Joined: 04/07/2015(UTC) Posts: 5,163  Was thanked: 818 time(s) in 650 post(s)
Originally Posted by: overlord  You really don't understand what we are telling, do you? What if you really had to change the diagram or create a different diagram from scratch?
In the picture below, I had created your example diagram in MS Word using only shapes. Also added an additional step for you to understand. I understand and produce what the client team can visualize/sanity check, for them to solve/advance their demand. I was the sole Canadian single consultant for AECL [Atomic Energy Canada Limited ... not just a pet shop]. I appreciate what you can do otherwise, as long as you associate the maths that govern your new diagram. Your last circle ? comes from the maths that you have removed. In short, your diagram is crippled. My original diagram represents a not visual working algo. It complements the most common logic diagrams only useful for coding that needs no understanding the objective end use. You are right, I don't understand why you are asking more about you own doing. If you have it doing so simply, why a plugin rather that suggesting a tool ? In that music, You play flute, I play "don't know" or vice versa. Just need a Master Orchestra, chasing cloud by hand ... Seemingly, Martin offers himself. Take care ... Jean
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,122   Was thanked: 979 time(s) in 561 post(s)
Originally Posted by: overlord  It is scalable and vectorial, you can easily add new items or remove existing without print quality loss. You can also create it with Inkscape, Adobe Illustrator, etc. But please explain, why shouldn't we also do this inside SMath? We are just dreaming here (only dreaming at this moment) to create or manipulate this kind of things in SMath Studio. This is more complicated than a simple shape plugin. If the shapes need to be connected or combined into diagrams, then this is already more difficult. You should know that in ms office not svg pictures are used, but special classes, since you can't have interactive schemes based on pictures alone. It will look like a small cad system. I mentioned this earlier here. The OpenS-CAD source code is more suitable for your requirements. But as you probably know, you need to find human resources to do this job. Unfortunately, it is not yet clear how to do this. Most of the users are happy with the current functionality. This topic is used only for collect ideas, not for discussing them. I created a separate one where you can continue, but there is a bug in the forum engine that prevents me from moving the discussion there. Edited by user 29 November 2020 09:51:38(UTC)
Joined: 23/07/2013(UTC) Posts: 218  Was thanked: 65 time(s) in 46 post(s)
Shapes don't need to be connected, they are not in this example too. Only need is them to be simple resize function. Some polygons, triangle, square, circle, lines and arrows should be enough. This is just an idea by the way.
Originally Posted by: overlord  Some polygons, triangle, square, circle, lines and arrows should be enough. 1. Polygons we have all sorts published [Area, Perimeter, Center of gravity] 2. Square, Triangle ... pretty easy 3. Circles ... we have all sorts in the Forum 4. Plenty of arrows. Enjoy the clock ... Jean Circle_rkfixed Clock.sm (27kb) downloaded 14 time(s). Circle_rkfixed AnalogClock (1).sm (23kb) downloaded 11 time(s). 2D Plot Setup Glyphes-Quadrant-Arrow.sm (37kb) downloaded 14 time(s).
Originally Posted by: uni  This is more complicated than a simple shape plugin. If the shapes need to be connected or combined into diagrams, then this is already more difficult. That's the answer. Once you will have digested the under the hood of gyzmas shapes from Samples SVG Primer, it is clear that all your creations are in vector. Then you need a core structure to join all those vectors [of your creation] into again a resulting stand alone creation That's what CAD systems do and there are plenty freeware ... LibreCAD, FreeCAD ... Unfortunately, none come with infinite library of gyzmas shapes. In 1990, I was consulting to revamp a bunker 2 Power Plant. No choice: AutoCAD 11 ... why ? Quebec-Hydro spent ~ 2 millions $ US for AutoDesk to design AutoCAD 11 wrt Process Control & Instrumentation, we had to design all our symbols +++ Who has need of that kind of re-invention in Smath ? ... To me, SVG Plugin is a dead stone that won't grow wings until it turns into fertilizer.
Yes uni, you are right. It is not easy task and require manpower but I think it is not impossible or very hard. It is not a CAD system I am talking. You misunderstood the concept. There are already web sites which are SVG creators and editors. https://editor.method.acThere are also several vbnet codes I have found but not tested. ShapeEditorTest_VS2010.zip (35kb) downloaded 9 time(s).If I hadn't leave coding for 10+ years and have spare time nowadays, I assure you I could implement it. If html code can svg editing, .Net code sure can do. And it was not me who made this is a discussion. It was Jean who made it which one will piss further contest, as always he do. I have just wrote my idea about a plugin to draw svg internally, he still try to debunk it. He even tries to debunk bug reports which are truly there waiting for to be corrected. I just don't like his attitude about these issues. If he continue this I will reply to it. Regards
Originally Posted by: overlord  Yes uni, you are right. It is not easy task and require manpower but I think it is not impossible or very hard. It is not a CAD system I am talking. You misunderstood the concept. There are already web sites which are SVG creators and editors. Slight consolation that two of us misunderstood the concept. Consequently to the failure of my XP Home PC, I have lost the personal e-mail of Steen Groode the creator of GeoGebra https://www.geogebra.org/m/WWYy5394Plenty of advanced Classrooms
Joined: 28/08/2014(UTC) Posts: 647  Was thanked: 348 time(s) in 226 post(s)
Hi. Ok, now we have Document mode, in a first stage of implementation. Very good! So, time for ask for the next feature Presentation mode!. SMath now can also store the zoom of the document, which can help in this feature. Presentation mode could mean different thinks, depending of the point of view of the developer. For example, this is what mean in Wolfram mathematica: https://reference.wolfra...to/CreateASlideShow.html In Microsoft Power Point there are also an option (in a button at right bottom) for use the slides in presentation mode but into a window, not in fullscreen. Maybe for SMath Presentation mode could be a fixed window with controls for move between slides, from some given templates for the screen proportions, in this case, the paper size and the default zoom. I guess that maybe that don't require a big effort for recoding everything. I don't know also if it necessary a new extension (like smp and smpz) or not. Best regards. Alvaro.
