SMath Studio Forum
Bugs & Problems
Plugins crash in Smath Studio 0.99.7679
Was thanked: 62 time(s) in 46 post(s)
Hello The following plugins crash in Smath Studio 0.99.7679  Best Regards Carlos
 1 user thanked CBG for this useful post.
I have the similar issue:
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,477   Was thanked: 1744 time(s) in 591 post(s)
I will update these plug-ins soon.
Originally Posted by: Andrey Ivashov  I will update these plug-ins soon. Is it possible to add a button to temperally disable plugins so they don't get loaded at startup but still can be checked for update?
Originally Posted by: netsonicyxf  Originally Posted by: Andrey Ivashov  I will update these plug-ins soon. Is it possible to add a button to temperally disable plugins so they don't get loaded at startup but still can be checked for update? Currently it is not possible.
mMath Files and Knovel Meta Tags Editor plug-ins fixed.
Thank you.
Thank you.
But the Text Region Utilities plugin keeps crashing
Carlos
Originally Posted by: Andrey Ivashov  mMath Files and Knovel Meta Tags Editor plug-ins fixed. When installing them through plugin manager, both of them shows "plugin installation fails" Edited by user 11 January 2021 14:03:49(UTC)
| Reason: Not specified
Originally Posted by: netsonicyxf  Originally Posted by: Andrey Ivashov  mMath Files and Knovel Meta Tags Editor plug-ins fixed. When installing them through plugin manager, both of them shows "plugin installation fails" Looking at the screens hot you provided it seems that you have plug-ins installed by manual copy of dll files. You need to delete such plug-ins first and then install then from Extension Manager.
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,329   Location: Italy Was thanked: 1172 time(s) in 772 post(s)
Originally Posted by: CBG  But the Text Region Utilities plugin keeps crashing
Thank you, I'll try to fix it ASAP. |
Originally Posted by: Davide Carpi  Originally Posted by: CBG  But the Text Region Utilities plugin keeps crashing
Thank you, I'll try to fix it ASAP. Davide, I've forgot to make some reviewed Fields public, so it was just impossible to fix the plug-in. Now it is done. Originally Posted by: CBG  But the Text Region Utilities plugin keeps crashing Fixed.
Joined: 05/03/2009(UTC) Posts: 401   Location: USA Was thanked: 12 time(s) in 11 post(s)
UNI's EFI plugin is crashing too. My new portable install has no plugins at the moment  Should I remove it per 0.99.7610 is availableEdited by user 14 January 2021 02:52:31(UTC)
Originally Posted by: ElSid  UNI's EFI plugin is crashing too. Strange. Just checked EFI plug-in - it loaded correctly in my SMath Studio installation.
Originally Posted by: Andrey Ivashov  Davide, I've forgot to make some reviewed Fields public, so it was just impossible to fix the plug-in. Now it is done.
Thank you Andrey |
Originally Posted by: Andrey Ivashov  Strange. Just checked EFI plug-in - it loaded correctly in my SMath Studio installation. As you see from the screenshot above, I'm using version 7610 (portable version). I uninstalled the plugin and reinstalled. The install went well and no errors. However, once I restart SMath, the error pops back up. Could it be a portable version issue?
SMath Studio Forum
Bugs & Problems
