2 Pages12>
Offline Andrey Ivashov
#1 Posted : 09 April 2021 00:31:34(UTC)
Was thanked: 2012 time(s) in 680 post(s)
SMath Studio - SMath
Created by SMath LLC in the scope of SMath project. Published by smath.
  • SMath Studio box
  • Calculation of Gravitation Acceleration example
  • Example of animation on the Worksheet
  • Extensions Manager tool
  • Opened math Reference Book
  • SMath Viewer output to Autocad example
  • SMath Studio on iOS
  • SMath Studio on iPad
They trust us *
* Customers' names and logos are used with the written permission of the copyright holders.
They talk about us (all reviews...)
  • Great tool for all engineers. It's very user-friendly and has lots of functionalities that can be further extended by installing plug-ins (it takes just a few clicks, no need for tedious file manipulations). SMath can operate on units, perform symbolic calculations and many more. Also, it has very clear interface and all formulas can be entered just like you would do on a piece of paper. What's more, the software has great community of people willing to help with various issues.
    by Jacob M.
  • Great program for conducting engineering calculations. The ability to insert text blocks and pictures makes it perfect for both computation and communication of the results to colleagues.
    by Filip Finodeyev
  • excelente programita lo recomiendo
    by malandro
  • Thank you so much for this amazing tool great job!
    by Sanan Toplic
  • Dentro del ámbito de la investigación y desarrollo electrónico es una herramienta completa para realizar los análisis preliminares y más. / Within the field of electronic research and development, it is a complete tool for preliminary analysis and more.
    by Cristian Matorra
  • Es un imprescindible para el día a día. Muchísimas gracias Mr Andrey Ivashov.
    by Ángel Álvarez
  • I've used this software for several years and can not use anything else for work. I'm a mechanical Engineer and use this for any calculations I do. 1) To show and check my work 2) to set values and write descriptions so I can reuse my formulas for other projects. This is better than any calculator. Thank you Smath for such a great software.
    by Shawn Paul
  • If you are thinking about getting MathCAD for your business or personal use you may want to try SMath Studio first. SMath Studio is a free math program with easy to use intuitive "paper-like" interface. If SMath Studio meets your needs then look no further and consider donating to promote further development of this great program. On the SMath Studio forum, the developer and forum community are very receptive to help questions, bug reports, and feature requests.
    by j_kris
  • Without a doubt it is one of the best tools for engineering, a good substitute for Mathcad
    by Marcel F. Chevalier S.
  • Absolutely Gorgeous software, which can be a level riser for spreadsheet calculation, seamlessly extended for any kind of mathematical application.
    by Shiju VT
SMath Studio in publications (all publications...)
SMath Studio plug-ins (all plug-ins...)
The functionality of the program can be expanded through the installation of plug-ins created by third-party developers and companies, as well as those prepared by the SMath LLC team. Most plug-ins are open source and can be modified if necessary.
  • Extends SMath Studio with a 3D Plot Region.
    Jack Xu, Viacheslav N. Mezentsev (viacheslavmezentsev@ya.ru)
  • Extends SMath Studio with more save/import/export features.
    Davide Carpi (davide.carpi@gmail.com)
  • Access to a set of programs for calculating properties of water, steam, gases and gases mixtures. Requires separate installation of the Water Steam Pro libraries and appropriate license for it (see http://www.wsp.ru/).
    ООО "ЭсМат"
  • Provides access to the free and open source computer algebra system Maxima.
    Kay Graubmann & Martin Kraska (THB www.th-brandenburg.de)
  • Extends SMath Studio with a X-Y Plot Region.
  • A SMath Studio native wrapper of the CoolProp library (www.coolprop.org) - thermophysical property database and wrappers for a selection of programming environments.
    Mike Kaganski
  • Contains nonlinear solvers for equations and systems of equations: Bisected Direct Quadratic Regula Falsi (BDQRF), Bisection, Brent's, Broyden's, Homotopy, Newton-Raphson, Ridder's, Secant, etc.
  • Digital Signal Processing Library: spectral analysis, IIR and FIR filters, resampling algorithms, etc.
    Sergey Bakhurin (http://dsplib.org), Viacheslav N. Mezentsev (viacheslavmezentsev@ya.ru)
  • Extends SMath Studio with statistical tools: Sample Estimators, Probability Density, Cumulative Density, Quantile functions, Random Numbers, etc.
  • Provides an interface to the SQLite relational database engine.
    Chris Bietz, Viacheslav N. Mezentsev
on 09/04/2021(UTC),  on 09/04/2021(UTC),  on 09/04/2021(UTC),  on 12/04/2021(UTC)
#2 Posted : 09 April 2021 00:41:22(UTC)
Main change of this version is that some features of the program will work only for those who signed in using smath.com credentials:
F.e.:
  • [DONE]Full version of SMath Viewer;
  • [IN PROGRESS]Open worksheets from SMath Studio in the Cloud directly in Desktop version (with possibility to save back to the Cloud);
  • [IN PROGRESS]Automatic back up of the worksheets to the Cloud (when turned on);
  • [IN PROGRESS]Reporting observations directly from SMath Studio;
  • [IN PROGRESS]Worksheet Author field automatically filled in with a name from Account for new Worksheets/Documents;
  • [IN PROGRESS]Synchronization of the program settings between devices (when turned on).
