- There is no replace option.
- I suggest use muti-level-criteria for find and replace selection:
The first level is whole document / from mouse point above / from mouse point below /select regions
The second level is all / text / math
The third level applies to math only all / variable only / subscripts only / superscripts only
Edited by user 30 January 2021 12:31:23(UTC)
| Reason: Not specified
Originally Posted by: netsonicyxf There is no replace option. Replace what, where by what ? In math regions we have: click the var/parameter, F8, back space, new.
Originally Posted by: Jean Giraud Replace what, where by what ? In math regions we have: click the var/parameter, F8, back space, new.
I can see uses, especially with the NEW document mode. Andrey even improved the search feature in 0.99.7691 BETA.
Originally Posted by: Jean Giraud Originally Posted by: netsonicyxf There is no replace option. Replace what, where by what ? In math regions we have: click the var/parameter, F8, back space, new. I tried it, it has some limits
- it works for variable only, but it doesn't work for super/sub-script.
- it only work in one region for one time, it not work for multiple regions or the whole document.
- it doesn't work for text regions.
Edited by user 30 January 2021 17:29:47(UTC)
Originally Posted by: netsonicyxf it works for variable only, but it doesn't work for super/sub-script. it only work in one region for one time, it not work for multiple regions or the whole document. it doesn't work for text regions. 1. It works for parameters as well. 2. Works for interlated regions, as multiple times. 3. Zap part of text, paste or compose new stuff.
