2 Pages<12
Offline gallyon1
#21 Posted : 05 May 2021 02:33:27(UTC)
gallyon1
hello. I have the same problem with the transfer from mathkad to smath and the maximize functionSad . Could you help me? I would really appreciate itConfusion . Sorry English is not perfect either here or in the pdf file Mathcad - mag. 2020 Vershinina Ehvelina Optimizacija slivochnogo krema1.pdf (114kb) downloaded 5 time(s).
Offline Razonar
#22 Posted : 05 May 2021 02:53:18(UTC)
Razonar
Uruguay
Was thanked: 404 time(s) in 258 post(s)
Originally Posted by: gallyon1 Go to Quoted Post
hello. I have the same problem with the transfer from mathkad to smath and the maximize function ...
Hi. If you upload the SMath file maybe someone can help you.
Offline gallyon1
#23 Posted : 05 May 2021 10:35:10(UTC)
gallyon1
yeah totally forgot about it Rolleyes sbalancirovannost_39__organoleptika_zefira_-_f-ii_Ketle_new.sm (20kb) downloaded 8 time(s).
Offline Razonar
#24 Posted : 05 May 2021 13:27:06(UTC)
Razonar
Uruguay
Hi. You have an issue here, and I don't know if it's because SMath can't calculate very well the exponential function or why, but the value for Ko(x) aren't the same in Mathcad and SMath, and thus the values for the target function K(x).
In the attached, the procedure for the "ad hoc" minimizer.
sbalancirovannost_39__organoleptika_zefira_-_f-ii_Ketle_new.sm (54kb) downloaded 7 time(s).
on 07/05/2021(UTC)
Offline gallyon1
#25 Posted : 05 May 2021 14:04:26(UTC)
gallyon1
Oh I see thank youThank you But final answer doesnt look like in MathCadSad sbalancirovannost_39__organoleptika_zefira_-_f-ii_Ketle_new (3).sm (54kb) downloaded 7 time(s).
Offline Razonar
#26 Posted : 05 May 2021 16:30:31(UTC)
Razonar
Uruguay
Hi. You must to choose the adequate parameter "percent" p for see if you can raise up the maximum. For instance this other seems to hold all the restrictions with a maximum only just 8 orders of magnitude bigger than Mathcad answer. Try to put the SMath xo value in Mathcad as new guess for the solve block and see if you get the same maximum for K(x) in Mathcad.
sbalancirovannost_39__organoleptika_zefira_-_f-ii_Ketle_new.sm (91kb) downloaded 8 time(s).
on 07/05/2021(UTC)
Offline gallyon1
#27 Posted : 07 May 2021 16:35:31(UTC)
gallyon1
If i use this x0 in MathCad I get the same X 111.pdf (132kb) downloaded 3 time(s).. x=X. I tried a lot of p values but I didnt get close result. Results are always too big. 222.sm (76kb) downloaded 3 time(s).
Offline Razonar
#28 Posted : 07 May 2021 19:19:13(UTC)
Razonar
Uruguay
Hi gallyon1. You are looking for a maximum. So, for your problem, bigger is better. SMath returns a bigger result, but that's not all: the results verify all the problem constraints, which make it valid answer for the problem.
Maybe I don't explain well: try to check what happen with mathcad if you use the SMath answer as the guess, this is substitute the x value in Mathcad for the xo value from SMath here:
But actually that's for compare. SMath solution checks all the constraints, then it's a candidate for the problem solution. You "didn't get close result", but I don't see a problem there, where I see a problem is if you want a close result, this is a result near to 8.8*10^8 you need to review your physical system and check if there are some additional constrictions for some variable or function which make your result "close" to that value. If not, SMath solution it's just a good solution, and Mathcad's isn't.
on 07/05/2021(UTC),  on 10/05/2021(UTC)
Offline gallyon1
#29 Posted : 07 May 2021 19:39:04(UTC)
gallyon1
Ok I got it. Thank you allThank you Maybe I was too attached to MathCad solution.
2 Pages<12
