Engineers. Easy, lightweight and comprehensive. Kudos to its Developer. more...
by Shafiq
I hope you keep on developing this great software! Thank you very much, it is easy and very efficient. If someone could help you to bring it closer to a nice text editor, it would probably replace Word for many engineers and other scientists. more...
by Dimitris
As experienced mechanical guy, this powerful tool is extremely useful for calculation for my work activities, and amazing it is free please keep working for software crown and kick expensive mathcad away! more...
by Kelvin Liu
thanks 3 users thanked Andrey Ivashov for this useful post.
on 02/05/2021(UTC),  on 02/05/2021(UTC),  on 07/05/2021(UTC)
Offline joaobr
#2 Posted : 02 May 2021 19:18:24(UTC)
joaobr
Brazil
Was thanked: 7 time(s) in 6 post(s)
Hi, Andrey!
I'm facing problems for selecting and moving objects with this update.
Offline ndtma
#3 Posted : 02 May 2021 19:55:01(UTC)
ndtma
Sri Lanka
Was thanked: 120 time(s) in 81 post(s)
Hi Andrey!
Problems with Formatted Label.
Apparently, it occurs when both text and background color is specified with "light ..." as shown.
Edited by user 02 May 2021 20:09:06(UTC)  | Reason: Error when both text and background color as "light ..."
thanks 1 user thanked ndtma for this useful post.
on 02/05/2021(UTC)
Offline overlord
#4 Posted : 02 May 2021 20:10:11(UTC)
Turkey
Was thanked: 444 time(s) in 298 post(s)
Originally Posted by: joaobr Go to Quoted Post
Hi, Andrey!
Me too, there is a performance drop with moving or scrolling regions.
#5 Posted : 02 May 2021 20:24:08(UTC)
Hi, Andrey!
How can I reproduce it?
#6 Posted : 02 May 2021 20:28:52(UTC)
Originally Posted by: ndtma Go to Quoted Post
Hi Andrey!
To overcome this issue you need to remove spaces from color name (" "). I will fix this.
Thank you!
on 02/05/2021(UTC)
#7 Posted : 02 May 2021 20:44:56(UTC)
Was thanked: 1301 time(s) in 857 post(s)
Hi Andrey!
Thank you!
In the meantime I've added a workaround in the plugin.
Offline overlord
#8 Posted : 02 May 2021 21:01:28(UTC)
Turkey
Cleaning "~/.config/SMath" directory and reinstalling all plugins solved the performance issue.
Possibly would be resulted same with cleaning the "Roaming/SMath" directory under Windows.
Edited by user 02 May 2021 21:05:03(UTC)  | Reason: Not specified
thanks 2 users thanked overlord for this useful post.
on 03/05/2021(UTC),  on 03/05/2021(UTC)
#9 Posted : 03 May 2021 00:11:30(UTC)
Hi Andrey!
Thank you!
This workaround will not work.
You need to change line
Code:
SMath.Drawing.Graphics.GetColorByName(color.Replace(" ",""));
with
Code:
SMath.Drawing.Graphics.GetColorByName(TermsConverter.DecodeText(color));
This is because variable color contains value from Term where text is always encoded. While GetColorByName does not except encoded values.
In case you want to see an example: I did the same correction in the Plot Region plug-in in my latest commit in main repo.
Offline ndtma
#10 Posted : 03 May 2021 06:19:42(UTC)
ndtma
Sri Lanka
Originally Posted by: overlord Go to Quoted Post
Originally Posted by: joaobr [url=/forum/yaf_postsm70583_Beta--SMath-Studio-0-99-7792--02-May-2021.aspx#post70583][/url]Hi, Andrey!
I too had this problem.
Even after a clean re-installation, the problem still exists.
#11 Posted : 04 May 2021 13:32:14(UTC)
Please describe in details what are you experiencing.
Offline joaobr
#12 Posted : 04 May 2021 16:11:35(UTC)
joaobr
Brazil
Sorry about the late reply.
When I open a selection box by holding the left click, it gets stucked, so I can't select objects and move them around.
I can select objects by clicking but can't drag them.
I'm testing right now and it happens only in worsheets created in previous versions.
Offline churichuro
#13 Posted : 04 May 2021 19:46:26(UTC)
churichuro
Mexico
Was thanked: 26 time(s) in 22 post(s)
trouble moving
thanks 1 user thanked churichuro for this useful post.
on 07/05/2021(UTC)
Offline ndtma
#14 Posted : 05 May 2021 04:47:48(UTC)
ndtma
Sri Lanka
Problem is as shown in post #13.
It occurs for files created in latest SS also.
Sorry for the delay.
Edited by user 05 May 2021 07:10:21(UTC)  | Reason: Not specified
Offline ndtma
#15 Posted : 05 May 2021 18:30:37(UTC)
ndtma
Sri Lanka
Did another clean-reinstallation.
Now the problem is solved only for new files saved in 99.7792.
But not for previous versions.
Thank you.
Edited by user 05 May 2021 18:33:37(UTC)  | Reason: Not specified
#16 Posted : 05 May 2021 19:08:40(UTC)
Was thanked: 961 time(s) in 789 post(s)
Do you mean for documents created in previous versions ?
As far back to previous versions ?
As well I noticed that last version affects "0.98.6179.21440"
Roots (range) options => Can't be set anymore ± 2.5
... Takes integers only or set it back to integer.
That happened from downloading some Forum latest version
even if denied updating like usual !
Take care ... Jean
Offline ndtma
#17 Posted : 05 May 2021 20:24:38(UTC)
ndtma
Sri Lanka
Yes. The last one before 99.7792.
Previous versions also. Can't remember the version number but the dates are given below.
29/05/2014
19/05/2016
27/08/2016
21/06/2018
23/09/2.18
26/06/2019
23/01/2020
Thanks.
Take care.
Offline MarB
#18 Posted : 06 May 2021 11:25:46(UTC)
MarB
Can't remember the version number ...
If you open the SMath file with a text editor, the second line shows the version:
e. g. <?application progid="SMath Studio Desktop" version="0.99.7778.42164"?>
Offline ndtma
#19 Posted : 06 May 2021 14:54:51(UTC)
ndtma
Sri Lanka
e. g.
Thank you.
#20 Posted : 06 May 2021 15:32:04(UTC)
if you can run the worksheet, just use appVersion(-digits), the negative values are for the worksheet version while the positive are for the executable.
2 Pages12>
