Und jetzt ? And now => attached document to best use native X_Y plot.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,493 Was thanked: 1274 time(s) in 745 post(s)
Updated.
Changes:
- the problem of drawing piecewise functions is partially solved. |
on 27/09/2020(UTC), on 28/09/2020(UTC)
Updated. Changes: - SS-4652 partially fixed. Edited by user 21 November 2020 14:09:36(UTC)
on 21/11/2020(UTC), on 21/11/2020(UTC)
This is a great plugin. I've been using it for several years now, and it just gets better. Thank you for it. I had a question on if there is any functionality to include a picture as the graph background?
Originally Posted by: Zane Wells I had a question on if there is any functionality to include a picture as the graph background? Have you tried to slide one over the other ? No problem for background, much less irritating . Cheers ... Jean
Originally Posted by: Jean Giraud Have you tried to slide one over the other ? No problem for background, much less irritating . Background and image was possible in Mathcad 11 but not in Smath. Image: yes in empty region of the graph, SS 6179.
Thanks, I inserted a picture with a transparent background, and it worked out great.
Originally Posted by: Zane Wells Thanks, I inserted a picture with a transparent background, and it worked out great. Can you show, very interesting.
Is there a reason why the X-Y Plot is showing decimals as a comma? In the US we use periods and I cannot find where it's getting the requirement Heat Capacity Function_Sys2Mat Ber7.sm (16kb) downloaded 10 time(s).
Originally Posted by: ElSid s there a reason why the X-Y Plot is showing decimals as a comma? In the US we use periods and I cannot find where it's getting the requirement Check "Options" ... set decimal dot. Here, we use . as decimals and never notice , decimal X_Y plot.
Originally Posted by: Jean Giraud Originally Posted by: ElSid s there a reason why the X-Y Plot is showing decimals as a comma? In the US we use periods and I cannot find where it's getting the requirement Check "Options" ... set decimal dot. Here, we use . as decimals and never notice , decimal X_Y plot. Exactly. My settings are decimal dot and plot is showing comma (European style).
Originally Posted by: ElSid Is there a reason why the X-Y Plot is showing decimals as a comma? The standard 2d plot also uses a comma. |
Originally Posted by: Jean Giraud Here, we use . as decimals and never notice , decimal X_Y plot.
Jean, Where in your settings? Maybe it's the newer SMath version and older plugin. Your on 0.98 right?
Jean is in an alternate reality, he doesn't know what is happening at the moment. |
on 24/01/2021(UTC), on 24/01/2021(UTC), on 25/01/2021(UTC)
Originally Posted by: ElSid Exactly. My settings are decimal dot and plot is showing comma (European style). Is it, you can create a vector decimal dot and create project with decimal dot but the alternate reality the X_Y is decimal coma ?
Why X-Y plot can't polt this, while plot 2D can?
Originally Posted by: netsonicyxf Why X-Y plot can't plot this, while plot 2D can? Spool to file 'M' or copy/paste to isolate.
I need a document to find out the reason. I can't reproduce this behavior. Quote:Why X-Y plot can't polt this, while plot 2D can? The components use different source code. |
Originally Posted by: uni I need a document to find out the reason. I can't reproduce this behavior. Quote:Why X-Y plot can't polt this, while plot 2D can? The components use different source code. please see attached. 1.sm (81kb) downloaded 33 time(s).
