Joined: 19/09/2009(UTC) Posts: 34 Was thanked: 17 time(s) in 11 post(s)
Hello, I can load a .sm file on Windows 10 (see joined files), but I have a big problem on linux (Ubuntu 20.04 64 bits - mono 6.12.0.122). When I have loaded the file .sm, all menus disappears and the sheet displayed becomes bigger . tested with smathstudio 0.99 build 7786 and build 7778 Thanks a lot. ex10 corr.pdf (50kb) downloaded 2 time(s). ex10 corr.sm (15kb) downloaded 5 time(s).Philippe DALET.
Please could you attach a screenshot from Linux?
Originally Posted by: Andrey Ivashov Please could you attach a screenshot from Linux? philippe
1 user thanked pdalet for this useful post.
Joined: 23/07/2013(UTC) Posts: 1,124 Was thanked: 506 time(s) in 337 post(s)
Nothing is wrong with my setup.
Thank you. Will check this issue.
Originally Posted by: Andrey Ivashov Thank you. Will check this issue. Hello Andrey , I run smathstudio on a terminal and no error messages are displayed in the terminal. - [AppDir] PictureRegion 1.10.7786.571 (21 ms.) - [AppDir] SpecialFunctions 1.12.7786.571 (21 ms.) - [AppDir] StandardToolboxButtons 1.1.7786.571 (0 ms.) - [AppDir] TextRegion 1.11.7786.571 (10 ms.) - [AppDir] PlotRegion 1.11.7786.571 (11 ms.) - [AppDir] HTMLFileType 1.14.7786.571 (1 ms.) - [AppDir] XMCDFileType 1.12.7786.571 (3 ms.) - [AppDir] AreaRegion 1.11.7786.571 (2 ms.) - [AppDir] SMathFileType 1.11.7786.571 (1 ms.) - [AppDir] ImageFileType 1.11.7786.571 (1 ms.) - [AppDir] MathRegion 1.11.7786.571 (2 ms.) - [AppDir] ViewerFileType 1.1.7786.571 (2 ms.) I have done the same operation with SMathStudioDesktop.0_99_7691.Mono. All is OK. No errors. Ph.D
Originally Posted by: Jean Giraud Philippe, If you don't mind, attach the *.sm document. Will add to my Instrumentation Compendium. I have Pt, T, J advanced thermometers but not alcohol column. Thanks ... Jean. Thanks The file is a correction of a physical problem given to my students. ex10 corr.sm (15kb) downloaded 5 time(s). ex10 corr.pdf (53kb) downloaded 4 time(s).
Originally Posted by: Andrey Ivashov Thank you. Will check this issue. Hello Andrey, I have found the origin of the bug. In text region (only on linux) changing <p style="font-family: Arial;"> with <p> eliminates the bug. no bug on Win10 ph.D
Hello. Originally Posted by: pdalet In text region (only on linux) changing <p style="font-family: Arial;"> with <p> eliminates the bug. Please could you try to replace "Arial" with some another Font name installed on your system? Unfortunately I cannot reproduce a bug, but maybe it is because Arial is not available on your system? If other fonts will work I think I could try to fix this problem.
Originally Posted by: Andrey Ivashov Hello. Originally Posted by: pdalet In text region (only on linux) changing <p style="font-family: Arial;"> with <p> eliminates the bug. Please could you try to replace "Arial" with some another Font name installed on your system? Unfortunately I cannot reproduce a bug, but maybe it is because Arial is not available on your system? If other fonts will work I think I could try to fix this problem. Hello, I have install Arial fonts on ~/.fonts folder, and the display is correct. All is OK Thanks. philippe
