  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,603   Was thanked: 1972 time(s) in 661 post(s)
New feature is introduced in SMath Studio 0.94.4535 - Absolute Definitions.  The same is for functions (which starts from ~). This feature is not the same as used in Mathcad (called Global Definitions). Absolute Definitions designed to introduce a built-in way to send data from the bottom of the Worksheet to it's top.  Example: absoluteDefinitionsExample.sm. Any questions are welcome  Best regards, Andrey Ivashov.
on 01/06/2012(UTC), on 01/06/2012(UTC)
  Rank: Administration Groups: Registered, Advanced Member Joined: 23/06/2009(UTC) Posts: 1,740   Was thanked: 318 time(s) in 268 post(s)
Hello Andrey, Thank you for this new feature. I have to say that using those variables might be quite useful, but sometimes a bit confusing. Regarding your example, and by playing a bit, I could see that the region will be "someVar=0" when you open the file. When you repeat Recalculate page, someVar will have values 1,2,3,4.....which is expected to be. On the other hand if you move that region above and below if clause subsequently, then the values will have step two, actually you will get 21,23,25... I've also noted that with the simple example 1: a:=1 2: a:=a+1 3: a=2 4: a:=6 Now, if you move 4: below 1: you will get ("a" will be 7 as expected) 1: a:=1 4: a:=6 2: a:=a+1 3: a=7 When you just move it back, then "a" becomes 8? If you continue moving 4: below 1: and back, value of "a" will get values 7 and 8 subsequently 1: a:=1 2: a:=a+1 3: a=8 4: a:=6 When you recalculate page at this time, "a" will become 2, as expected. Is there something I do not understand here?. I think that this moving the definition of an absolute variable above and below the region when that variable changes the value is a bit problematic at the moment. I think that variable should not change the value when we get it back. Aactualy, I think that variable "a" should retain the value 7 and not change to 8. Regards, Radovan Edited by user 01 June 2012 12:19:16(UTC)
Was thanked: 5 time(s) in 4 post(s)
This is because program evaluates only expressions affected by the change. So when you move a back to the bottom SMath Studio performs evaluation starting from second expression and not from the top.
 1 user thanked kmihaylovich for this useful post.
Hello, Originally Posted by: kmihaylovich  This is because program evaluates only expressions affected by the change. So when you move a back to the bottom SMath Studio performs evaluation starting from second expression and not from the top. Thank you, I think I understand now By the way, could someone reproduce this. I tried to make an absolute function and then the region disappeared, and everything else disappeared. I got it back by clicking in the worksheet area. It happened to me few times before, sometimes SMath crashed, but could not reproduce it. Look at this video, please. Regions disappearRegards, Radovan |
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,540   Location: Italy Was thanked: 1270 time(s) in 835 post(s)
Originally Posted by: omorr  Hello, ... By the way, could someone reproduce this. I tried to make an absolute function and then the region disappeared, and everything else disappeared. I got it back by clicking in the worksheet area. It happened to me few times before, sometimes SMath crashed, but could not reproduce it. Look at this video, please. Regions disappearRegards, Radovan I confirm... it's not the absolute value, but the assignment ":" (sequence to reproduce the issue: ~ -> f -> ( -> x -> " ->" -> : ) the ~ can be obtained by typing "Alt" + 0126 (from numpad)I think the bolded function obtained by typing ~ before the name can be very interesting...  regards, w3b5urf3r Edited by user 02 June 2012 22:58:01(UTC)
Thank you, Originally Posted by: w3b5urf3r_reloaded  I confirm... it's not the absolute value, but the assignement ":" I agree and it seems it happened sometimes when the assignment is used. I just bumped into it when tried to use absolute functions. I think this might be considered as a bug then. Regards, Radovan |
Joined: 04/07/2015(UTC) Posts: 6,397  Was thanked: 928 time(s) in 756 post(s)
Originally Posted by: omorr  By the way, could someone reproduce this. I tried to make an absolute function and then the region disappeared, and everything else disappeared. I got it back by clicking in the worksheet area. It happened to me few times before, sometimes SMath crashed, but could not reproduce it. Look at this video, pleas Hello Radovan, Watching your video about Smath turning blue is occasional. Worst when it turns all white. Tip, open another work sheet go back to the working work sheet ... back on foot. Sometimes it crashes for true, because truly bad syntax. I don't understand the problem of assigning absolute ........... f(x):=A*|(x-xo)^0.0625| Gamma planet is slow in my Smath, hope yours is faster. You will have to plug the image in your system. The bold, if it works as bad as in Mathcad 11, bad luck. In Mathcad 11 it didn't save settings, so you had to redefine again. IMHO, purely classroom demo. Jean   Image Planet Gamma.sm (102kb) downloaded 52 time(s).
Hiiiiiiiiiiii !
Can hardly see the Smath work sheet attached.
Originally Posted by: Davide Carpi  I think the bolded function obtained by typing ~ before the name can be very interesting... Not so sure, to see capital phi => size 24 Jean Scrap Bold.sm (5kb) downloaded 54 time(s).
"Everything is relative" ![2016-02-16 08_13_19-SMath Studio Desktop - [Scrap%20Bold.sm_].png](/forum/resource.ashx?a=11822&b=2) If you are working in a worksheet where 24pt is the default font-size, shouldn't be a problem. But yes, bold notation has his own limits (even when used to distinguish a matrix from a scalar) :P |
Smath recognises Alt+0key, but not Alt+0key symbol. Smath does not have the "Font" plugin Still very interesting for publishing.  Jean
