SMath Studio Forum
Samples
operations with base different to 10
Joined: 04/04/2021(UTC) Posts: 10 Was thanked: 1 time(s) in 1 post(s)
how can I do an arithmetic operation using a different base to 10?
I did not find anything related to this anywhere.
Originally Posted by: jtm2020hyo how can I do an arithmetic operation using a different base to 10 ? Can you be more specific with an example ?
For example, for binaries:
2 in base 10 = 2
2 in base 2 = 10 ( base 2)
2 in base + 2 in base 2 = 100 (base 2)
4 in base 10 = 100 in base 2
Base is wrote like a number subscripted
Joined: 23/07/2013(UTC) Posts: 1,126 Was thanked: 507 time(s) in 338 post(s)
Originally Posted by: jtm2020hyo For example, for binaries:
2 in base 10 = 2
Base is wrote like a number subscripted If I am not mistaken, there are no such base arithmetic functions under SMath. You can write your own functions under SMath, but I guess it would take a lot of time. Hmm, maybe this is a nice idea to write a plugin about. I could do that as a side project in my spare times. No promises here. Regards. Edited by user 06 April 2021 16:11:56(UTC)
| Reason: Not specified
Originally Posted by: jtm2020hyo how can I do an arithmetic operation using a different base to 10 ? I don't understand, simply. I you have a parametric function from source f(a,b,c,x) parameters [a,b,c] given from source as decimal, why would you convert in another base than decimal ? However, you can shrink/expand the variate 'x' as you wish.
SMath Studio Forum
Samples
