Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 124 time(s) in 82 post(s)
While making finishing touches to the attached SM file (latest version), a warning message propped up to continue or quit. I continued, saved and closed. But now unable to open it. It loads but immediately closes without any message. Can this be recovered please? This is the first time I came across this type of an issue. I use latest WIN 10 64 bit Home edition TEST.sm (388kb) downloaded 17 time(s).Edited by user 26 February 2021 19:55:33(UTC)
Joined: 23/07/2013(UTC) Posts: 1,124 Was thanked: 506 time(s) in 337 post(s)
For information, same behavior with bug under Linux. Seems a line break is written wrong to file. Corrected it with text editor and tried to save under smath to replicate the bug. Couldn't achieve to bug reappear again. Code was like this previously. Code:<p><br>EE</br>Calculate the head losses and the corrected fows in the various pipes of a </p>
Revised to this with text editor. Code:<p>EE<br />Calculate the head losses and the corrected fows in the various pipes of a</p>
Regards TEST_rcv.sm (489kb) downloaded 21 time(s).Edited by user 27 February 2021 03:20:47(UTC)
Originally Posted by: overlord For information, same behavior with bug under Linux. Seems a line break is written wrong to file. Corrected it and tried to save to replicate the bug. Couldn't achieve to bug reappear again.
Thank you very much for your contribution. It saved me a lot of trouble. |
You are welcome, happy to help you.
Originally Posted by: overlord For information, same behavior with bug under Linux. Seems a line break is written wrong to file. Corrected it with text editor and tried to save under smath to replicate the bug. Couldn't achieve to bug reappear again. Code was like this previously. Code:<p><br>EE</br>Calculate the head losses and the corrected fows in the various pipes of a </p>
Regards TEST_rcv.sm (489kb) downloaded 21 time(s). I've had this issue before. Thanks for the fix, the last time this happened, I had a backup. The funny thing is, per HTML code, the first screenshot looks "more" correct. NDTM, I spotted what appears to be minor spelling error. F LOWS, not FOWS
Originally Posted by: ElSid I've had this issue before. Thanks for the fix, the last time this happened, I had a backup. The funny thing is, per HTML code, the first screenshot looks "more" correct.
NDTM, I spotted what appears to be minor spelling error. FLOWS, not FOWS
Yes. Thank you. Now I made the correction. |
Whenever I try to edit contents of some description boxes the unhandled exception error message props up. For information of Developers please. Edited by user 01 March 2021 07:38:51(UTC)
Originally Posted by: ndtma Whenever I try to edit contents of some description boxes the unhandled exception error message props up. For information of Developers please. Please attache the content of the "Details" window. Originally Posted by: ElSid The funny thing is, per HTML code, the first screenshot looks "more" correct. IDK I'm only an amateur HTML coder but to me <br> always has been a void/empty element; looking at standards: In the orginal HTML (up to 4.01) only <br> is correct; In XHTML <br/> <br /> and <br></br> are allowed, <br> is not allowed. In HTML 5 only <br> <br/> and <br /> are allowed, <br></br> is not allowed. <br>something</br> was newer allowed, so it seems an encoding bug to me. Edited by user 01 March 2021 13:43:32(UTC)
Both issues fixed. Thank you!
Regards TEST_rcv.sm (489kb) downloaded 21 time(s). Most accurate and informative answer.
