SMath Studio Forum
Questions
function maximize/minimize in Smath Studio
Originally Posted by: gallyon1 hello. I have the same problem with the transfer from mathkad to smath and the maximize function ...
Hi. If you upload the SMath file maybe someone can help you. Best regards. Alvaro.
Originally Posted by: gallyon1 Hi. You have an issue here, and I don't know if it's because SMath can't calculate very well the exponential function or why, but the value for Ko(x) aren't the same in Mathcad and SMath, and thus the values for the target function K(x). In the attached, the procedure for the "ad hoc" minimizer. sbalancirovannost_39__organoleptika_zefira_-_f-ii_Ketle_new.sm (54kb) downloaded 12 time(s).Best regards. Alvaro.
Originally Posted by: gallyon1 Oh I see thank you But final answer doesnt look like in MathCad Hi. You must to choose the adequate parameter "percent" p for see if you can raise up the maximum. For instance this other seems to hold all the restrictions with a maximum only just 8 orders of magnitude bigger than Mathcad answer. Try to put the SMath xo value in Mathcad as new guess for the solve block and see if you get the same maximum for K(x) in Mathcad. sbalancirovannost_39__organoleptika_zefira_-_f-ii_Ketle_new.sm (91kb) downloaded 19 time(s).Best regards. Alvaro.
If i use this x0 in MathCad I get the same X 111.pdf (132kb) downloaded 7 time(s).. x=X. I tried a lot of p values but I didnt get close result. Results are always too big. 222.sm (76kb) downloaded 8 time(s).
Originally Posted by: gallyon1 If i use this x0 in MathCad I get the same X 111.pdf (132kb) downloaded 7 time(s).. x=X. I tried a lot of p values but I didnt get close result. Results are always too big. 222.sm (76kb) downloaded 8 time(s). Hi gallyon1. You are looking for a maximum. So, for your problem, bigger is better. SMath returns a bigger result, but that's not all: the results verify all the problem constraints, which make it valid answer for the problem. Maybe I don't explain well: try to check what happen with mathcad if you use the SMath answer as the guess, this is substitute the x value in Mathcad for the xo value from SMath here: But actually that's for compare. SMath solution checks all the constraints, then it's a candidate for the problem solution. You "didn't get close result", but I don't see a problem there, where I see a problem is if you want a close result, this is a result near to 8.8*10^8 you need to review your physical system and check if there are some additional constrictions for some variable or function which make your result "close" to that value. If not, SMath solution it's just a good solution, and Mathcad's isn't. Best regards. Alvaro.
on 07/05/2021(UTC), on 10/05/2021(UTC)
Ok I got it. Thank you all Maybe I was too attached to MathCad solution.
SMath Studio Forum
Questions
