  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,499   Was thanked: 1776 time(s) in 601 post(s)
New Beta SMath Studio 0.99.7691 is available!Tiny, powerful, free mathematical program with WYSIWYG editor and complete units of measurements support. It provides numerous computing features and rich user interface translated into about 40 different languages. Application also contains integrated mathematical reference book. Changes introduced in current buildImprovements- Automatic replacement context menu item added to TextRegion;
- Search in TextRegion significantly improved;
- Text Region: Show all characters context menu item added.
Corrections- Visible special XML symbols fixed in Text Region;
- Issues related to work with ordered/unordered lists fixed.
Download
 6 users thanked Andrey Ivashov for this useful post.
on 21/01/2021(UTC), on 21/01/2021(UTC), on 21/01/2021(UTC), on 21/01/2021(UTC), on 22/01/2021(UTC), on 23/01/2021(UTC)
Joined: 05/03/2009(UTC) Posts: 412   Location: USA Was thanked: 12 time(s) in 11 post(s)
Problem with areas. The titles disappeared
Joined: 05/06/2014(UTC) Posts: 272   Location: Colombo Was thanked: 82 time(s) in 59 post(s)
Originally Posted by: ElSid  Problem with areas. The titles disappeared Same problem with my SM files too. Edited by user 23 January 2021 06:47:09(UTC)
Joined: 23/07/2013(UTC) Posts: 252  Was thanked: 69 time(s) in 50 post(s)
Originally Posted by: ndtma  Originally Posted by: ElSid  Problem with areas. The titles disappeared Same problem with my SM files too. They are there, but not visible unless you try to select the titles. It is same with smath book with quite sometime, maybe related to document mode, it started with build 7666. Even if you have disabled or never activated it area titles disappeared from me since document mode is released. It will be fixed soon I guess. Regards.
Originally Posted by: overlord  It will be fixed soon I guess. True.
Andrey, I can no longer specify a "custom page size". I need larger than 11x17 US.
