SMath Studio - SMath
Grazie per l'ottimo lavoro che svolgete da anni. Sono un ingegnere ed anche insegnante e consiglio di utilizzare il vostro programma anche ai miei studenti
more...
by Aldo Pepi
Grazie tanto per lo splendido lavoro. Io lo uso per i miei calcoli di elettronica. Большое спасибо за замечательную работу. Я использую его для моих вычислений электроники. Thank you so much for the wonderful job. I use it for my electronics calculations.
more...
by Vito BLASI
I use this program on my everyday civil engineering calculations, and I highly recommend it!
more...
by GiE
4 users thanked Andrey Ivashov for this useful post.
on 08/03/2021(UTC), on 08/03/2021(UTC), on 09/03/2021(UTC), on 10/03/2021(UTC)
Hi. Thanks for the program, and this update. An small issue: Write some text and then put the cursor somewhere in between within that text and hit the right-delete key. When you reach the end of the text, the work DELETE begins to appear several times: Best regards. Alvaro.
Originally Posted by: Razonar I can easily reproduce it. What a funny bug, can't keep myself to print several DELETE. Somebody stop me
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Yes. Edited by user 08 March 2021 15:39:06(UTC)
Oops... I did it again I've spent so many time on backward compatibility, performance and formatting improvements... even forgot to check the simplest use cases. Sorry. Will fix it asap. Actually I'm starting to prepare to make a stable release, so I do not plan to do any major code changes until it is done. Small fixes/corrections only. Thank you!
7 users thanked Andrey Ivashov for this useful post.
on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 27/03/2021(UTC)
