Offline SmathNewbie
#1 Posted : 21 April 2021 22:46:53(UTC)
SmathNewbie
Rank: Member
Is there such matrix function to help me get the coefficient Cf based on ratio s/h and B/s from given table in matrix form?
Offline overlord
#2 Posted : 21 April 2021 23:38:34(UTC)
Turkey
You can either use linterp() or InterpBilinear().
They can also find an interpolated value between title numbers.
Please look at the Reference Book for further information.
Offline SmathNewbie
#3 Posted : 22 April 2021 00:05:55(UTC)
SmathNewbie
Rank: Member
Thank you. Found it here. https://en.smath.com/for..._Interpolate-Matrix.aspx
Learn new things every day.
#4 Posted : 22 April 2021 00:24:29(UTC)
Spline(M,x,y) is universal.
Construct 1/1 from the given example, forget decoration <, >
Just for interpolation, you don't need the rotation system.
Spline Matrix Tutorial RECTANGULAR Surface Plot.sm (23kb) downloaded 22 time(s).
on 22/04/2021(UTC)
#5 Posted : 22 April 2021 00:33:04(UTC)
... nice example done for Smath Community visitor.
Construct rough data table, spline at will, plot is most delightful.
How do you manage ... Jean
SplineRectangularMatrix Isentropic Surface.sm (458kb) downloaded 12 time(s).
on 22/04/2021(UTC)
Offline SmathNewbie
#6 Posted : 22 April 2021 01:13:21(UTC)
SmathNewbie
Rank: Member
Beautiful. I love the way you present all math problems in such a lovely form.
Even though it is a very rare case, when x and/or y values exceed the range in my posted table the function will return the value more or less than it should be because I think the table cap the values. I wanted to make changes to the Spline function to reflect this but my limited knowledge in programing and Smath prevents me from doing that. Any suggestions?
#7 Posted : 22 April 2021 19:50:04(UTC)
See you soon tomorrow ... Jean.
... here is, play with rotation.
Spline Matrix Tutorial RECTANGULAR Surface Plot Example.sm (24kb) downloaded 9 time(s).
on 22/04/2021(UTC)
Offline SmathNewbie
#8 Posted : 22 April 2021 20:47:20(UTC)
SmathNewbie
Rank: Member
Awesome. When x=70, y=0.5, I need it to be 1.75 per code because x>45 but the function gives me 1.83. How would I modify the code for Spline to achieve this.
Offline mkraska
#9 Posted : 22 April 2021 21:37:25(UTC)
mkraska
Obviously the function uses linear extrapolation beyond the limits of the data array.
Without touching the function you can enforce constant extrapolation by repeating the first or last rows or columns of data.
surface.sm (19kb) downloaded 10 time(s).
on 23/04/2021(UTC)
#10 Posted : 22 April 2021 22:46:35(UTC)
... as simple as that, preserving last two cols linearity.
on 23/04/2021(UTC)
Offline SmathNewbie
#11 Posted : 23 April 2021 00:41:11(UTC)
SmathNewbie
Rank: Member
Me feeling dumb. Thanks, Jean and MKraska
