6 Pages123>»
Offline uni
#1 Posted : 22 November 2010 23:42:19(UTC)
uni
Was thanked: 979 time(s) in 561 post(s)
EFI for SMath Studio
SMath Studio compatibility SMath Viewer compatibility mono compatibility Platform Extension page Sources
This plugin will help you to connect the old unmanaged code (numerical) to SMath Studio (only for 32-bit systems (*)).
Path to userefi folder:
Code:
%appdata%\SMath\extensions\plugins\91a20d24-c30b-4774-9b1b-4d502a80420f\x.x.x.x\userefi\
You can see the list of loaded functions in the log file when the program is running:
Code:
%appdata%\SMath\extensions\plugins\91a20d24-c30b-4774-9b1b-4d502a80420f\x.x.x.x\mcadefi.log
Examples of user libraries using EFI:
1. C (Š”++): test
2. OPascal (Delphi7): NumericalRecipesPascal
3. Assembler (RadAsm): test2 (not finished)
4. Fortran 2003 (IVFC XE 12): TestFortran (not finished)
Links:
1. Steamtables for Mathcad.
2. Design FIR band-pass/stop filters up to length~2000 (remez2.dll).
(*) CorFlags will help you to use this plugin on 64-bit system.
CorFlags.zip (142kb) downloaded 1 time(s).
Edited by user 27 February 2021 16:54:07(UTC)  | Reason: Not specified
File Attachment(s):
Mathematical library for MathCad v1.2.pdf (75kb) downloaded 412 time(s).
Steamtables v. 0.3.pdf (56kb) downloaded 269 time(s).
SMathStudio_Desktop_0.97.5154_32bit.zip (194kb) downloaded 138 time(s).
SMathStudio_Desktop_0.97.5189_32bit.zip (205kb) downloaded 141 time(s).
SMathStudio_Desktop_0.97.5283_32bit.zip (200kb) downloaded 95 time(s).
Creating a User DLL.pdf (134kb) downloaded 282 time(s).
userefi.zip (409kb) downloaded 227 time(s).
SMathStudio_Desktop_0.96.4909_32bit.zip (196kb) downloaded 128 time(s).
SMathStudio_Desktop_0.97.5301_32bit.zip (201kb) downloaded 143 time(s).
Russia ☭ forever
Viacheslav N. Mezentsev
šŸ’° Support me for plugins development: https://yoomoney.ru/to/410013245578758
on 23/11/2010(UTC)
Offline frapuano
#2 Posted : 23 November 2010 11:59:58(UTC)
frapuano
Was thanked: 13 time(s) in 13 post(s)
thanks a lot for your posting and sorry for the stupid question but how can I install it.
I have copied the 2 .dll under the plugin dir but when SmathStudio starts I receive several error messages and the plugin is not loaded.
Thanks in advance for your help and your efforts to improve smath.
Francesco
Offline omorr
#3 Posted : 23 November 2010 12:31:43(UTC)
omorr
Groups: Registered, Administrators, Advanced Member
Serbia
Was thanked: 313 time(s) in 267 post(s)
The same question,
I also do not know how to make this plugin to work and which one of the dll's from this archive to use and how.
I assumed that I have to copy everything under "plugins" folder in this archive into "plugins" folder of SMath. As Francesco mentioned, severeal error boxes appeared. This is obviously wrong regarding the dates (from 2009) of some of the approprriate dll's (or not?).
Here is one of the error boxes:
Is there maybe some mess with Mathcad's system of user made functions via dll's?
Offline uni
#4 Posted : 23 November 2010 13:14:23(UTC)
uni
I'm thinking...
Yes, that's right. It's simple to install.
Russia ☭ forever
Offline uni
#5 Posted : 23 November 2010 13:38:09(UTC)
uni
Try these dlls: mcadefi_20101123.7z
I don't know where a problem. All works for me.
mcadefi.dll and mcaduser.dll must be in the "\plugins\" folder. Path "plugins\userefi\" must exists.
SMath Studio version: 0.89.8 (03 October 2010)
Russia ☭ forever
on 23/11/2010(UTC)
Offline omorr
#6 Posted : 23 November 2010 14:35:37(UTC)
omorr
Serbia
It is working now Biggrinancing:
Thank you uni very much Thank you
BTW, I hope that something could be done in order the new user functions inserted via plugins could have their place under Insert|Function Category. At the moment they can be seen only in the "all" category and via Dynamic Assistance.
Edited by user 23 November 2010 14:43:01(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#7 Posted : 23 November 2010 15:14:01(UTC)
Was thanked: 1744 time(s) in 591 post(s)
Now works for me too! Thank you uni!
Offline uni
#8 Posted : 23 November 2010 16:38:57(UTC)
uni
Also they can be seen in the "Service\Plugins..." dialog, but remember that it's the test version.
Mathcad strings are not supported yet and error tables too.
Russia ☭ forever
Offline omorr
#9 Posted : 23 November 2010 16:49:46(UTC)
omorr
Serbia
Hello uni,
Ah yes, you are right- forgot to mention. I've looked there first to see how many functions the plugin consists of.
Thank you for your efforts. I appreciate it very much.
