2 Pages<12
#21 Posted : 21 January 2021 19:02:40(UTC)
Originally Posted by: ElSid Go to Quoted Post
Not sure why you cannot open.
It is a persisting random bug, from unknown.
Windows not recognizing *.sm format, at random and why.
That bug has not been isolated ... Russian Roulette ?
Offline Ber7
#22 Posted : 22 January 2021 10:09:05(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
A good way is to work units-less, then append silent units.
Calculation without units. Units are presented at the end of the calculation
Heate.sm (10kb) downloaded 8 time(s).
Edited by user 22 January 2021 10:16:47(UTC)  | Reason: Not specified
Offline ElSid
#23 Posted : 22 January 2021 17:28:29(UTC)
ElSid
Ber7,
Still off by a factor of units (12 to convert inches to ft). I split this to a NEW TOPIC. I've never used the Mat2System function.
Edited by user 22 January 2021 17:32:30(UTC)  | Reason: Not specified
#24 Posted : 22 January 2021 17:46:23(UTC)
Thanks Ber7, nice sterilized units
Heate 6179.sm (15kb) downloaded 5 time(s).
Offline ElSid
#25 Posted : 22 January 2021 17:49:28(UTC)
ElSid
But it's wrong Sad
#26 Posted : 22 January 2021 18:05:10(UTC)
Just divide something by 12
Offline ElSid
#27 Posted : 22 January 2021 18:08:24(UTC)
ElSid
That's the problem. Units are important and impact the way the function is not working. Divide t by 12 and the The x column no longer starts with 4, but 1/3 and the y column is correct. Leave it as is and the x column is correct and the y column is wrong.
#28 Posted : 22 January 2021 19:09:45(UTC)
I love Ber7 method, saved it personal.
Easy to scale/reconciliate from your original by 'λ'
Unit Waterloo Otherwise.sm (16kb) downloaded 6 time(s).
Offline Ber7
#29 Posted : 22 January 2021 19:27:55(UTC)
Ber7
Israel
In dimension Ro there is a ft. Therefore, the size t
should be expressed in ft. The bug has been fixed.
Heate in-ft.sm (10kb) downloaded 8 time(s).
Edited by user 22 January 2021 19:30:46(UTC)  | Reason: Not specified
#30 Posted : 22 January 2021 20:34:41(UTC)
Therefore, the size tshould be expressed in ft.
Wait and watch what Elsid will comment !
Units system is really a Monkey Business, isn't ?
Offline ElSid
#31 Posted : 22 January 2021 20:49:53(UTC)
ElSid
Correct, divide by 12 ... in this case.
This elegant function appears to work on all empirical equations, as long as the user input units are double checks for consistent cancellation.
Is the descriptor of the function accurate? Heat Capacity Function_Sys2Mat Ber7.sm (16kb) downloaded 10 time(s).
Edited by user 22 January 2021 21:54:04(UTC)  | Reason: Added attachement
Offline Ber7
#32 Posted : 23 January 2021 20:51:29(UTC)
Ber7
Israel
Change your file a bit and added clarifications
Heat t Ber7.sm (17kb) downloaded 18 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 24/01/2021(UTC)
2 Pages<12