Full version of SMath Viewer is now available for signed in users:
Edited by user 09 April 2021 12:32:45(UTC)  | Reason: Not specified
Offline overlord
#3 Posted : 09 April 2021 04:57:39(UTC)
Turkey
Was thanked: 548 time(s) in 368 post(s)
Originally Posted by: Andrey Ivashov Go to Quoted Post
Full version is now working again using https://en.smath.com/for...7769--09-April-2021.aspx
If your linux setup don't have libgluezilla, last version won't work with Mono.
If you have a debian based distro, sudo apt-get install libmono-webbrowser4.0-cil should work for you.
Unfortunately, my distro don't have this library in its repos.
Andrey, is this required by sign-in process?
PS: Nevermind, I have downloaded debian package and replaced corresponding libraries on my system with files in it.
Code:
$ ./smathstudio_desktop_mono
libgluezilla not found. To have webbrowser support, you need libgluezilla installed
Unhandled Exception:
System.NullReferenceException: Object reference not set to an instance of an object
  at System.Windows.Forms.WebBrowser.Refresh (System.Windows.Forms.WebBrowserRefreshOption opt) [0x00042] in <391b318e46af443ab4360466631816f9>:0
  at System.Windows.Forms.WebBrowser.Refresh () [0x00000] in <391b318e46af443ab4360466631816f9>:0
  at System.Windows.Forms.Control.SetVisibleCore (System.Boolean value) [0x000e0] in <391b318e46af443ab4360466631816f9>:0
  at System.Windows.Forms.Control.set_Visible (System.Boolean value) [0x00009] in <391b318e46af443ab4360466631816f9>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control.set_Visible(bool)
  at SMath.Environment.DesktopAccount..ctor () [0x00061] in <fbb68a878e394b9fb8c8b62d5205b3aa>:0
  at SMath.Environment.SessionsManagerPaths..ctor (System.String[] resourcesPaths) [0x00006] in <fbb68a878e394b9fb8c8b62d5205b3aa>:0
  at SMath.Environment.SessionsManagerPaths.Create (System.String[] paths) [0x00012] in <fbb68a878e394b9fb8c8b62d5205b3aa>:0
  at SMath.Environment.AppSettingsDesktop.Initialize (SMath.Manager.PluginsStatusEventHandler loaded) [0x0005e] in <fbb68a878e394b9fb8c8b62d5205b3aa>:0
  at SMath.UI.Desktop.Program. (System.String[] ) [0x0006b] in <a2a38fd6146f46e4b9a353dd93da2fd7>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object
Edited by user 09 April 2021 05:59:43(UTC)  | Reason: Not specified
on 09/04/2021(UTC)
Offline fedeghi
#4 Posted : 09 April 2021 13:53:41(UTC)
fedeghi
Was thanked: 24 time(s) in 16 post(s)
Andrey, could you give us some further details about accounts, how are they obtained/assigned, what is the idea behind, conditions and so on?
Thanks
Offline PompelmoTell
#5 Posted : 09 April 2021 16:13:14(UTC)
PompelmoTell
Was thanked: 115 time(s) in 98 post(s)
Andrey, in my current installation (0.99.7739.40423) no update is proposed. Do I need to install from scratch?
Edited by user 09 April 2021 16:23:16(UTC)  | Reason: Not specified
Offline ElSid
#6 Posted : 09 April 2021 16:21:54(UTC)
ElSid
Same question as fedeghi.
In addition, this feels like your moving to a rev 1.0. I've seen multiple requests for documentation. How can we (community) help? gurro recently started the "New series of YouTube videos for learning how to use SMath Studio"
#7 Posted : 09 April 2021 18:17:40(UTC)
I think you need to turn Exclude Beta versions checkbox off in Extensions Manager to see this update.
#8 Posted : 09 April 2021 18:46:48(UTC)
PompelmoTell
yes, now it's gone,
Thank you
Offline Jason McCool
#9 Posted : 09 April 2021 19:18:56(UTC)
Jason McCool
Was thanked: 9 time(s) in 7 post(s)
Tried logging in, but nothing happened. Is that SMath account a different account than the SMath Forum account? I did confirm that I had the right password for the forum account and tried again, but no success.
Also, the problems I reported before about unwanted math regions being inserted automatically in text regions is still present. I can't enter a date in any common format without it being interpreted as an equation. Using dashes like 01-01-2021 isn't too different on the formatting (more space), but slashes are also common and 1/1/2021 gets interpreted as a fraction, which is an issue. My only workaround so far has been to add spaces and then backspace them out after I've typed everything, which is not an ideal workflow. But it may also be affecting my dropdown boxes as well now. In the screenshot below, the last entry for 3/4 was entered after the update this morning, and it doesn't display correctly in the subsequent dropdown combobox. It still picks the correct value, but the display in the list could be difficult to interpret like this.
