SMath Studio - SMath
Simplemente la mejor y libre alternativa a Mathcad. Gracias
more...
by Jorge Rodríguez
An invaluable tool for high schoolers and engineering students! A big thank you from India.
more...
by Anirban
Es un programa excelente y muy útil para la enseñanza y aprendizaje en ing. Civil. Muy recomendable!!!
more...
by Wilson Rodríguez Calderón
on 02/05/2021(UTC), on 02/05/2021(UTC), on 07/05/2021(UTC)
Joined: 12/02/2018(UTC) Posts: 62 Location: Belém Was thanked: 7 time(s) in 6 post(s)
Hi, Andrey!
I'm facing problems for selecting and moving objects with this update.
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Hi Andrey! Problems with Formatted Label. Apparently, it occurs when both text and background color is specified with "light ..." as shown. Edited by user 02 May 2021 20:09:06(UTC)
| Reason: Error when both text and background color as "light ..." |
1 user thanked ndtma for this useful post.
Joined: 23/07/2013(UTC) Posts: 1,126 Was thanked: 507 time(s) in 338 post(s)
Originally Posted by: joaobr Hi, Andrey!
I'm facing problems for selecting and moving objects with this update. Me too, there is a performance drop with moving or scrolling regions.
I'm facing problems for selecting and moving objects with this update. How can I reproduce it?
To overcome this issue you need to remove spaces from color name ( " "). I will fix this. Thank you!
To overcome this issue you need to remove spaces from color name ( " "). I will fix this. Thank you! In the meantime I've added a workaround in the plugin. |
Originally Posted by: Andrey Ivashov How can I reproduce it? Cleaning "~/.config/SMath" directory and reinstalling all plugins solved the performance issue. Possibly would be resulted same with cleaning the "Roaming/SMath" directory under Windows. Regards Edited by user 02 May 2021 21:05:03(UTC)
| Reason: Not specified
2 users thanked overlord for this useful post.
on 03/05/2021(UTC), on 03/05/2021(UTC)
Originally Posted by: Davide Carpi Originally Posted by: Andrey Ivashov Originally Posted by: ndtma Hi Andrey!
To overcome this issue you need to remove spaces from color name ( " "). I will fix this. Thank you! In the meantime I've added a workaround in the plugin. This workaround will not work. You need to change line Code:SMath.Drawing.Graphics.GetColorByName(color.Replace(" ",""));
with Code:SMath.Drawing.Graphics.GetColorByName(TermsConverter.DecodeText(color));
This is because variable color contains value from Term where text is always encoded. While GetColorByName does not except encoded values. In case you want to see an example: I did the same correction in the Plot Region plug-in in my latest commit in main repo. Best regards.
Originally Posted by: overlord Originally Posted by: joaobr [url=/forum/yaf_postsm70583_Beta--SMath-Studio-0-99-7792--02-May-2021.aspx#post70583][/url]Hi, Andrey!
I'm facing problems for selecting and moving objects with this update. I too had this problem. Even after a clean re-installation, the problem still exists. |
Originally Posted by: ndtma Originally Posted by: overlord Originally Posted by: joaobr [url=/forum/yaf_postsm70583_Beta--SMath-Studio-0-99-7792--02-May-2021.aspx#post70583][/url]Hi, Andrey!
I'm facing problems for selecting and moving objects with this update. I too had this problem. Even after a clean re-installation, the problem still exists. Please describe in details what are you experiencing.
Sorry about the late reply.
When I open a selection box by holding the left click, it gets stucked, so I can't select objects and move them around.
I can select objects by clicking but can't drag them.
I'm testing right now and it happens only in worsheets created in previous versions.
Joined: 27/03/2019(UTC) Posts: 75 Location: coah Was thanked: 27 time(s) in 22 post(s)
trouble moving
1 user thanked churichuro for this useful post.
Originally Posted by: Andrey Ivashov Please describe in details what are you experiencing.
Problem is as shown in post #13. It occurs for files created in latest SS also. Sorry for the delay. Edited by user 05 May 2021 07:10:21(UTC)
Originally Posted by: ndtma It occurs for files created in latest SS also. Did another clean-reinstallation. Now the problem is solved only for new files saved in 99.7792. But not for previous versions. Thank you. Edited by user 05 May 2021 18:33:37(UTC)
Originally Posted by: ndtma Did another clean-reinstallation. Now the problem is solved only for new files saved in 99.7792. But not for previous versions. Do you mean for documents created in previous versions ? As far back to previous versions ? As well I noticed that last version affects "0.98.6179.21440" Roots (range) options => Can't be set anymore ± 2.5 ... Takes integers only or set it back to integer. That happened from downloading some Forum latest version even if denied updating like usual ! Take care ... Jean
Originally Posted by: Jean Giraud Do you mean for documents created in previous versions ? As far back to previous versions ? Yes. The last one before 99.7792. Previous versions also. Can't remember the version number but the dates are given below. 29/05/2014 19/05/2016 27/08/2016 21/06/2018 23/09/2.18 26/06/2019 23/01/2020 Thanks. Take care. |
Originally Posted by: ndtma Can't remember the version number ...
If you open the SMath file with a text editor, the second line shows the version: e. g. <?application progid="SMath Studio Desktop" version="0.99.7778.42164"?>
Originally Posted by: MarB If you open the SMath file with a text editor, the second line shows the version: e. g. Thank you. |
if you can run the worksheet, just use appVersion(-digits), the negative values are for the worksheet version while the positive are for the executable. |
