Offline TerjeB
#1 Posted : 16 November 2020 16:19:38(UTC)
TerjeB
Trying first time with some bigger formula set, but now I have run into a problem with some error propagating into the calculation. Seems more or less lie anything becomes a problem some way down and even if I reformulate the formulas there pops up another problem with a value not being set as shown in the attachment. When I rewrote the formula then another value was marked red.
Feeling like the program is either running out of memory or there is a problem somewhere else causing the problem in the last part.SMath error.png
I saw someone else looking into the text file here on the forum and I see there are some error message there without me understanding how to debug it:
</mathSMath error - 1.png>
</region>
<region left="0" top="5859" width="731" height="32" color="#000000" fontSize="8">
<math error="2" errorLocation="4">
<input>
<e type="operand">G.3</e>
<e type="operand">1</e>
<e type="operand">2</e>
<e type="operand">H.O2_CO2</e>
<e type="operand">K.O2</e>
<e type="operator" args="2">*</e>
<e type="operand">H.N2_CO2</e>
<e type="operand">K.N2</e>
<e type="operator" args="2">+</e>
<e type="bracket">(</e>
<e type="operator" args="2">^</e>
<e type="operator" args="2">:</e>
</input>
<result action="numeric">
<e type="operand">#</e>
</result>
</math>
</region>
</regions>
</worksheet>
Hope someone have time to tell kick me in the right direction here
Terje
#2 Posted : 16 November 2020 17:28:07(UTC)
Attach the document [no monkey see, no monkey do].
Define the undefined or make the formula dependent of the parameters.
Offline overlord
#3 Posted : 16 November 2020 19:23:35(UTC)
Turkey
Jean is right.You want something that is very time consuming for other people to recreate the document they see on a screenshot and debug it while the document can be simply posted.
Offline TerjeB
#4 Posted : 26 November 2020 15:53:51(UTC)
TerjeB
Thanks for answering, I didn't attache the file because I wasn't sure it was OK to do this in here. Good
Blandingers viskositet_R01.sm (273kb) downloaded 14 time(s).Attached is the file.
Best Regards,
Terje
#5 Posted : 26 November 2020 17:42:07(UTC)
Your numerical engine is scrap from other gyzma(s).
That kind of bug is not possible in native Smath.
Offline Andrey Ivashov
#6 Posted : 26 November 2020 19:21:54(UTC)
Program says μr_O2 - not defined:
Searching for μr_O2:
It is really not defined. This equation is only one place where μr_O2 can be found.
This is an error.
#7 Posted : 26 November 2020 21:29:29(UTC)
Originally Posted by: Andrey Ivashov Go to Quoted Post
This is an error.
Quite a curiosity !
Offline TerjeB
#8 Posted : 30 November 2020 14:11:22(UTC)
TerjeB
As far as I can see I have defined the variable here:
Have I done something wrong in this definition?
When I try to print the variable other places in the document it seems like it is defined since it returns a value of zero (which it should have).
Did a test with different value
and it still is a problem even if the value is defined:
Appreciate all help from you here!
Terje
Offline Razonar
#9 Posted : 30 November 2020 15:33:22(UTC)
Razonar
Uruguay
Hi. The error msg is about mr_O2, even red colored another expression. But notice that you define "m.r_O2" not "mr_O2", see the difference in the dot.
Edited by user 30 November 2020 15:53:08(UTC)  | Reason: Not specified
Offline TerjeB
#10 Posted : 04 December 2020 13:23:27(UTC)
TerjeB
Thanks Alvaro and the rest for assisting me here! Finally found the error with your help now. Clap
I see you use an Unknowns() function, is there some documentation of that one? Did not get same result as you when I tried to enter it.
Terje
Offline Razonar
#11 Posted : 04 December 2020 22:35:50(UTC)
Razonar
Uruguay
Hi Terje.
Under Tools / Plugins open the "Interactive Book" named "Interactive SMath Handbook", which it's an extensive and excellent documentation for SMath and almost all it's plugins, by Martin Kraska.
Then look under plugins / Special solvers. There is an entry for Unknows.
Edited by user 04 December 2020 22:42:06(UTC)  | Reason: Not specified