Thanks,
Jason
Jason McCool
Robbins Engineering
Little Rock, AR, USA
#10 Posted : 09 April 2021 19:29:15(UTC)
PompelmoTell
Jason,
I used the Smath Cloud account (it's not the same registration used for the forum) and it recognized me.
on 09/04/2021(UTC)
Offline overlord
#11 Posted : 09 April 2021 19:34:41(UTC)
Turkey
Jason,
Sign-in works under windows, doesn't with linux.
Any other linux user who could sign in?
Offline ElSid
#12 Posted : 09 April 2021 20:29:44(UTC)
ElSid
Jason,
Sad
#13 Posted : 09 April 2021 20:50:46(UTC)
Jason McCool
There's also another issue that started appearing in the previous build, but still occurs in this one. See below for a screenshot of the shaded region at the bottom of the page that is inaccessible. The cursor cannot be placed or moved into that area. Trying to move any text or math region into it just makes those items bounce out. Seems to occur when I've had a graphic on the page above that moved down until it no longer fit on the page and moved to the next page. Then it leaves this strange shaded area where the graphic used to be on the upper page. If I hit the carriage return on the keyboard, one line of the shaded region goes away. So if hit Enter a bunch of times, the region temporarily goes away, but comes back later with more editing. Any ideas?
Thanks,
Jason
Jason McCool
Robbins Engineering
#14 Posted : 09 April 2021 21:27:38(UTC)
To have an account it is enough just to register at http://smath.com using this url: https://en.smath.com/register
There are no any conditions - it just takes couple of minutes to fill in a registration form and receive an e-mail.
Exactly. I'm preparing to make a release of SMath Studio ver 1.0.
Long time ago I planned to provide more integration between SMath Studio Desktop and SMath Studio in the Cloud. In addition I want to restore functionality to create full featured SMath Viewer apps. All these requires support from server side. Which means every user who plans to use such functionalities needs to be authenticated.
Today SMath Studio in the Cloud stores Terabytes of worksheets and other data on server and it becomes more and more hard to maintain server/database (performance, backups etc.).
Another point is that I want to stop asking community for donations. Just to make it clear: it is a pleasure for me that so many people ready to help and really helped me a lot, but obviously it is not a way to make a project more professional.
Taking everything into account I decided to try to change something... and to introduce subscriptions. Preliminary, there are 3 options to be available:
  1. Simple: SMath Studio in the Cloud in guest mode, SMath Studio Desktop will work as it does today;
  2. Existing account at smath.com: personalized SMath Studio in the Cloud, auto fill properties for new worksheets from the user Profile, synchronization of the settings, etc.;
  3. Paid plan (f.e. annual, based on the number of users in Organization): unlimited disk space on SMath Studio in the Cloud, full featured SMath Viewer Pro, deep integration with SMath Studio in the Cloud; additional documents backup options; support by e-mail/Skype.
It is not a final list, so something may be changed or rearranged. Of course I will provide special offers for those who use SMath Studio for personal or educational purposes.
And I want to highlight it again: SMath Studio remains to be free and account or paid subscription required ONLY for features which uses connection to server or if it is related to support. Just because I have to spend many time and resources on this stuff.
At least it is a plan. Not sure if it will become a reality. For now, having an account on smath.com enough for all.
thanks 3 users thanked Andrey Ivashov for this useful post.
on 09/04/2021(UTC),  on 11/04/2021(UTC),  on 21/04/2021(UTC)
#15 Posted : 09 April 2021 21:30:41(UTC)
Account at the Forum and account at smath.com are different. This is something I need to fix asap, but it is not that simple.
#16 Posted : 09 April 2021 21:36:19(UTC)
Sad
As always Linux is a tricky part of the development. I will see what I can do about it. If it will not be possible to support Account menu item at all I will just remove it from Mono version of SMath Studio. At least for some time.
Offline overlord
#17 Posted : 09 April 2021 21:50:45(UTC)
Turkey
Thank you for your support on linux. It is not a growing market yet you do your best.
Actually one thing we really want is bold and italic font functions to work with linux.
Sign-in option has secondary priority compared to this at the moment if you ask me.
#18 Posted : 09 April 2021 21:52:26(UTC)
This is by design from the time when Pages representation mode was introduced. Please try to play with MS Word and SMath Studio side by side.
on 10/04/2021(UTC)
#19 Posted : 10 April 2021 05:43:46(UTC)
Jason McCool
Wow, 20+ years of using Word and I never knew about that! Thank you for the explanation. I had tried clicking in the space several times but never double-clicking. Glad that one had an easy solution. Thanks! Any suggestions on how the text is displaying in controls?
Jason McCool
Robbins Engineering
#20 Posted : 10 April 2021 11:11:40(UTC)
The reason is in my comment here: https://en.smath.com/for...SN-T-WORK.aspx#post69253
I will start correcting plugins today.
2 Pages12>