Offline frapuano
#10 Posted : 24 November 2010 11:53:42(UTC)
frapuano
Hello uni,
now works on my system too! Thanks again for what you are doing. You are really a master , I am reading the russian forum ( bad traslated) and you are pushing forward costantly to improve the system with a lot of new ideas and results.
Keep on the good working and take care.
Francesco
Offline uni
#11 Posted : 24 November 2010 17:57:35(UTC)
uni
Thank you, Francesco.
Check new version on your system: mcadefi_20101124.7z
This one completely supports the User EFI interface, with strings and error messages.
Russia ☭ forever
on 24/11/2010(UTC)
Offline uni
#12 Posted : 26 November 2010 15:19:00(UTC)
uni
Some bugs fixed: mcadefi_20101126.7z
Russia ☭ forever
on 26/11/2010(UTC),  on 26/11/2010(UTC)
Offline gurro
#13 Posted : 29 November 2010 00:58:42(UTC)
gurro
Rank: Member
Was thanked: 6 time(s) in 4 post(s)
I have tried to load the Mathcad EFI plugins for SMath Studio 0.89(build 8) unsuccessfully.
I copied the files "mcadefi.dll" and "mcaduser.dll", and the folder "userefi" (containing the files "bmqcad.dll", DIGAMMA.DLL", "KRONECKR.DLL", and "mathlib.dll"Wink into my SMath Studio directory, namely: "C:\Program Files(x86)\SMath\SMath Studio\plugins".
I keep getting two messages indicating that it couldn't load or assembly "mcaduser.dll".
I am using a Windows Vista Ulimate in a 64-bit Toshiba Satellite laptop.
Any ideas on what I could be doing wrong?
Gilberto Urroz
Offline uni
#14 Posted : 29 November 2010 08:14:31(UTC)
uni
Try to put files (just mcaduser.dll and "userefi\*.*" ) on another path:
"C:\Program Files\SMath\SMath Studio\plugins"
P.S. I am afraid that for a 64-bit platform it will be necessary to recompile the project.
Edited by user 29 November 2010 14:00:08(UTC)  | Reason: Not specified
Russia ☭ forever
Offline kazdano
#15 Posted : 28 February 2011 03:01:44(UTC)
kazdano
Hmm... Uni could you explain why Avira Virus Lab detects file "bqmcad.dll" as Trojan???
I used online scaner as well: http://virscan.org/repor...d89b784c6534edfd326.html
So only 4 on 37 scanners detect it as something dangerous.
Dry I'm almost sure that is OK but ... maybe you can put some light on it Uni.
Edited by user 28 February 2011 23:54:06(UTC)  | Reason: Not specified
Offline uni
#16 Posted : 05 March 2011 02:32:37(UTC)
uni
I took this file from here:
http://karataev.nm.ru/bqmcad/bqmcad.zip
The author is Evgenie Karatayev (Ekarataev@mail.ru). I don't know why scanners think so.
Here the source code of library: http://karataev.nm.ru/bqmcad/bqmcadsrc.zip
Page: http://karataev.nm.ru/bqmcad/
Possibly such effect gives a splash window:
Code:
void ShowScreen( void)
   if( Show)
      // show only copyright message
      MessageBox( 0, strMessage, strCaption, MB_ICONINFORMATION | MB_OK);
      Show = 0;
   return;
Anyway you can compile your own library.
Russia ☭ forever
Offline Remmen
#17 Posted : 17 March 2011 23:02:34(UTC)
Remmen
have anyone had success with this plugin in Linux? The plugin is disabled and I'm getting an error report when starting SMath:
An exception was thrown by the type initializer for <Module>
And ideas?
/Lars
Offline uni
#18 Posted : 18 March 2011 08:40:46(UTC)
uni
It uses an unmanaged code which probably isn't used in Mono. SMath Studio is completely written on .NET platform and Mathcad plugins aren't, mcadefi.dll - the intermediary between managed (.Net, SMath Studio) and unmanaged (Win32API, Mathcad UserEFI interface) code in Windows. Most likely in Linux it will never work.
This plugin only for Windows (like Mathcad).
Edited by user 29 March 2012 15:08:55(UTC)  | Reason: Not specified
Russia ☭ forever
Offline omorr
#19 Posted : 03 February 2012 06:04:55(UTC)
omorr
Serbia
I've noted that Mathcad EFI plugin has its own round(1) function. SMath has round(2). In spite of that the both functions have the same name but different numbers of arguments, when the EFI plugin is active then we can not use round(2). Here is a simple example:
EFI plufin enabled:
c←80/9
c=8.8889
round(c)=9
round(c,3)=9
EFI plugin disabled:
round(c,3)=8.889
Offline uni
#20 Posted : 29 March 2012 15:02:09(UTC)
uni
This function from Mathematical library for MathCad v1.2 (Giuseppe Borzì ) which is in the userefi/mathlib.dll file. You can delete mathlib.dll and function round() will disappear without plug-in switch-off. The example with function is given in the Mathlib.pdf (page 3).
Russia ☭ forever
on 29/03/2012(UTC)
6 Pages123>»
